Test/review of Tronic AA 2300mAh (Silver-Black)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 18 hours ago
DSC_9107
Official specifications:
  • Voltage: 1.2V
  • Capacity: 2300mAh
  • Low self discharge (LSD): 75% after 1 year
Tronic%20AA%202300mAh%20(Silver-Black)-info
Maximum temperature raise at different discharge currents: 1A:+1,9°C, 2A:+5,2°C, 3A:+8,8°C, 5A:+16,2°C, 7A:+22,3°C, 10A:+26,5°C
A fairly cheap brand of LSD batteries.
DSC_9087 DSC_9088
DSC_9108 DSC_9109
DSC_9110
DSC_9111
DSC_9112
Tronic%20AA%202300mAh%20(Silver-Black)-Capacity
These curves do not trace fairly well, especially not at higher current.
Note: I had a glitch on my test station when testing the A cell at 0.1A, that is the reason for the early termination.
Tronic%20AA%202300mAh%20(Silver-Black)-CapacityTime
On these curves it is a bit easier to see that the A cells is bad at higher current and it cannot even deliver 5A. The B cells performance is more average.
Tronic%20AA%202300mAh%20(Silver-Black)-CapacityTimeHours
Tronic%20AA%202300mAh%20(Silver-Black)-Energy
Tronic%20AA%202300mAh%20(Silver-Black)-PowerLoadTime
Tronic%20AA%202300mAh%20(Silver-Black)-CurrentTest
Here it is very obvious that the internal resistance of the two cells are very different.
Tronic%20AA%202300mAh%20(Silver-Black)-Charge
Conclusion
The B cell in my test has about average performance, but the A cell has rather poor performance.
If the batteries are used in fairly low drain devices this will not be a problem, but the batteries are not good in high current devices (Anything that can run them dry in less than 1-2 hour).
Notes and links
The batteries was supplied by a reader for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Woody
Woody's picture
Last seen: 10 hours 15 min ago
Thanks for the review. Good timing too, Lidl in the UK have these (and the AAA version) on sale from tomorrow. Think I’ll give them a miss.
ChibiM
ChibiM's picture
Last seen: 14 hours 28 min ago
For some applications they might be okay, but definitely not in series.
Thanks for the test HKJ
Tinderbox UK
Tinderbox UK's picture
Last seen: 7 months 2 weeks ago
I have not had a problem with these battery and i must have a few dozen, you can always do a capacity test and group your battery`s for use in flashlights that take more than one cell so you don't get an uneven discharge problem.
John.
Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
