You are correct, the DQG NW is way more “yellow/greenish” than the MF-01 XP-G3.
The MF-01 is way purer white/cooler in the overall color.
(The hotspot i pure white, dimming out in the edges.)
I think you’re the second person in this thread who has mistakenly thought I was talking about a neutral white DQG.
I have the cool white DQG. How do the 2 cool white versions you have compare?
Hi JasonWW..
SRI my bad..
It should read : You are correct, the DQGCW is way more “yellow/greenish” than the MF-01 XP-G3. Skip this: You are correct, the DQG NW is way more “yellow/greenish” than the MF-01 XP-G3.
Then I think we are on the same page..
But when we are talking about the MF-01:
– One of the battery carrier are drawing the batteris uneaven.
(acttually, one was at 3.84v, two was at 3.98v while the last was at 4.20v !!)
The other one works fine, drawing the batteries even.
Well my second MF01 showed up today. The three clusters of 219C emitters are evenly lit on low output unlike my first sample. Turbo output is also around 10000 lumens, so I’m very happy. Take it for a spin tonight.
i did the same bypass the main spring and didn’t notice any improvement, i guess the spring is compress in the way that it creates a short path and no bypass is needed or maybe the spring is good enough.
giorgoskok wrote:
Just did a spring bypass on my MF01 219C , on the single spring on the head of the light . Left the carrier’s springs untouched …
Output still the same , no increase even at the first second .
Hi JasonWW..
SRI my bad..
Please check if anyone else has the same problem.
Okay, so the xp-g3 MF01 is a more cool white. This sounds pretty good to me. I was afraid the xp-g3 was gonna be yellow and green tinted like my dqg. Now I may consider getting one. Hmmm.
There has been 3 or 4 people report the same battery voltages. Only 3 of your cells are making contact. You need to check that none of the white discs are too high for your batteries.
Also this:
L4M4 wrote:
I measured my batteries just now and I also had the contact Problem (4.19, 4.04, 4.04, 3.87)
I put out the white thingys and one of those brass things came right off.
I soldered it back and resoldered all others (just put a powerfull soldering iron with no solder at the tip on top of the brass thing).
Also this:
The problem found, had to measure around the board, one of the two brass contacts (+) had come loose.
Had to find out my old solder bolt and put some heat on the brass contact surface and got it fasten for contact again.
The problem was then resolved. made a “dry run” and checked that the batteries were equally discharged and everything was ok.
Thanks for the pointing out JasonWW and L4M4. (BTW: None of the white “discs” were to high.)
If your name is already in the list (post #2),you don’t have notify me if you wish to swap between tints. Supplied coupon will be valid for both tints anyway.
Freemee, I thought I asked to put on the second list (missed out on the GB, too slow), but don’t see my name.
Just one torch, now that I know code will work for Nichia or Cree. It will be Nichia provided same LEDs will be used. I am happy with small price increase for some improvements. Will the tube be knurled and match the MF02, I would prefer that ?
By the way. is the MF02 delayed, last time I looked you didn’t have a date ?
Hi I’m a noob to flashlight world… and I am looking into this MF01 light, and I don’t know if I want XP-G3 or Nichia…
Can someone give me their opinion on each light? All I know XP-G3 gives more lumens output.
And is the 30Q battery the best choice for this light? (I’m also looking for sony VTC6 but they’re hard to find)
The Nichia one will give an even consistently white beam with great color rendering (reds will be deep and saturated) while the XP-G3 will be all over the place with a pale and sickly greenish look to it (at least on some parts of the beam). In my opinion the output difference is not big enough to justify the XP-G3.
They did acknowledge the carrier issue when I asked them. They are currently working on it as well.
JasonWW wrote:
^^ Glad you found the problem. I hope this carrier issue gets fixed on the next batch of lights. It could lead to a dangerous situation.
You name is in the list, you will see it if you scroll down the table. Note: there a few pages for the table. You could either use the search function located at top right corner or click through various pages with the link located at the bottom of the table.
As for knurling design, i have to ask them if they will update them for second batch. 50/50 chance.
Freeme, I thought I asked to put on the second list (missed out on the GB, too slow), but don't see my name. Just one torch, now that I know code will work for Nichia or Cree. It will be Nichia provided same LEDs will be used. I am happy with small price increase for some improvements. Will the tube be knurled and match the MF02, I would prefer that ? By the way. is the MF02 delayed, last time I looked you didn't have a date ? Thanks.
Here are Beamshots of both flashlights from Bluzie (TLF)
NichiaXP-G3
Ohhh thank you! I think I like that Nichia better!
After reading all 47 pages I’ll have to agree with you. Nichia does look a lot better despite the lesser output. The photo from Aussi above showed exactly what you were referring to. And the Nichia isn’t that far behind interma of light output (in picture). The camera might be able to pick up the difference but I think to our eyes will be the same… blinding lol.
I’ve also heard that Nichia in turbo mode will produce slightly more heat than the XP-G3, and I know someone posted about it few pages ago… but I can’t find it anymore lol.
Welcome to BLF!
Are you sure you want with this one?
It gets hot fast, has cells in series and the actual longer usable brightness is matched by lights that are cheaper and don’t get so hot.
