Test/review of Tomo Power bank M4
21 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 4 hours ago
Tomo Power bank M4
DSC_9522 DSC_9523
Official specifications:
  • Input: 5V / 1.2A
  • Output: 5V / 1A, 2A
  • 2-in-1: 18650 Battery Charger + Smart Power Bank
  • Compatible Battery: 4 × 18650 battery (Not included)
  • Weight: 86g
  • Size: 10.00 × 8.40 × 2.70 cm / 3.94 × 3.31 × 1.06 inches
I got it from Gearbest
How does it look
DSC_9495 DSC_9496 DSC_9497 DSC_9498
The power bank is delivered in a cardboard box with a window and some specifications on the back.
DSC_9521 DSC_9526
It exist in black and in white.
DSC_9518
It contains the power bank, a usb cable and a “instruction sheet”.
DSC_9525
All connectors is placed at one end
  • Micro usb: Charge input.
  • 1A and 2A usb output.
  • Power on button.
DSC_9576
On the other end of the box is a display.
DSC_9578
When current is drawn the display will show voltage and current for each slot. The display will not indicate charging.
DSC_9579
When charging a mains cord is shown to the left and the bars in the batteries are animated.
DSC_9528
DSC_9529
The box do not include any batteries, it is up to the user to supply them.
The length of the batteries can be from about 58mm to 69mm.
Measurements
  • Usb output 1A is coded as usb charger (DCP)
  • Usb output 2A is coded as Apple 2.1A
  • Power consumption from battery when off is 3.5mA
  • Power consumption from battery when on is 21mA
  • Power consumption from battery at 1.9V is 1.5mA
  • Limit for detecting current draw or not is about 65mA load on 2A usb and 65mA on 1A usb output.
  • The four battery slots are independent, i.e. no problem mixing full and empty batteries.
  • It is possible to use both outputs simultaneous, but the total current is only 2A, this is enforced.
  • Can be used as UPS
  • Size: 100 × 83.6 × 26.4mm
  • Weight: 87.7g (Accessories and batteries not included)
Tomo%20Power%20Bank%20M4%201A%20load%20sweep
The 1A output can deliver nearly 1.4A before shutting down.
Tomo%20Power%20Bank%20M4%202A%20load%20sweep
The 2A output can deliver 2A, but not the coded 2.1A
Tomo%20Power%20Bank%20M4%202A%20charging%20load%20sweep
The current limit is not changed when charging.
Tomo%20Power%20Bank%20M4%20usb%20out%201A%2010ohm%20%28SA18650-33%29%20%231
At 0.5A load on the 1A output with a single cell in the power bank the curve looks fine.
Tomo%20Power%20Bank%20M4%20usb%20out%201A%205ohm%20%28SA18650-33%29%20%231
Same with a 1A load.
Tomo%20Power%20Bank%20M4%20usb%20out%202A%205ohm%20%28SA18650-33%29%20%231
The 2A output with a 1A load from a single cell.
Tomo%20Power%20Bank%20M4%20usb%20out%201A%2010ohm%20%284xSA18650-33%29
With 4 cell the runtime is more than 4 times longer, here at 0.5A load.
Note: Current measurement is only for one cell.
Tomo%20Power%20Bank%20M4%20usb%20out%202A%205ohm%20%284xSA18650-33%29
And at 1A load.
Tomo%20Power%20Bank%20M4%20usb%20out%202A%202.5ohm%20%284xSA18650-33%29
At 2A load the boost converter has trouble when the batteries are about empty. This killed the power bank.
Current
The current display is not a precision meter, but it will easily show if the connected device is charging and give a very good idea on how fast charging is.
10ohm
Noise is 16mV rms and 159mVpp
5ohm
Noise is 24mV rms and 227mVpp
2.5ohm
Noise is 26mV rms and 335mVpp, all noise values are fairly very low.
Tomo%20Power%20Bank%20M4%20charging%20%284xSA18650-33%29
Charging is with a CC/CV voltage charge curve.
Tomo%20Power%20Bank%20M4%20charging%200.5ohm%20%284xSA18650-33%29
A 0.5ohm in series with the power supply to simulate a long cable or weak power supply will slow down the charging, but not that much.
