Charging times
What are the charging times for Trustfire 18650 flames in the new Xtar WP2 II charger? I've had a new set of unprotected flames in there overnight but they are still charging this morning.
One of them finished charging at about 16 hours however another night has passed and the 2nd one is still charging! I guess it's faulty. :(
Where did you get them?
OK having read a review of the charger it seems it is not charging as that would give a solid red light whereas I am getting a flashing from red to green every few seconds. I have put the battery into the right hand charging slot and now have a solid red light so it is charging. It is looking like the problem is with the xtar WP2 II charger itself, specifically the left hand slot. :(
DinoDirect however it looks like it is the charger at fault as the battery is charging fine now in the 2nd slot.
Make sure the battery has proper contact, cleaning the contacts with alcohol might help.
Try putting it back at the 1st slot and see if it blinks again.
Might want to also make sure the battery isn't getting hot in the questionable slot just to make sure.
I've seen chargers do this before .. they just get finicky .. sometimes just pulling them out and putting them back in and they start charging .. might be a small contact issue or .. gremlins
