TK's Emisar D4 review
5353 posts / 0 new
Anthon
Last seen: 8 hours 9 min ago
I’d buy asap if hank released a new tailcap with removable magnet and lanyard hole
hIKARInoob
hIKARInoob's picture
Last seen: 47 min 26 sec ago
I’m not convinced the D7 is a flooder. The DQG has seven emitters from a single 26650, so from a thicker triple 18650 you have significantly more space in the head. I can’t imagine the individual optics just placed further apart.
It would be more interesting to have larger reflectors, so probably metal reflectors instead of optics as losses would be high with the latter? With these larger reflectors, the light would move away from the typical flooder beam we’ve seen from the M43 and D7, and have a much higher lux/lumen ratio. So in terms of beam profile, it would be something between a flooder and a thrower, something comparable to an L6 or Q8?
A pure flooder would make the D7, although perfectly executed no doubt, just “another flooder” in a slightly different form factor. But this light could be a game changer… Just my thought I had for a while… Party
RollerBoySE
RollerBoySE's picture
Last seen: 6 hours 17 min ago
I really would like to see the introduction of a shortcut to maximum sustainable level in the next release of firmware. Maybe even make it a selflearning function, based upon the max temp setting and real use of the flashlight (with the particular LED:s and cell).
I love my D4:s and will purchase the D1 and the D7 when available.
Lanyard hole and optional real high CRI versions would make my day.
Agro
Agro's picture
Last seen: 1 min 15 sec ago
DQG Tiny 26650 3th has 33 mm head diameter. This is enough for a TIR with individual lenses of a size similar to Carclo 10 mm ones, like in D4. I don’t know what the lens size actually is there or what lens is it. I tried to find the manufacturer, without success.
D7 body size is going to be like 42-43 mm in diameter. With a somewhat larger head, it’s going to fit a TIR with 16 mm cups. This is enough for 10 cd/lm with a good lens. I guess with a perfect lens this could be beaten somewhat. Use of a floodier lens wouldn’t surprise me either. Somewhat larger head (and thus lens) is possible too. Anyway, I don’t view D7 as anything but a flooder, though I do expect it to be somewhat throwier than D4.
ADDED:
Forgot to mention, throw figures above assume XP-L HI.
spinynorman
Last seen: 5 hours 30 min ago
Always leave them wanting more…
hIKARInoob
Thanks for the figures Agro. With increasing reflector and head size, so does the lux/lumen ratio. I’m more interested in lux value of the D7 than amount of lumens.
Agro
Agro's picture
Just wanted to add: Q8 is a little under 10 cd/lm. So D7 may actually be slightly throwier and in general is likely to be in the same ballpark (as long as you pick it with XP-L HI).
hIKARInoob
Thrunite Mini TN30 (2016) has 7.1 lux/lumen and only 3660 lumens, and I find this light “pretty throwy” for a soda can light. With higher lux/lumen value, you need less lumens for a satisfying experience… Cool
rizky_p
rizky_p's picture
Last seen: 9 hours 21 min ago
i think the D4 should have been using D1 head to sink more heat and D1 should be using a smaller D4 head, D1 with D4 head and XPL Hi should give enough throw i think.
Tixx
Last seen: 2 weeks 21 hours ago
Nite Shadow wrote:
Can anyone comment on the objective/subjective differences between all the NW options? Ideally I like pure white or a little rosy with high CRI. No purple to yellow transitions. Or should I wait til better emitter, probably Nichia, is introduced. Most recent purchases have been Nichia. Or if this has been discussed at length earlier, please point me in right direction. Thanks and Cheers!
I’ve had every one of them and here is my list from best to worst according to my eyes and I’ve had multiples of them, not just one of each:
1) XP-G2 4000k
2) XP-G2 5000k
3) XP-L 5000k
4) Nichia 219c 5000k
SubSailorVet
SubSailorVet's picture
Last seen: 11 months 3 weeks ago
I got my Emisar D4 XP-G a few days ago and I am really impressed with this little powerhouse flashlight! It lights up my entire backyard with perfect cool white light. This is my first light with ramping. Very cool! I love this light! The only drawback is it gets pretty hot. I’m gonna buy a few for gifts that will really impress the recipients. Good job on the design and build of this impressive light! Thumbs Up
Best regards,
Matthew
battery
Last seen: 2 weeks 6 days ago
Hank Wang wrote:
leestrong wrote:
Hank Wang wrote:
mean like this?
A wild Hank Wang appears outside the great firewall ! Big Smile
Is that D7?
And are the tubes of those lights interchangable?