Tear down
With the power bank dead I decided to take a look inside.
DSC_9823
The box was clipped together and could be opened without too much trouble.
DSC_9824
There is a lot of electronic inside, lets take a closer look at it.
On each side of the display is a dual mosfet (Q3 & Q4) together with dual comparators (U9 & U10: LM393), this is the circuit that is used to select what battery that has to deliver power onto the internal power bus. This power bus can also get power from the usb input via a diode (D2), i.e. if the usb input voltage is a diode drop higher than battery voltage it will supply the boost converter.
Close to the display flat cable connection is a transistor (Q2) to control the backlight .
There is four linear charge ic’s (U1, U2, U3, U4), one for each battery.
In the center of the board is the microcontroller (U8:PIC16F1933), it has build-in LCD controller, ADC and lot of other stuff. The display must have a build in controller, the controller in the mcu is too small for this display.
The boost converter is one IC with rectification build in (U6: G5177C) and a inductor (L1).
Near the usb connectors is a dual transistor (Q5) to shut down the outputs and two resistors for current measurements (R41 0.05ohm & R42 0.1ohm). It looks like the ADC (Inside the microcontroller) has lowest range at 1V and I cannot see any amplification, this means the current measurement is only using 10% of the ADC range.
DSC_9825
Only usb connectors, switch and battery connections on this side of the circuit board.
DSC_9826
DSC_9827
DSC_9828
The LCD is controlled directly from the microprocessor, the red and black wires are used for a backlight module mounted on the back of the display.
Conclusion
This power bank has many good details:
  • Long battery slot, i.e. can handle some protected batteries.
  • Independent slots
  • The display with current for each port
  • Overload protection
  • Easy battery replacement, this makes it possible carry spare batteries or use it as 18650 charger.
But the standby current is a bit on the high side, i.e. the batteries has to be charged every few months even when not using it. I would also have like a bit more current on the 2A port and auto coding.
It looks like this type of power bank has problems with delivering full power for long time: they die.
I will rate it as acceptable.
Notes
The power bank was supplied by Gearbest for a review.
Read more about how I test USB power supplies and chargers
Speed4goal
Last seen: 11 months 2 weeks ago
Thank you for this review. I have three of the original version of this charger. And love them. I’ve put one through the ringer. I take to work with me. Its taken a beaten of you saw it in a recycle bin you wouldn’t even take it. Been dropped, plastic has chemical burns on it industrial bug repellant leaked in my bag and ate away at the plastic. I have to charge the batteries seperarly but these are great if you have piles of laptop pulls or tons of cells. The other two work around the house. I’d like to see a 2 amp charge rate. Instead of one amp.
I did have one die on me after one week of use, but imrbatteries took care of me in no time on it. I recommend if you want a cheap power bank you can swap cells on the go with. I’m not sure about the this new version. But the old one can take protected pana b. Its a tight fit but they fit and work.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 13 min 58 sec ago
Thanks for the review mate!
We can now call you HKJ the power bank killer Silly
HKJ
HKJ's picture
My score is 3 for this year, two that could not handle maximum current and one that died at very low current.
dodge_911
dodge_911's picture
Last seen: 2 years 2 months ago
So, how does this compare to the TLIFE?
Is there a difference in build quality, components?
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
maukka
maukka's picture
Last seen: 7 months 5 days ago
Thanks a lot for the review. Looks just as bad as I have experienced. I don’t like how low the output voltage drops under load.
Also, if you happen to use this heap of mediocrity, you should never load the power bank with only one 18650. It heats up very much when discharged. Even with four batteries the efficiency is quite bad, I got 31.8 Wh out of four 18650GAs, which is about 67 %.
Just get a good 10000 mAh power bank like a Xiaomi, which is not only smaller but better in every way.
The only saving grace of the Tomo is that it’s very cheap and there’s not many like it.
Tinderbox UK
Tinderbox UK's picture
Last seen: 6 months 1 week ago
I have the Tomo version of this power bank, and as said in the comment above the efficiency seems quite low a lot of power wasted as heat and not much getting into your phone/tablet.
