I have tried to lockout my light and remove the battery for awhile. The light remembers that it was locked out, even with the battery out. I suspect there is data stored in memory that stays even when the battery is removed. It sounds like that is not your problem though. I know others have had good success getting replacements from Manker, you might try that route.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
… Also be aware that the head comes glued to the body. I wanted to buy one without the glue, but all stock they had then were glued.
A white spirit/gasoline bath will dissolve any glue. The process may require some hours (or maybe a couple days) at ambient temperature, check to see if done every once in a while. Keep as much of the head above spirit level as possible, you just want to dissolve the glue in the head-body threads, isn't it? You'll need a new o-ring there after this.
As a general rule gasoline/white spirit dissolves plastics, though it may take days at room temp for this to be noticeable.
Cheers
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
What's the cheapest you can get this light and where?
Have light will flash :)
Hello guys.
It would be a special edition for the BLF members
pavol77
I was in the same situation and contacted Manker in December 2017. Jason replied that they do not sell the headband separately.
Cheers
Clearance Sale Now!! E02,E02H and E03H 50% OFF
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
Thread resurrection -
I thought I saw a picture of an E02 with a larger, more “tail-standable” tail cap and a rubber grip – or was I dreaming that?
I love this little light but it could use those things -
