Decent capacity power bank
18 posts / 0 new
Nightshade
Last seen: 1 year 4 weeks ago
Good folks of BLF,
Can anyone recommend me a decent power bank? I’m taking on a 2 week cycle tour that will include wild camping. Ideally I want as much capacity as I can within budget to be able to keep my phone and garmin in juice. I was hoping to budget around £20 and to find something not too heavy.
Ebay has loads that promise 100,000mah!! I presume that’s just nonsense?
I can find Xaiomi and Aukey packs at 20,000mah in budget – is that the maximum I can realistically expect? Does anyone have any specific recommendations?
I keep checking the deals section on here in case anything turns up.
Cheers!
Lexel
Lexel's picture
If you look at the price for quality lithium packs you dont get more than 20000mAh for your budget
For recharging the bank, maybe you shouls invest in a foldable solar charger than in more capacity
Nightshade
Thanks Lexel, that is kind of as I guessed. So the question moves to which 20,000mah pack I guess?
Having spoken to lots of touring cyclists, I don’t think solar is an option. I will be on the bike all day. You can mount a panel to the bike, but it’s likely to be in and out of shade and rarely at an optimum angle – so I doubt I’d get much charge in.
I might have to invest in 2 packs and just charge them at campsites when I can. Also, I’m aiming to travel as light as I can.
mrheosuper
Last seen: 6 months 3 weeks ago
I would recommend xiaomi 20000 mah gen 2, it has great power efficiency, and the price is good
for 20$ i dont think you can find something better
Forgot my pen
Nightshade
mrheosuper wrote:
I would recommend xiaomi 20000 mah gen 2, it has great power efficiency, and the price is good for 20$ i dont think you can find something better
Is there somewhere special to find it at $20? Gear best, banggood etc are all $30-$40+
mrheosuper
i think with coupon in this forum(at somewhere, i dont know), it is about 2x $(which is quite over 20$, but worth)
Forgot my pen
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
I’d buy one in a second for $20. I have 2 of the newer 10,000mAh Xiaomi’s I’m super pleased with. I also have an older 10,400mAh Xiaomi which is still going strong after a couple of years of regular use.
Boycott Nike
bwl123
bwl123's picture
Nightshade
bwl123 wrote:
https://www.aliexpress.com/bicycle-dynamo-usb-charger_reviews.html?src=g...
Link doesn’t appear to work, although I know what you’re getting at. A good solution, but decent ones are expensive to buy and I also don’t have the skills to rebuild my wheels to accommodate which leads to more expense. I’m fairly confident that a power bank is right for my needs (actually I suspect I’ll find loads of other uses for it beyond this trip too!)
bwl123
bwl123's picture
https://www.aliexpress.com/item/New-Bike-Dynamo-Bicycle-Generator-Charge...USB-Device/32763828029.html?spm=2114.search0306.4.2.MsrYN7
This is the one with most good reviews,but only 250ma.
It’s easy to install.
I would get this and the power bank.
will34
will34's picture
Last seen: 3 hours 44 min ago
Xiaomi 20,000mah V2 for sure. Can be found for as low as 21.99, normally at 24.99.
L4M4
L4M4's picture
Last seen: 4 hours 57 min ago
Where is this Powerbank normally at $24.99?
Gearbest has a flash-sale and it’s more expensive: http://www.gearbest.com/power-banks/pp_600939.html
Nightshade
I’m leaning towards this…..unless it doesn’t look like a decent buy
https://www.amazon.co.uk/d/Cell-Phone-Portable-Power-Bank-Chargers/20000...USB/B0183K0GZC
Ronin42
Ronin42's picture
Last seen: 2 years 2 months ago
Ive had good luck with solar but this looks cool
Promotion 6V3W =.9A Bicycle Friction Generator Voltage Regulator Offer Power Rechargeable Lighting
Description
Adopting high quality T6 LED lights,can be used as Headlamp, waterproof , 6 v3w aluminum shell generator , voltage regulator using the latest generation of 2 aluminium shell voltage regulator, output 5 v, output is a USB port,
Feature: * 100% Brand New and High Quality * T6 White LED.can be used as Headlamp * Waterproofing design. * 6 v3w aluminum shell generator * 2 aluminium shell voltage regulator, regulated usb
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
will34
will34's picture
L4M4 wrote:
Where is this Powerbank normally at $24.99? Gearbest has a flash-sale and it’s more expensive: http://www.gearbest.com/power-banks/pp_600939.html
Yesterday it was at $25.99, but the code expired http://budgetlightforum.com/comment/1163020#comment-1163020
Just wait a couple days until some deal shows up, the 10,000mAh version was on sale for 11.99 just last week.
Dutcheee
Last seen: 3 weeks 1 day ago
I think that aukey powerbank is a very good quality option.
But don’t you have some unprotected 18650’s lying around?
I use this one quite a lot > Aili powerbank ebay
It’s very cheap and gets the job done well. HKJ tested it.
If you don’t have any 18650’s, buy them as well and at some point a nice flashlight to use them in.
Bc412
Last seen: 1 year 6 days ago
The Xiaomi 20k V2 is great. I tested mine out at like 97% efficiency. It was like 14,400 out of a possible 14,800 mah.
I also really like the besiter 6× 20k mah with the usb/usb c dual charging. Only takes a few hours to charge, which is great when you are on the go. It ended up around 90% efficient.
angerdan
angerdan's picture
Last seen: 6 hours 36 min ago
Nightshade wrote:
I'm taking on a 2 week cycle tour that will include wild camping. Ideally I want as much capacity as I can within budget to be able to keep my phone and garmin in juice. I was hoping to budget around £20 and to find something not too heavy.
1. Ebay has loads that promise 100,000mah!! I presume that's just nonsense?
2. I can find Xaiomi and Aukey packs at 20,000mah in budget - is that the maximum I can realistically expect?
3. Does anyone have any specific recommendations?
4. Can anyone recommend me a decent power bank?
1. yes, it's just a paper tiger.
2. 20,000mAh are 74Wh. A single 18650 cell with 10Wh capacity costs around 10€. So 1€/Wh is possible for powerbanks too. £20 will get you a good 37Wh/10Ah powerbank.
3. http://enerprof.de/product-category/batteries/power-banks/?orderby=price
4. ebay.co.uk/sch/Mobile-Phones-Communication/15032/i.html?_udlo=14&_udhi=26&_mPrRngCbx=1&_from=R40&_nkw=powerbank+%28xiaomi%2Corico
....lygte-info.dk/review/Review%20USB%20battery%20box%20Thrunite%20C2%20UK.html
....lygte-info.dk/review/Review%20Charger%20Miller%20ML202%20UK.html