The Xiaomi 10.000mah seems to be sold out on a lot of sites, It must be popular, Though i prefer power banks i can change the battery`s once the die.
John.
Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 4 months ago
Thanks for the review.
I am not that familiar with these power banks other than the fact that several3 could not take your test! Wink
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Tinderbox UK
I have had 2 battery charger`s go bang from new, and another just die while charging so it must be catching.
John.
tempo
Last seen: 7 hours 28 min ago
I like my Tomo Original very.
I don’t mind the low efficiency because you can recharge the bank and have infinite energy supply this way
HKJ
HKJ's picture
The Tomo may not be perfect, but it have some advantages:
1) Display of current
2) Easy replacement of batteries (This makes it easy to carry spare batteries).
I do not use it because I want auto coding and preferable Quick Charge and I do not want to carry spare 18650 cells (Except two for my lights). This is personal choices and other people may have other preferences.
angerdan
angerdan's picture
Last seen: 17 hours 2 min ago
So what’s the difference between Tomo M4 and TLife TC-01 ?
HKJ
HKJ's picture
The charge circuit must be different, but the boost converter looks to be about the same.
deleted-200707
Last seen: 1 year 3 months ago
Just returned from a 3 week trip during which, what could go wrong did.
Butt I must say that my TOMO M4 worked as expected on my MP3 player, LG smartphone, a couple flashlights (Nitecore TIP, Astrolux S42), and provided extra 18650 batteries (and/or charging) for my Nitecore MH20GT. A single channel charger (XTAR in my case) powered by the TOMO covers most all my battery needs.
AA/AAA is another animal. Wish they would evolve.
manishpalav
Last seen: 3 years 4 months ago
I have TOMO S4 i accidentally connected its output terminal to input, now its not charging.
d_t_a
Last seen: 10 hours 39 min ago
Just wondering, which is better: Tomo M4, T4 or S4?
angerdan
angerdan's picture
tempo
What's the runtime of the powerbank when i connect a consumer with 0.5A?
I've got an USB fan, and i am going to
angerdan
angerdan's picture
tempo wrote:
What’s the runtime of the powerbank when i connect a consumer with 0.5A?
Depends on the capacity of the cells you put into the TOMO M4.
4× 3000mAh for example give you 44Wh capacity. A 0.5A fan needs 2.5W.
With the conversion losses the fan would run around 13 hours.
tempo
thanks @angerdan !
it's this graph, right?
I've got some old 4xNCR18650B for the test. Before going to bed, i'll pause the test, remove the batteries. I've got an omnicharge 4x18650B too, so i should do a runtime test with it too. Sounds like fair game. We will expect that the omnicharge has a longer runtime.
tempo
The current/voltage/wattage displayed numbers of TOMO, of USB doctor, or omnicharge are not precise because the numbers fluctuate (nature of any fan, hello?). Current draw looks around ~0.5A, so wattage should be ~2.5W, but omnicharge displays 3.0W. So maybe a more relevant practical measure for comparison is device runtime!!
  • TOMO V8-4 w/ 4xNCR18650B (old cells with few cycles, charge-tested avg. 4x3160mAh totalling 49.312Wh): USB fan runtime is a whopping 16h31m30s, i stopped it to the second yay. The four cells recovered after 24h to 4x3.264V offline.
  • omnicharge 4xNCR18650B (old cells with few cycles, nominal 49.500Wh): USB fan runtime is only 15h31m57s, i stopped it to the second. It is unclear to which voltage level the four cells recover after the fan has turned off.
I like this simple clear result. The tomo has a longer runtime than omnicharge, at least for this low current application (0.5-0.6A current draw). I don't think that the tomo has a better energy conversion efficiency. I believe that in the omnicharge the cells don't get discharged as much/deep as in the tomo (did @HKJ measure how deep the cells get discharged in the tomo?); this alone could explain why the tomo runtime is that much longer.
Oh for watt do i need the portable USB fan? — I thought of building a diy mosquito trap hehe. But in the end i solved the mosquitoes-in-tiny-room problem with some spray and a handheld vacuum. Lol!
