Help making a "timer" for a flashlight.
9 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 1 week 5 days ago
Hi all,
This is an extension of one of my UV projects. I need to be able to make a timer that will shut the light off after a certain amount of time. Got any ideas?
A distant second to this would be a display that showed how long the light had been on for starting when the switch was hit, but the above would be much better Smile
Thanks
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 26 min ago
Needs to be small, I take it?
Dunno if it’d run on as little as 3V, but a JFET timer (eg, 2N3819) would be simplest, its output driving a bigger (MOS)FET.
Else a 7555 IC in monostable mode.
stephenk
stephenk's picture
Last seen: 23 min 27 sec ago
Interested in a solution (especially if it works with ConvoyS2+, L6, or BLF Q8). Would be useful for solo light painting!
mattlward
mattlward's picture
I would think that a 555 variant would have a simple enough circuit to make it fit in a smallish light. UV does not take that much current, maybe a tiny fet to feed 2 7135’s for around 700ma?
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
The Miller
The Miller's picture
How easy must it be to change the time?
Couldn’t a programmer add a mode like this to Narsil
Ramping, modes and timed on
Select timed on starts in time select (a click for a minute) and after 3 seconds no click for time ramp to select brightness
Just thinking out loud here.
vestureofblood
I have a little room to work with. I will go in a 2× 26650 size light.
The Miller wrote:
How easy must it be to change the time? Couldn’t a programmer add a mode like this to Narsil Ramping, modes and timed on Select timed on starts in time select (a click for a minute) and after 3 seconds no click for time ramp to select brightness Just thinking out loud here.
I considered having it work like a turbo timer or similar. That would be better than nothing, but I would prefer that a novice be able to change timer without too much trouble.
I wish I could make it be something like a miniature one of these that was in the end of the tail cap Smile
https://www.bedbathandbeyond.com/store/product/lux-spring-wound-timer/10...
Lightbringer
A 26650 host with a side-clicky, you could replace the switch with a pot and have it go, say, from 0-3min.
In the driver, sense an analog voltage and count down accordingly (like a light/dark thingy in a toaster). With a separate timer circuit, that’d be the resistor controlling the timer.
Or w/o a side-clicky, it might be possible to drill a hole with a really small pot. I’ve seen 1/8” shafts on pots barely bigger than that.
prepro
prepro's picture
Lazy-R-us
Last seen: 2 months 3 days ago
I think your best bet would be to get with one of the firmware gurus and see about incorporating a real time clock to talk with the ATTiny processor. Once the processor has an accurate clock, you could get a mode for both delay off and delay on, with the delay selected by some number of clicks perhaps. Adafruit has several different options.
Alternatively, simply bringing out the pins on an e-switch light to a wireless remote would allow you to control a light that way., Adafruit has these
Or you could go full bore crazy and set up a local Wi-Fi hot spot and run a Spark Photon from your phone controlling any number of drivers with different colors or tints of light. Spark Photons.
Lazy-R-us
