There is indeed a thrower with a bigger reflector coming up next, from what I recall. Someone with a better memory will probably give more info and the name.
Hopefully with added heat sinking people with delicate baby soft hands like me can use it without welding gloves on.
have you tried lowering the Thermal Configuration to match your hands preference?
So many people are complaining about how hot the light gets, and it has a user configurable thermal sensor..
Why doesn’t anybody use it to make it not burn your hand?
I really like the 100% regulated output level. At around 150 lumens it’s approximately between levels 3(80 lumens) and 4(240 lumens) on my E2L, S2+, and BLF A6 which are my most used modes. I have 7 modes enabled on all of them counting moonlight the S2+ and E2L using Bistro.
I have a question about perceived brightness that came to me in my sleep. I understand that to double what the human eye perceives you need an exponential increase in light, but when using floody optics where the output is less dense, thus less bright to the human eye, does that even out the correlation between perceived brightness and lumens?
Does anyone know if there’s plans to make a similar light in a larger body with bigger reflector? Hopefully with added heat sinking people with delicate baby soft hands like me can use it without welding gloves on.
I hear there’s an Emisar D1S coming up soon. Hank estimated it has 120 kcd / 692 m of throw.
It’s D1. From memory, 40 kcd. It seems to use XP-L HI. Can’t wait. ADDED:
Confirmed, around 40 kcd. Will be available
"Hank Wang" wrote:
Probably in the middle of the month towards the end of the month, D1S will follow soon.
Thanks for the info. I am wondering the classification of D1, D1S and D7, correct me if I am wrong,
So D1 is a small sized balanced light, not as much throw as C8,
and D1S is going to have a bit more throw than D1,
and D7 is going to be a flood light like D4, but with 7 emitters.
Are there any plans on other Dx?
Added a little DC FIX to mine and the partial squareness is almost entirely gone and it’s a tad bit floodier. My approximating shoebox doesn’t see any more light loss than whatever 1 of my “calibrated” lumens is worth at 100% 7135. I also tried melting/burning it off with repeated turbo runs with no failures. Now I can hold off from buying more optics for the time being.
I picture the D7 being very reminiscent of the DQG Tiny. As my anticipation heightens I’m hiding my credit card.
A wild Hank Wang appears outside the great firewall !
Is that D7?
And are the tubes of those lights interchangable?
Yes, D1 and D4 tubes are interchangable, meaning D1 can also use the 18350 tube to become a tiny thrower.
D1 around 40Kcd, 1*XP-L HI, ultra small body, slightly bigger than D4 as it can be seen above, true all arounder for size and throw
D4 around 120Kcd,1*XP-L HI, excellent throw, small body
I’d call D1 a pocket thrower. Less throwy than D8, but much smaller.
D1S is 110 kcd, so just a small thrower.
D7 has 7 emitters and 3 18650s, most likely very floody, though if they keep the styling (head significantly larger than body), it could be throwier than D4 (w.r.t. beam profile, not just intensity). I haven’t seen any pictures or written details, so this is a wild guess.
I’m not aware of any other Emisar lights in the pipeline. I’d love to see some zoomies. And 21700 battery tubes…
I posted this recently over at the “What did you mod today” thread. Thought I should also post it here, since this is the D4 thread.
kaybi wrote:
I went ahead and modded first custom firmware, for the Emisar D4.
Very simple stuff (not like I have the knowledge to do anything fancy). I just removed the mode memory, (Or rather, it always remembers the same level) and now, a single click will always take me to full 7135 power (125 lumens). This way, I always have access to moonlight (long press) medium (single click) and turbo (double click). And if I need any other mode, the ramping is still there, right after moonlight. Basically, I don’t like not being sure about what my flashlight will do once I press a button, so I dislike memory mode. So now, I have the best of ramping UI (being able to choose any specific brightness I want) and the advantages of discrete modes (easy to get to certain pre-defined levels).
Took a few tries, but luckily, my driver testing setup worked well enough.
I also changed the led leads from 22awg to 18awg. It had no effect on the output, according to my “approximating sphere”.
Now, I’m trying to find a way to remove the tailcap pcb, so I can place a magnet there. With some luck, a 1mm or 1.5mm magnet will have enough strength to hold the D4 up, which is the biggest magnet I figure will actually fit in there.
I asked the same question. It seems (did not look above ) there is definitely a D7 coming 3×18650. My question is more of a DQG Tiny 26650 III size (but a little bit longer to avoid the issues shortness causes) so maybe with support they will go for a D? like we keep asking about?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
I epoxied a pretty thick and strong magnet to the outside of the tailcap. Not as clean looking as CRX’s magnet inside the tailcap, but it works for me.
Perhaps is the moment for add option for 20700 tube in next models….be prepared for the future….
I like the D1 and perhaps D1S!!
Can you say
D7L
It’s most likely going to be a lot different in function though. Nothing like a floody quad.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Black Magic
(And there you go, Zanflare F1 is off the to buy list.)
… Do we get to see some pictures of the D7 as well…?
Shoot! Just take my money Hank! Looks like Emisar is going to be a staple in our collections gentlemen.
Thier ain’t no bones in a hot dog. F. York
I sense a large drop in my rainy days fund in the next couple of months
I’m quite interested in hearing more about the D7 too.
Wow! I was going to order a Convoy C8 but now I’m going to wait for this!
I’m trying to build a callous and toughen up!
Dang Wang! Another must have.
That’s such a great development Hank. I would also love to see the body with screw on pocket clip if possible.
Is that D7?
ADDED:
Man count me in for 1 and for D7 too
Reviews: Astrolux MF01s, Haikelite SC26, Fitorch P30R, Nitecore TINI, Amutorch JM70, Utorch S1 Mini, Nitecore TIP, Haikelite MT09R, XTAR OVer 4 Slim Charger, Vollsion MR12-D, Nitecore HC33, Nitecore EC23. Lumintop SD Mini II XPL, BLF Q8, Astrolux MF-01 Nichia, Convoy C8 Clear, Convoy S2+ Desert Tan, Nitecore Concept 1, Emisar D4, Haikelite MT01. Nitecore Tip 2017, Imalent DN70, Haikelite MT07 Buffalo, Haikelite SC01, Haikelite MT02, Haikelite MT03
You’d better find more skilled designer
D7 is using 7*LED and 3*18650
Same UI on all D series from Emisar
Added: Hank beat me to it.
Hank, will D1S be available with 26650 tube?
Can you say
D7L
I wonder how does D7 compare to Q8. Smaller, higher peak output, lower sustained output, floodier, costlier?
