1) Super Power CR-18 Led Flashlight, contains 18*CREE XML2 LED Chip. Up to 8700 Lumens (when using 6 pcs 18650 batteries). Powerful enough to light up an entire football field.
2) Bulb Quantity:18 Light, Color: cool white, LED Lifespan: 100,000 hours.
3) Mode Arrangement: High(100%) / Middle(50%) / Low(30%) / Strobe(100%) / SOS, Lighting Distance: 287 m
4) Battery Configuration: 2 or 4 or 6 × 18650 Rechargeable Batteries(not included), Input Voltage: 3.6-4.2V, 4.2Vmax
5) Runtime: 2-4 hours, Switch Type: Click/Clickie, Switch Location: Tail-cap, Lens: Convex Lens
6) Waterproofing design: IPX7 (But Can’t put it into water directly)
7) Internal wiring applies the high efficient booster circuit, working voltage is wide and can utilize the batteries in the largest extent
Color: Black
Material: Aviation grade aluminum alloy
LED:18*CREE XML2
Voltage: 8.4V
Color BIN: Cool White
Mode Memory: No
Switch Type: clicky
Switch Location: Tailcap
Lens: Toughened glass
Reflector: Aluminum Textured
Beam Range: 287m
Strap/Clip: Not included
Dimension: 8.6in × 3.5in x 2.1in
Weight: 863g
https://youruifire.en.alibaba.com/product/60626133025-804858050/COURUI_C...
I will shoot some videos and upload them on Youtube. We have any suggestions, you can speak. Thanks
youruifire
Hey, you sure those are Cree leds?
Forgot my pen
This project is loaded with CREE XML2 chip, the picture is just showing 18 lights, (can ignore the image chip)
youruifire
How about the shelf, where the leds
Sit on, is it solid, or hollow
Using 2s makes me want to change all the led to XHP 50
Forgot my pen
I feel much brighter than the brightness of XHP50, after all, is 18 L2
This is my link to buy, you can see, there are detailed pictures and parameters https://youruifire.en.alibaba.com/product/60626133025-804858050/COURUI_C…
youruifire
They look like LatticeBright “XM-L“s
Like almost all of the lights with a lot of HP-LEDs
The Body is the same as this one http://kaidomain.com/p/S022371.12-x-Cree-XM-L-T6-LED-5-Mode-13800-Lumens-Flashlight
The inner 4 LEDs will get toasted pretty well
They are not CREE XM-L2…
This should be in the commercial subforum.