Yes, D1 and D4 tubes are interchangable, meaning D1 can also use the 18350 tube to become a tiny thrower.
D1 around 40Kcd, 1*XP-L HI, ultra small body, slightly bigger than D4 as it can be seen above, true all arounder for size and throw
D4 around 120Kcd,1*XP-L HI, excellent throw, small body
D7 is using 7*LED and 3*18650
Same UI on all D series from Emisar
Too late to re-design a slightly more recessed button?
battery
1) XP-G2 4000k
2) XP-G2 5000k
3) XP-L 5000k
I’m surprised you would put a 4000K Cree as best looking pure white. Almost every Cree I have seen below 4500 is noticeably yellow.
Geuzzz
Geuzzz's picture
Last seen: 7 hours 36 min ago
Does any of you guys know if the mcpcb below is a direct replacement for the D4 board? The description says it’s 2mm thick.
http://intl-outdoor.com/noctigon-4xp-mcpcb-cree-xpg2-s4-5d2-p-919.html
Tixx
battery wrote:
1) XP-G2 4000k
2) XP-G2 5000k
3) XP-L 5000k
Do you have all 4 of these to compare? He also mentioned rosy was fine. The XP-G2 4000k meets that.
khas
Last seen: 8 hours 36 min ago
It’s the same MCPCB , I think he advertised the MCPBS’s before the D4. I have one running a quad Nichia :
D4 Nichia 219C 4000K CRI92 (left) X5 Nichia 219C 5000K (right)
DB Custom
DB Custom's picture
Last seen: 4 days 13 hours ago
Geuzzz, that looks like the same Noctigon board that came in my D4. I’ve replaced it with Richards quad board and Nichia 319AT emitters.
Geuzzz
Geuzzz's picture
Thanks guys! Ordered.
winspiration
Last seen: 3 years 3 months ago
1) XP-G2 4000k
2) XP-G2 5000k
3) XP-L 5000k
How about the other xp-g2 and xp-l tint? I’m curious as to how you would rank them.
Tixx
winspiration wrote:
1) XP-G2 4000k
2) XP-G2 5000k
3) XP-L 5000k
I don’t do tints above 5000k (unless extreme circumstances and a modification is planned). So I only experienced those 4.
electricjelly
electricjelly's picture
Last seen: 2 min 37 sec ago
I received the xp-g2 5d2 4000k and a Nichia 219c 5000k. I much prefer the xp-g2 5d2 over the 219c. The 219c gets hotter and steps down way faster and bigger steps than the xp-g2. The small gain in brightness isn’t worth the added heat in my opinion. The tint of the xp-g2 isn’t pure white but it is below the black body line with a slight rosy hue which I love, especially with night adjusted eyes. I liked the 5d2 tint so much I ordered 3 more quad boards. One to swap out the 219c’s in my green emisar and two more to play with in other lights.
noboneshotdog
Last seen: 4 days 3 hours ago
Just got my xpg2 3d today. Love this little green hulk.
Found I had to set the temperature higher on mine as I like to hover between 600 to 1000 lumens and thermal management was dropping me below 600 lumens after just a short time of use.
Now with it adjusted I am very happy with this purchase.
Thier ain’t no bones in a hot dog. F. York
noboneshotdog
Does anyone know if the offset optic fits this light without any modification.
If so could you please attach a link so I know what optic to purchase.
Firelight2
Firelight2's picture
Last seen: 17 hours 56 min ago
Do you mean the offset star? That’s a replacement star for the LEDs to sit on where each LED is rotated at a different angle so the corona is much more even and not square.
The offset star replaces the stock star. They use the same optic.
You can buy the offset star at Mountain Electronics
noboneshotdog
OK got you. Thanks for the direction. Is this the one?
http://www.mtnelectronics.com/index.php?route=product/product&path=63_64...
rubatone
rubatone's picture
Last seen: 1 year 6 months ago
Is there a clip that works with this light? About to order two of them Smile
I want to be able to strap it to my hat with the 18350 tube. Also will the s4 3D be a good choice?
Firelight2
Yes, that’s the one. You’ll also need a soldering iron and basic soldering skills.
Trevi_lux
Trevi_lux's picture
Last seen: 1 year 8 months ago
Anodized D1 and D1S…. will be nice colours like green or only dark?
gregor
gregor's picture
Last seen: 2 hours 19 min ago
Here you can find macro pictures of this FL:
http://imgur.com/a/2hZd5
Few examples:
You can find more pictures on above link.
Kind regards
ven
ven's picture
Cool pics gregor Smile
I like my D4 on the rocks…………….
