BLF GT Proto. Review. Work in progress. update 6.8.17. Post 69. Run time test added.
129 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 7 hours 38 min ago
Tom E wrote:
Looks Awesome! Can you take full outer measurements and post in OP? I can’t find them in the GT thread OP either – no outer head diameter #.
Thanks!!
134mm head OD
85mm fin OD at button
56mm battery tube
62mm battery cap OD
~315mm total length with long battery tube (ruler only goes to 305mm, guessing on the last 10)
RobertB
RobertB's picture
Last seen: 1 hour 13 min ago
These caps might work for a lens cap, if heated up and pressed on. 133mm
https://store.mocap.com/mocap_en/pc.html?Item=PC154BK1
Texas_Ace
Texas_Ace's picture
Interesting idea, that could work indeed.
MRsDNF
MRsDNF's picture
Theres some nice ideas. The pipe cap looks good and ccc bag if it had a shoulder strap looks like a possibility.
rizky_p
rizky_p's picture
at least the head is not as big as “millions candelas” lamps that runs H3 12v 50w bulb we used to “love”, i still have those.
Suncoaster
Suncoaster's picture
Last seen: 2 weeks 4 days ago
Location: Where the girls are green and the grass is pretty.
There was once a “BLF lanyard” by Manafont, perhaps now there should be a “BLF shoulder strap”.
or custom paracord strap..
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Texas_Ace
Texas_Ace's picture
Yes, this light is perfect for a shoulder strap. I put my S70 strap on it and it works fantastic! Review coming tomorrow. Leaving to take some beamshots in a little bit hopefully…..if I can put off the important work I should be doing right now…..
MRsDNF
MRsDNF's picture
I reckon the leather lanyard your talking about would be able to handle this torch.
southland
southland's picture
Last seen: 1 week 4 days ago
Adsum, that bag does look great for the light if it fits. Maybe someone in China can test fit the light for us.
MRsDNF, can’t wait for more info and some beam shots. See if you can scorch some leaves on that big tree out back.
MRsDNF
MRsDNF's picture
The weather is terrible tonight in this part of the world so no beam shots. Before I do take them I will have to replace the led as it has a black spot on it which appeared this morning. The cause has not been investigated yet.
Starting with the tailcap.
This picture shows the lanyard strap hole in two different places. The part the hole is in rotates 360 degrees around the tailcap itself. The hole has a diameter of just over 4mm and the width is just under 5mm. Wall thickness is around 1mm.
A view of the top and inside the tailcap. The four holes inside allow the inside of the tailcap to be disassembled.
The three components that make up the tailcap. Everything has well lubed orings on it and should be perfectly waterproof. The lanyard swivel has a nice firm smooth movement to it.
I fell in love with the battery holder as soon as I looked at it but nothing is perfect. the negative springs are on the soft side. I’ll let one of the other members with a light to expand on the technical side of the springs resistance wise etc.
71mm long batteries with these springs should fit ok. Flat top 30Q batteries will work but are not held with a lot of force. The positive button is slightly raised in the holder allowing the flat tops to make contact.
For reliability’s sake I’d stick to button tops.
The ends show the positive spring and negative contacts which make contact with the driver. The spring here is short and strong. There will be no issue with it bending over and contacting the negative contacts.
The opposite end has contacts that allow another battery holder to mate up to it.
The driver itself has a large threaded retaining ring holding it in place. The brass contacts on it are around 1mm in thickness and should never wear out.
And finally for tonight is the battery tube. Threads are square cut. The tolerances they are machined to are in my opinion fairly loose. This could be improved upon to make the threads a tighter fit. Orings sit either end as per a normal battery tube.
The outer thread diameter is 53mm. A C8 will fall through this tube without touching the sides. Styling is plain but fits with the rest of the lights design.
DavidEF
DavidEF's picture
Last seen: 1 day 13 hours ago
Shocked Shocked Shocked Shocked Shocked Shocked
- The YKK Philosophy
AlexGT
AlexGT's picture
Last seen: 2 days 7 hours ago
Thanks for the update, Cool Beer
The Miller
The Miller's picture
Last seen: 1 year 12 months ago
Thanks for these detailed pics!
