ENEDED
2671 posts / 0 new
Bruno28
Last seen: 1 month 2 days ago
My nichia just arrived. Very nice tint and beam.
It’s pretty bright. I’m yet to test at night.
My first thoughts:
The box is really nice make it feel premium when opening.
The light feels heavy and but very solid built. Dedinerly heavier than a imalent Dt70 or niwalker mm15mb.
The battery carrier feels so well built and sturdy, heavy too.
Really liking it. Might even have to order another later on.
Now I’ll have to test a bit more at night and see if it all is working well. But we’ll with it.
Definitely feels like twice the price we paid.
Hopefully astrolux can keep up this quality from now on. Haven’t had much luck on the S41ss and S42.
silicoon
silicoon's picture
My first thoughts:
Left / right 219C middle XP-G3
I have S42.
S41 imalent Dt70 was previously owned.
Here it seems that the reputation of S41 S42 is bad, why?
JasonWW
JasonWW's picture
Last seen: 3 hours 21 min ago
freeme wrote:
Based on Silicoon pics, i suspect MF-01 XP-G3 tint will be fairly close to S41S version. You are right, DQG is more yellow than green, i remembered wrongly.
JasonWW wrote:
 Yes, I know. I have one. It’s a bit on the neutral side, hint of yellow, with a little bit of green. I was wondering how the xp-g3 used in this MF01 compared. If it’s the same, I won’t like it. If it’s a bit whiter, then I would.
That picture shows the NW version of the dqg. I’ve got the CW version and it has a hint of yellow in it. So I’m trying to compare CW DQG 7X with CW MF-01. If anyone has this combination please let me know how they compare.
RollerBoySE
RollerBoySE's picture
Last seen: 6 days 2 hours ago
silicoon wrote:
RollerBoySE wrote:
Does anyone know where I can obtain a decent holster for my MF-01?
Nitecore TM26 holster surprises well.
Thanks for the tip!
(Managed to find someone on eBay who sells the holsters separate and ordered one.)
RollerBoySE
The initial batch of S41 were, due to bad design, prone to shorts at the mounting screws for the LED board. Shorting a Li-Ion is no fun… Later batches have been quite OK.
The initial batch of S42 had a battery tube that was too short for basically all 18350:s on the market. The S42 is still plagued by a couple of bad design choices: like a horrible UI and a driver with cheap components that makes the light underperform badly.
Bruno28
And don’t forget the horrible beam profile and tint on the s42
Ilmatic
Ilmatic's picture
Last seen: 4 days 10 hours ago
BLF (GT, Q8, A6)
Haikelite (MT03 TA, SC01)
Astrolux (EC01, FT03, MF-01, S1, S42)
Sofirn (C8A, SP32A, SF14, SP40)
Emisar (D4, D4S)
[Convoy L6, Utorch UT02, KDLITKER C8.2, Inova T4R]
Ilmatic
Ilmatic's picture
PBWilson wrote:
I tried mine out in an army surplus Smoke Grenade pouch (search in the Q8 thread) and found that it does fit…kind of. The battery tube fits well in the sleeve but the larger head keeps it from settling all the way down the pouch. there’s wasted space below the light. The velcro top does hold it in place securely though so it does work, just note that it’s not made for this light.
I also just received THIS POUCH from Banggood and it’s too big. The MF-01 fits entirely in the pouch with a good deal of room to spare. It doesn’t really have room to roll around, but it’s not snug or form fitting in any way. The drawstring top seems to secure it though and it will work, especially if you have an extra quad of 18650 cells that you want to carry along.
I’m hopeful that POUCH #3 will work just right. I looked at the size and the head of the MF-01 will fit in there. I just don’t know how snug or secure. I’ve got one on order and will report back.
Just got POUCH #3 from your link in the mail today. Fits the Q8 perfectly, the head of the MF01 is a bit of a tighter squeeze, but still gets through. I think the pouch is a perfect size for both lights.
BLF (GT, Q8, A6)
Emisar (D4, D4S)
Ilmatic
Ilmatic's picture
JasonWW wrote:
Ilmatic wrote:
I’m very knew to the hobby (binge bought a bunch of lights) and have a question……After playing around with the MF01, I decided to go charge the cells, and when I put them in my Nitecore D4 charger, I noticed that 1 cell was at 3.37V, 2 cells were at 3.97V, and one cell was at 4.18V. Does that mean that the 4.18V cell did not have proper contact??
Any input would be appreciated. Thanks!
What cells are you using?
Can you measure volts? Put 2 cells in the carrier that are in series and see if you get 8 or so volts. Take those out and try the other 2 cells. Then do the same test on the other 2 slots in the battery carrier.
It’s possible one of your white safety rings is too high causing bad contact.
Tell us or show us what cells your using first.
Just to follow up, I removed all 4 plastic rings off the + ends and re-soldered the brass button tops. All is good now, discharge is even on the 4 30Qs. My ceiling bounce test also registered a 15% increase in output.
