Hey guys,
Just been having a chat about lighting with the father I.L and he’s pointed me in the direction of fresnel lenses for the purpose of fixed focal length collumation. From my brief reading they have slightly higher light transmittance than aspheric and are basically aspheric lenses with the ‘excess’ material removed.
Do they perform any differently to an aspheric when placed at a fixed focal length.
Thanks
Thom.
Just an idiot with a soldering iron.
The Fresnel lenses I have seen and the ones I have tried myself (cheap ones I had laying around) they always had a rainbow effect on the beam, super intense but ugly to look at.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
Here is a good video I watched, about a year ago. He uses a Fresnel lens, with his homemade light.
Note the beam pattern too, at about 2 feet in front of the light, at the 02:39 mark.
That video is kinda cool. Certainly throws a fair way! They are available in 42mm (that’s C8 size right???
Might grab one to check out as it seems an interesting idea for a thrower.
There are two types of fresnel lenses.
Typical spherical fresnel lenses, and aspheric fresnel lenses.
https://www.edmundoptics.com/optics/optical-lenses/fresnel-lenses/aspher...
The aspheric ones are basically the normal aspheric lenses with the excess material removed.
This is the ones you want for a flashlight.
Don’t waste your time with spherical lenses, they suck for throw and collimation.
The only reason to really use these fresnel lenses is if you want a low cost / low weight solution for large diameter lenses.
Anything below 4” or so you can get a regular aspheric lens for cheap.
When you start going 6-12” then regular lenses get extremely heavy or expensive.
Keep in mind that fresnel lenses will have a reduced projection quality when compared to regular lenses, because of the way it is cut up into sections.
The OPTOFIRE - 4.63Mcd aspheric LED flashlight The SYNIOSBEAM - 10Mcd recoil LED flashlight List of the farthest throwing flashlights
My experience is that good fresnel lenses can be similar in performance to traditional aspheric lenses in terms of lux for a given diameter lens. Bad fresnel lenses might have larger spaces between the active concentric parts of the lens which leads to effectively less active area and less lux.
Their main advantage is lighter weight and less space.
I’ve tried a number of small fresnel lenses in lights and have compared the results to same-size aspheric.
The results:
Net result is fresnels throw worse than a comparable aspheric. I think the problem is that at the transition of each peak and valley on the fresnel some light is wasted and not focused. This loss is much greater than the amount absorbed by the extra thickness of the aspheric.
If you want max throw in a flashlight aspheric is the way to go. Fresnels are more suited for when you want the absolute thinnest and lightest possible light. I agree with previous posters that fresnels make more sense in large lens flashlights where the weight and cost of an aspheric may become prohibitive.
Hence their use in light houses. (That’s where the conversation that sparked this question began)
someone here?
made a cool weird light once for an experiment.
they took a fairly standard LED and driver, mounted it in what looked like a stereo speaker box, and fitted a big fresnel where the speaker foam would have been.
i remember it being weird and different and creative, and lighting up stuff a ways off. the only downside was size and the beam was a little colored and ugly, maybe. BUT, big size was the POINT, they wanted to see what a 2 foot wide lens would do.
i thoroughly enjoyed the build thread, though… it was just “different” and “creative” in my book, 2 things you cant get enough of for my moneys worth.
fresnels keep popping up unexpectedly for me. I found an old “make your TV screen bigger” fresnel in a junkpile, and took it home to watch my little old laptop play DVDs on my laptop on my bed… it was originally out of a “high school projector transparency thingy” but i made it be a “bigger TV” lens instead.
then, a buddy took me to some guys house, and this guy had BIG lenses, one of which (several feet wide?) would set a 2×6 on fire almost instantly, guy had been experimenting with solar cooking power for camping.
to me? they have a certain coolness factor…
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