Do you think the tube would benefit from knurling?
bwl123
bwl123's picture
MRsDNF wrote:
Any requests I’ll try and do after work today. Approximately 9 hours time. Tired Edit. It would also be nice if anyone had suggestions on a carry bag for this light. Even for transport purposes to stop it getting damaged.
https://www.aliexpress.com/item/2016-Men-Women-Nylon-Travel-Backpack-Out...
AlexGT
AlexGT's picture
How sharp is this part? In the pics looks like it needs some rounding on that edge…
thijsco19
Last seen: 1 week 5 days ago
When using a shoulder strap I don’t see a problem there. There is a metal connection between that hole and the strap itself.
Or did you mean for handling?
Though I agree it could have a nicer edge.
Edit.
After taking another look that ring looks at that point pretty thing. Could be a weakpoint. However I can’t think of a way to improve it right now.
MRsDNF
MRsDNF's picture
The shoulder is square but wouldn’t call it sharp by any means. You would have a hard time cutting yourself on it. The weakest point of the hole is the wall thickness, not the width.
With the balance point of the shorty tube up towards the head I’m not sure knurling would be of any great benefit but saying that I haven’t really carried it in anger yet. The longer tube may benefit.
Personally I would not use the light in short form.
I cant get the pictures on the bag to open except for the default one. I have terrible internet connection here at the moment which isn’t helping things.
MRsDNF
MRsDNF's picture
After another frustrating night with a non existent internet speed.
Tonight we have some night shots. The camera was used with a slower shutter speed than normal so the pictures dont get blown out.
We’ll start with pictures of the tree in the background which is about 120 meters away. No washing on the line this time of the year so no knicker shots this time. Silly
Firstly is the Q8.
Monster light. MTG2 at 5 amps.
C83. 3 x C8 reflectors running XML2 leds at 5 amps a piece.
OL Tribute light. LUM 90 reflector, XHP70 at around 11 amps.
Defiant Super Thrower. Dedomed XML2 at 5 amps.
And finally the BLF GT. It does this to you. Shocked
Next are the driveway shots to give another aspect to beam profiles.
Firstly is the Q8.
BLF GT.
DavidEF
DavidEF's picture
Shocked is right! Wow!
R10500
Last seen: 1 year 11 months ago
LOL gonna do a cloud-spotting test too? or light up a hill miles off?
pinkpanda3310
pinkpanda3310's picture
Last seen: 15 min 1 sec ago
Nice shots. Thanks Moose.
Does the tint look that cold to the naked eye?
Theodore41
Last seen: 7 hours 44 min ago
Oh my God. Smile
The Miller
Nice beamshots
Ouch so harsh cold that GT, but dang bright Smile
Though I love the Q8, C83 and OL tribute light beams a lot as well.
Yokiamy
Yokiamy's picture
Last seen: 4 hours 58 min ago
Wow, wow, wow and just wow!
[Lovely tint of the Q8 though]
rizky_p
rizky_p's picture
Q8? is that the BLF Q8? havent seen anyone posted beamshots of it.
MRsDNF wrote:
Firstly is the Q8.
Yokiamy
Yokiamy's picture
MRsDNF wrote:
Firstly is the Q8.
Djozz has posted several beamshots, don’t know exactly which post of the almost 10000!
MRsDNF
MRsDNF's picture
I’ve Posted beam shots of the Q8 before. Not sure where though.
The tint of the GT is cool and its unknown to me what it is. The GT will be getting a warmer tint in the production lights.
I should of mentioned these pictures of the GT were taken with the black mark on the led. This will be looked into today.
Lexel
Lexel's picture
Last seen: 1 year 2 weeks ago
Facepalm and they forgot the pocket clip
The Miller
Lots of beamshots of the Q8, just check what we posted, it is in the OP
Most of us posted beamshots but it stood out to me here, without even seeing it was our Q8 at first Big Smile
Can you imagine a nice NW XHP35HI GY beamshot?
Already it is impressive.
MRsDNF
MRsDNF's picture
Just a couple of pictures with big brother posing with little sister.
The MCPCB really is that big. Yes its the Q8.
A C8 reflector sitting on top with a P60 and S2+ reflector out front.
