Test/review of Ebat 18650 2900mAh E7-18P29 (Black)
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 23 hours 55 sec ago
DSC_0009
Official specifications:
  • Brand: EBAT
  • Model: P29
  • Normal voltage: 3.7V
  • Normal capacity: 2900mah
  • Charging voltage: 4.2V ± 0.5V
  • Discharging cut-off voltage: 2.5V
  • Discharge rate: 30A
  • Rechargeable: Yes
  • Size: 18±2mm Dia 65±1mm Length
  • Cycle life: > 500 times
  • Operation Temperature Range: Charge(0~45°C ) Discharge(-10~60°C )
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-info
This high current, high capacity cell is from a new brand of batteries.
DSC_0008
DSC_0010 DSC_0011
DSC_0012
DSC_0013
DSC_0014
I like that the battery is both marked with pulse and continuous discharge current.
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Capacity
This discharge curves are tracking just about perfectly and the cell can deliver 15A continuous.
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Temp-15.0
The cell gets hot at 15A, but not too hot.
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Temp-20.0
At 20A I had to stop.
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Temp-30.0
And also at 30A
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-CapacityTimeHours
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Energy
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-PowerLoadTime
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-TripCurrent
Ebat%2018650%202900mAh%20E7-18P29%20(Black)-Charge
Conclusion
The cell look like good quality and it can deliver the rated current and capacity.
Notes and links
The batteries was supplied by Ebat for review.
Compare to 18650 and other batteries
djozz
djozz's picture
Last seen: 1 hour 4 min ago
Thanks for the test!
Nice, an honest and good new battery brand. If it is really a china produced battery it sounds really good quality.
EasyB
Last seen: 9 hours 53 min ago
Looks like it could be a LG HG2 cell, based on the discharge curves.
Speed4goal
Last seen: 1 year 3 weeks ago
Hg2 overheats at 20amps like this one?
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
EasyB
Looks like the HG2 does get a bit less hot than this cell, but close. Not sure if that is due to a small difference in the thermometer attachment or an indication of something else.
torchythebatteryboy
Last seen: 1 year 3 months ago
Interesting that these cut off at 20A and 30A. I got full discharges up to 60A constant current, altjough they got really HOT!!
HKJ
HKJ's picture
The jumps in output was because my holder got damaged, not the battery. Yous has probably also vented.
torchythebatteryboy
I was prepared for venting at that temperature, but it didn’t happen.