BLF (GT, Q8, A6)
Emisar (D4, D4S)
silicoon
silicoon's picture
Thank you Thumbs Up I understood it well.
S41 is a countermeasure lot as though operation itself is no problem,XP-G 219B is both released with fever.
S42 I got battery damage Sick I got a countermeasure item from BG.
The UI is for sure.
silicoon
silicoon's picture
I do not understand this well Sad
S42 (219C) likes low fever.
Bruno28
I took some thermal images of this light. I don’t know how to post photos here but I posted on my Thermal gallery on Instagram.
I ran the light for 2 mins to see how hot it gets. Its about 56 Degrees C before it steps down. But the handle is never very hot, only the head of the light gets hot.
There are a few photos, so flick to the left to see the other shots.
https://www.instagram.com/p/BZVAUEildGZ/?taken-by=thermalshots
The video
rizky_p
rizky_p's picture
why are there a new interest list? sorry i haven’t been following the thread.
JasonWW
JasonWW's picture
If instagram gives you Web page links to the images, you can click the little orangish sunset button along the top of where you type. A window pops up. Paste the image address in there. Maybe choose 95% size, then OK. It will add the photo to your message.
Itsme
As far as I can tell, this 2nd wave is for folks like me that got a code for the first round but by the time I got it and tried to use it, the first batch of lights was sold out and the light was on back order. Just waiting for the 2nd wave code (via PM) so I can buy one this time around
Nicolicous
Nicolicous's picture
They haven’t really pushing this light to the limit yet.
It should handle 65 degrees ok
My convoy L6 get up to 70 degrees without and issues and it does get warm Smile my hand have thick skin Big Smile
Nico -.-
L4M4
L4M4's picture
Last seen: 1 day 2 hours ago
Maybe we should make 2 Threads out of this – one interest list for the next ones, one discussion-Thread
Ronin42
Ronin42's picture
Good to know so if this group buy is now closed maybe Freeme can update the first page?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
JasonWW
JasonWW's picture
It’s not closed. Just waiting for new stock.
freeme
freeme's picture
Last seen: 3 hours 38 min ago
I will notify the members in the list (with new code) once sale resume.
Itsme][quote=rizky_p wrote:
why are there a new interest list? sorry i haven't been following the thread.
Still open.
freeme
freeme's picture
Thanks for sharing Bruno28. One question, how come it doesn't capture its SS bezel temperature?
Bruno28 wrote:
I took some thermal images of this light. I don't know how to post photos here but I posted on my Thermal gallery on Instagram. I ran the light for 2 mins to see how hot it gets. Its about 56 Degrees C before it steps down. But the handle is never very hot, only the head of the light gets hot. There are a few photos, so flick to the left to see the other shots. https://www.instagram.com/p/BZVAUEildGZ/?taken-by=thermalshots !https://www.instagram.com/p/BZVAUEildGZ/?taken-by=thermalshots! The video
rizky_p
rizky_p's picture
ah thanks for the heads up.
got my light today. phew finally. what a beautiful light makes my MT03 look plain this make me want another one. :Good quality overall and i do agree the box look nice definitely beat the box provided by Haikelite by some distance hahah….I think this flashlight deserves its full price.
it only has slight brightness variation on the emitters and that is only on low. i am not complaining it is barely there at least on my unit. Notice the top 6 emitters only just. The cons is now is exactly Noon nothing can beat the sun. cant wait for the dark.
L4M4
L4M4's picture
freeme wrote:
Thanks for sharing Bruno28. One question, how come it doesn’t capture its SS bezel temperature?
Because it is too shiny, it reflects other things.
If you want the temperature from that, put a bit of coloured tape over it
WTF
Last seen: 2 months 4 weeks ago
Most of the non-contact temperature meters I have used don’t deal with shiny metal very well. It looks like his camera doesn’t either.
If you put a piece of masking tape on the bezel it will read properly.
Are you expecting the price for the second round of the group buy to change?
rizky_p
rizky_p's picture
spring bypass is it worth doing on this light? anyone done that?
Sledgestone
Interested in the 219c version.
JasonWW
JasonWW's picture
Lexel did it on his review light. I can’t remember if he measured an improvement or not. Worth checking out.
Tally-ho
Tally-ho's picture
Last seen: 1 hour 18 min ago
silicoon wrote:
It is still copper if it is this brand Wink
Yes Astrolux tend to use copper for the head of their flashlights but a MF-01 with a copper head will be much heavier and this will also increase the price significantly. Not worth the price if they don’t push the high and turbo modes to higher current (with higher gauge wires to the LED banks).
Jtm94
Last seen: 16 hours 31 min ago
it was documented that spring bypasses can gain almost an extra amp on turbo
JasonWW
JasonWW's picture
Make sure to do all 5 springs. I’m guessing it’s the one on the driver that benefits most.
I’m not even sure he bypassed the 4 battery springs. Hmmm?
