June 11, 2017 Convoy M1 Quad
32 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 11 hours 34 min ago
Well, today seemed like a good day to build my second Convoy M1 Quad. So I headed out to the shop and proceeded to carve an aluminum (shocker, right?) heat sink/spacer to fill the head of the new M1 I just got from Simon. At the same time, I’m trying the new Nichia 319 for the first time. I like to fit the heat sink to all the contours inside the head, also allowing the quad optic to seat flush at the top of the sink so it’s fully supported and the sink is up against the glass lens. So that’s how I went about this one…
The emitter shelf is cut to fit Richards new quad board, with the walls tapered to clear the TIR’s within the quad optic..
Always an interesting challenge to get all the dimensions right, tapers and all, so that the heat sink mates to all surfaces inside the head. Especially with one arm severely limited! lol! I have a Dr.‘s appt. tomorrow and another on the 21st with the surgeon, hoping to get this thing wound up soon, but now I really don’t know when surgery will be done. So here I am, doing what I do.
The bottom of the heat sink mates up nicely with the stock emitter shelf…
Ended up being a nice fit, quite pleased…
Richards new Quad MCPCB and a Carclo spot optic…
The MCPCB fits snugly into the base of the sink, almost zero play, while the optic fits flush at the top of the sink when the legs are mated to the mcpcb. This allows the glass lens to be pressed into the sealing o-ring with nice uniform pressure. Wink
I got it assembled with a freshly built A17DD S-08 driver utilizing the Vishay SiR020DP FET and 20 ga leads. I used Arctic Silver to glue the heat sink into the head so it’s a permanent resident. The mcpcb has Arctic Alumina Thermal Paste so if necessary it can be removed easily for updates. (wasn’t sure how this new Nichia 319 was gonna act. Wink )
I’ll get some pics of the finished light later on (am whipped, arm is fussin at me really good by now)
So how does it work, you might ask? Well, it’s a monster! Big Smile
With a freshly charged 3000mAh Efest 18650 I get these numbers…
0.005A for 0.69 Lumens
0.02A for 6.486
0.14A for 57.615
0.55A for 230.805
3.21A for 1090.20
9.00A for 2518.5
18.22A for 4591.95
Wasn’t expecting THAT! nearly 4600 lumens from a Convoy M1, WOW! Gotta love it when a plan comes together… Wink
Assembled and wowing…
Thanks Simon, excellent little light and a superb finish! And thanks to you too Richard, awesome quad boards and they do indeed work amazingly well with the new Nichia 319, thanks for supplying those as well. Smile Still thankful to Wight for his work on the orginal FET+1 boards and ToyKeeper for the incredible A6 firmware, love to be able to back into a lesser mode and avoid that 18A hit up on top. So many amazing people on this forum, just love building these little monsters! lol
Edited by: DB Custom on 06/11/2017 - 18:50
blueb8llz
Last seen: 23 min 53 sec ago
Now that’s truly a monster! Nice work as usual dale.
EasyB
Last seen: 4 months 1 week ago
Nice result and nice machining! It definitely does increase the difficulty when you try to fill all of the available volume in the head with the spacer.
djozz
djozz's picture
Last seen: 3 days 11 hours ago
Nice fitting work! Quite a sleeper:-)
I have a question though: I have built one 319 triple (3000K 80CRI) and was quite put off by a distinct yellow center in the hotspot. I would like to know if that was these specific leds and colour temperature or that it is an unpleasant general feature of the 319 ? Could you check if there is any of that in your beam?
Jensen567
Last seen: 3 years 4 months ago
Beautiful work. I need one, the M1 is my favorite light. Do you have a drawing for the aluminum spacer? I might try to make one myself.
DB Custom
DB Custom's picture
Yeah Jos, it’s like that in this one too. Somewhat like the XP-G3, Nichia style.
Jensen, I just made it on the fly to fit this light, sorry.
In level 6 I can hold onto it for a couple of minutes, hot but not quite burning up until then. On level 7, about 30 seconds, 35, and you just gotta shut it down. That’s at a near 80º ambient.
CRX
CRX's picture
Last seen: 8 months 1 week ago
Nice build Thumbs Up
Does the 319 suffer from this in reflectored lights?
raccoon city
raccoon city's picture
Last seen: 3 hours 56 min ago
Location: Palm Desert CA ~ West Coast is the best coast
DB Custom wrote:
June 11, 2017 Convoy M1 Qaud
There, fixed that for ya!  ;)
DB Custom
DB Custom's picture
I got a few extra 319’s to play with, haven’t put one in a reflectored light yet. Richard cautions against using a single emitter with an FET driver, so it’d be wise to either control the FET with a reduced max through PWM or otherwise limit total output with a regulated driver. The hex shaped die should mate up well with a reflector, the low Vf will just require attention.
Edness
Edness's picture
!https://c1.staticflickr.com/5/4195/35206949916_c7416d4f19_n.jpg!