I do like how that carrier is made though, but the massive output just makes it too hot too fast and it misses a real moon (with a moon one can look at the LEDs, I like that but low on the MF01 is too high for that).
I am using it with 30Q BT cells.
So idk what you are used to but a nice clear C8 NW Biscotti packs a nice punch and seems more practical and safe to begin with
(Read up on li ion safety see link in my SIG)
Hello!
I am actually looking into several lights and I found a very great deal on Haikelite MT03 and I already pulled the trigger on it lol
10LM,150LM,1000LM is a usable and good light spacing for me, and get to kill zombies with 9000s so that one I got (But haven’t arrived yet…)
At first I was looking at Imalent lights but the one I interested in had bad lighting spacing (from too low to too high) so I scratched that off the list.
Another I very considering is the Klarus G20… 3000 lumens max (Or so they claimed) Rechargeable and comes with battery ready to play. Also found a very good price just under $65 new…
Reason I want this MF01 is because of that high lumens output with under $100… I know it won’t be able to run in turbo for very long but I still want it for no real reasons….. but bright lol
Hello!
Hi yuhsin,
I prefer the Haikelite SC02. The SC02 has a much nicer lightcolour as Klarus G20 and a better heatmanagement !
Will new carriers be available separate (at a reduced price) for us with lights from the first batch?
To be honest I do not know how long “my fix” will last on the carrier. The entire brass button assembly seems terribly weak and if you change batteries often without checking if there is full contact on the board, it may loosen without you knowing it (not everybody have a DMM) and then you are “buring” batteries. The whole soldering process reminds me of my black and white TV that I had in the late 70’s. You just looked at it, and the wires came loose. (Cold soldering.)
(So yes freeme, if the first batch buyers can get hand on an upgraded carrier I will feel much happier both for myself and all others.)
QUESTION: Anybody willing to let me borrow one of these to compare with some other lights in a video? I can pay a deposit and shipping costs both ways etc?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not. http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
You might as well spend a little bit more for the entire light to make it yours. It is a very impressive light.
If they were available I would. I kinda need it soon
Hi JasonWW..
SRI my bad..
It should read : You are correct, the DQG CW is way more “yellow/greenish” than the MF-01 XP-G3.
Skip this:
You are correct, the DQG NW is way more “yellow/greenish” than the MF-01 XP-G3.Then I think we are on the same page..
But when we are talking about the MF-01: – One of the battery carrier are drawing the batteris uneaven.
- George
My Reviews : KDlight C8 / ThruNite Archer 1A V3 / Thorfire C8s / ThruNite TN12 (2016) / Utorch UT01 / Utorch UT02 / Jetbeam WL-S2 (xp-l) / ThruNite TC12 V2 / Massdrop Brass AAA / Manker LAD / Lumintop SD26 / ThruNite Mini TN30 (3x xm-l2) / Qualilite D81 / Nitecore MH20GT / Odepro TM30 / Klarus XT30R / Nitecore NU20 CRI / Ultrafire XM-L2 / Foursevens Mini MK II / Manker E02 / Manker E14 II / Teekland Flashlights / Lumintop Elfin / Thorfire S70S / ThruNite Neutron 2C / Jaxman M8 / KDLITKER C8.2 / Zanflare F1 / Nitecore Concept 1 / Emisar D4 / Astrolux MF-01 / ThruNite TC10 V3 / Amutorch JM70 (xpl hi)
Thanks, probably not worth it then.
maybe their is improvement, but our eyes are not good enough to notice that
10000 and 11000 lumen looks very similar
Forgot my pen
Did not compared by the eye , but in a lightbox !
- George
Reviews: Astrolux MF01s, Haikelite SC26, Fitorch P30R, Nitecore TINI, Amutorch JM70, Utorch S1 Mini, Nitecore TIP, Haikelite MT09R, XTAR OVer 4 Slim Charger, Vollsion MR12-D, Nitecore HC33, Nitecore EC23. Lumintop SD Mini II XPL, BLF Q8, Astrolux MF-01 Nichia, Convoy C8 Clear, Convoy S2+ Desert Tan, Nitecore Concept 1, Emisar D4, Haikelite MT01. Nitecore Tip 2017, Imalent DN70, Haikelite MT07 Buffalo, Haikelite SC01, Haikelite MT02, Haikelite MT03
Switching frequency is 20kHz.
Also this:
Click this to go to signature links. I'm still around, just not reading many new threads.
Thanks.
Nichia
XP-G3
@1theDeals
“My collection”: http://budgetlightforum.com/comment/700139#comment-700139
Will get back to you on this. I have already may a note for it.
@1theDeals
Welcome to BLF!
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
Hello!
Hi yuhsin,
Greets
Carsten
Hope for positive respond..
I want the carrier to be sold as an Sold separately.
Also do not forget the holster
Agree…
About holster. If somebody if sitting in holster for/from NITEYE EYE30 it fits PERFECTLY. Even better than the NITECORE TM26 holster.
Thanks FreeMee, found your latest list at http://budgetlightforum.com/comment/1193681#comment-1193681
All good (PS: just one for me, now knowing code will be good for either type).
Regards.
Wow I only just now found out about this.. Sweet.
Well you’ll probably going to get it afterwards anyway.
P.S. Thanks a lot for all your videos; I enjoy watching them!
