Test/review of Vappower IMR26650 5000mAh (Green)
Official specifications:
  • Product name: Vappower IMR26650 5000MAH Li-ion Battery
  • Typical Capacity: 5000mAh
  • The minimum capacity: 4900mAh
  • Charging voltage: 4.20±0.05V
  • Maximum charge voltage: 4.25V
  • Nominal Voltage: 3.7V
  • Cut off Voltage: 2.5V
  • Continuous maximum charge current: 4A
  • Continuous maximum pulse charge current: 12A
  • Continuous discharge current: 35A
  • Internal resistance: Max 32m Ohm
  • Size: Max.26.50 x 66.5.00mm (diameter x length)
  • Weight: Max.94.5g
  • Quantity:1pcs
High capacity and high current in a 26650 cell.
There is a piece of paper on the connection to prevent any risk of shorts.
There is a small difference between the two cells, but it is not huge. The cells handle up to 15A without any change in capacity, above that current the capacity goes down.
AT 20A the cells gets hot, but it is just about acceptable.
At 30A I terminated one of the tests due to temperature, but that was only a few seconds before the test would have stopped anyway.
Conclusion
This cell is near the top in performance for high current.
Notes and links
Compare to 18650 and other batteries
Saw the photo before the title, and for a second I thought A123Systems are back in the game.
Well, I guess not. :frowning:
Thank you for testing these cells. Will be buying more 26650’s soon so these will be added to my list to price check before I decide what to purchase.
Thanks for the review!
When I first saw it I thought, he already did that battery!,ohh,the 5000mAh version.
I have the VP 4200mah battery in one of my modded lights. It works very well, For me, the capacity is not that important because I change the batteries in my single cell lights after 15 to 20 minutes maximum! I love max output!
Good to know that it performs well.