I built a 319 5000k triple and have the same egg yolk beam. Not a big fan…I still prefer 219c D320.
jescereal
jescereal's picture
In your opinion, is the 319T superior to the 219C D320 70cri in a multi-emitter light?
Box
Last seen: 2 years 7 months ago
Holy shit that’s impressive. Nice skills Dale. Now that’s a pocket rocket
Box
Hahaha Big Smile
MRsDNF
MRsDNF's picture
Nice machining Dale. Well done and thanks for posting it up and sharing your thoughts. Thumbs Up
DB Custom
DB Custom's picture
Well, I’ve built quads with the 219 before and only saw around 4000 lumens (EDIT: just remembered that was in a 35mm CUTE-4, this is the considerably smaller 24mm Carclo), didn’t have the odd beam profile though. So this new 319 delivers more and probably an overall better beam shape, but there are the inconsistencies of color, tradeoffs. Both are low Vf emitters, so either way the amp draw is going to be high. I think I might prefer to use the new XP-L W2 2B that allows the TIR to fit the domed emitter, this delivers good output without overdriving the emitters to such a heat producing event.
This was a fun experiment though, for sure. My first 319 experience.
DB Custom
DB Custom's picture
I had an Eagle Eye X6 host sitting here so I built it up with Wight’s PZL driver and TK’s A6 firmware, used a Nichia 319 emitter in it. The beam profile is UGLY. That center section from a smooth mirrored reflector just really sucks. So I’m gonna have to say this new Nichia 319 really needs an orange peel or equivalent reflector.
CRX
CRX's picture
Thanks for that Thumbs Up
DB Custom
DB Custom's picture
Fixed the beam profile problem, the Nichia 319 seems to really like Illuminations Machines diamond faceted reflector. Big Smile
CRX
CRX's picture
That looks cool, nice even beam now?
JasonWW
JasonWW's picture
Last seen: 1 hour 10 min ago
How bad was the beam?
DB Custom
DB Custom's picture
Nice even beam now. The beam in a smooth X6 reflector was like djozz’s shot, with the ugly center.
Edit: Now, with the diamond facet reflector…(shot at high shutter speed to show hot spot)
Rufusbduck
Rufusbduck's picture
Last seen: 5 months 13 hours ago
“There’s a place in the world for “ * OP. Nice job under challenging circumstances, I can relate. I know you generally prefer RS optics but for some things the blending of SS can result in more uniform beam and color. Do you have the Carclo quad equivalent to try it with?
RIP Dan Fogelberg.
Scott
DB Custom
DB Custom's picture
This is a Carclo quad optic Scott, it’s mated to Richards new quad mcpcb. It’s the SS version, or 10621, purchased from Richard along with the mcpcb’s and Nichia 319’s.
DB Custom
DB Custom's picture
It may be confusing that I also built an Eagle Eye X6 with the Nichia 319 to help determine if the ugly beam profile existed in this mirror reflector on a single emitter use. When it proved out that it does indeed, I rebuilt the light with an Illuminations Machines diamond faceted reflector and smoothed it out. I had to make an aluminum spacer, about 3.2mm thick (filling the emitter shelf area then stepping up to 31.7mm), and used a 32mm Noctigon on top of it, so the leads and contact points would clear the reflector.
Sorry if this second light creates confusion here, was answering CRX’s and djozz’s questions about the 319 beam profile.
J-Dub74
J-Dub74's picture
Excellent work as always brother! Thumbs Up
I only have a single M1 but I love the look and the feel of that light. Doesn’t hurt that a friend of mine turned into a sweet quad! Wink
I also love Illumination Machines reflectors. I’m going to have to have a light with one of those gorgeous reflectors at some point.
DB Custom
DB Custom's picture
Does your wife let you take it for a spin every once in a while? Wink
Yeah, that one turned out so nice I always meant to build another one, just took forever getting around to it. I’m kinda glad I didn’t glue the mcpcb down though, as I do believe I’ll change out the 319’s for something else… will have to play with it some more and use it in a few real world situations and see what I think of it then. As it stands though, the 7th level just makes too much heat to really be feasible so it only makes sense to re-do it with a different emitter. Maybe it’s time for me to do a calibrated set-up like TK did, using different tints to create a nice neutral white. Hmmm……
pinkpanda3310
pinkpanda3310's picture
Last seen: 17 hours 23 min ago
Your the king of single cell monsters Dale Crown
DB Custom
DB Custom's picture
I don’t know about all that, Mitko builds some awesome C8 throwers and Scott sure turns a mean wood battery tube and Steve has really been steppin out with that mill and all, there’s a heckuvalot of talent here for sure!
MRsDNF
MRsDNF's picture
I vote for this one. Smile
DB Custom
DB Custom's picture
Gonna have to start naming my flashlights Protozoa…
Rufusbduck
I suppose that’s better than Amoeba Lights.
Scott
