5th Annual BLF OL Comp Build. Can A Flashlight Flash? The Naked Truth. Update post 151. Night shots added. 16.12.171
155 posts / 0 new
MRsDNF
MRsDNF's picture
Just a small update today.
Lots of thought has been going on in my Moose mind which probably explains a lot, on how to incorporate the fan and drill lots of cooling holes without interfering with wiring and mounting holes for the different components.
I think I’m nearly there so just going to carry on.
This has been redrawn a dozen times and hopefully with a few more holes in it I can start machining. This part will have the reflectors threaded into in and also locate the MCPCB’s which will be screwed down into the next section which will house the fan.
The test reflector was placed into the three jaw chuck to machine the ends of the threads off flush with the base to give clearance for the wiring.
To tune the reflector to the led different width isolators were used.
This was an interesting exercise tuning the reflector as by shining the light on the door of the shed the further into the reflector the led was the smaller brighter the hot spot appeared.
On getting the light meter out to test what I saw with my eyes a different story emerged. The highest reading on the light meter at about 4 meters was with between .6mm to .8mm isolator. This gave a larger hot spot and a fair amount of spill compared with having the reflector base sitting on the base which gave a clearly defined tiny hot spot.
MtnDon
MtnDon's picture
Last seen: 1 hour 7 min ago
Looking like fun…. wish I had a lathe.
MRsDNF
MRsDNF's picture
You could only take so much of with the lathe. It was taken down to .25mm thickness by hand.
CRX
CRX's picture
Last seen: 7 months 5 days ago
Thumbs Up
fritz15
fritz15's picture
Last seen: 3 months 5 days ago
Awesome built so far Smile good luck with the rest!
FmC
FmC's picture
Last seen: 9 months 4 days ago
Looking pretty good – those small taps are fun to work with sometimes Facepalm
Where can I get one of those magic hacksaws??
I didn’t know about chalking the file – thanks for the tip! Beer
MRsDNF
MRsDNF's picture
Welcome back FmC. That went quick. The magic hacksaw came from The Millers picture. Silly
MRsDNF
MRsDNF's picture
I’ll save the boredom of showing another triangle with a squillion cuts on this final triangle piece. The three larger holes will be threaded for the reflectors. Yes it was a whoops in one corner but probably turned out for the better as the triangle is a few mm smaller than it would of been if it was machined to the size I drew it up as.
As the lathe and mill had not been cleaned down for a few weeks that was the first job on the agenda after the above piece was finished. This picture doesn’t do the mess justice.
Back to the lathe and the piece was set up in the independent four jaw chuck for threading.
One thread later and will the reflector screw in?
Yes it does screw in. One down two to go. Its odd that even after screw cutting hundreds of threads I still get nervous that something will go wrong.
And finally we have three threads ready for reflectors.
And then the so called magic hacksaw was ordered to do its bit. Yeah sure. Smile
I asked SHMBO to get me some chalk when she went shopping next as I’d run out of white chalk. She came back with this saying it would make a difference. Well being the doubtful type I was surprised that it did make a difference. The coloured chalk made a pretty big difference. Facepalm
After lots more filing we had this. It assembled with one reflector ok. Will it assemble with three? Who knows.
To me it looks like I made a top and bottom triple clamp. Silly
I’m now back to the drawing board on how to proceed next. The item will house the fan, have cooling holes and the top face will have the leds mounted to it. I hope. Question
FmC
FmC's picture
Well, the hacksaw must be magic – passing through a solid object like that…
That’s starting to take shape now, & really wouldn’t look out of place on a custom bike.
When I haven’t been posting about Drag Week, I’ve spent today making moulds for my build, & keeping an eye on Jack & his buddy who’s come around to check out the build… Flat Stare
MtnDon
MtnDon's picture
[quote]Its odd that even after screw cutting hundreds of threads I still get nervous that something will go wrong.[quote]
I get the same nerves with wood. Most often I get rewarded with a nice fit, good finish… . Other times… Facepalm
MRsDNF
MRsDNF's picture
This weeks update is more about failures than moving ahead.
Trying to hasten the speed of the build up a bit I spent an hour or so in the evenings after work each night in the shed.
Work started on the part that will house the fan on one side and the leds on the other.
The aluminium here is about 110mm in diameter and 44.5mm in width.
3 × 3/8’‘ holes were drilled spaced at 60 degrees.
This allowed 3/8’‘ copper bar to be inserted through the aluminium.
Long story short, I drilled two of the 1/8’‘ through holes in the wrong spot. Wrong PCD.
Starting again I only had 150mm diameter aluminium bar so this was cut to length in the older than I power hacksaw.
On knocking the copper rod through the holes on the second one, the copper picked up internally and butchered the aluminium.
The third one I managed to get the copper through ok.
Lots of holes were drilled and the MCPCB bolt holes were tapped M2 and yes I snapped a tap of in one of the holes. I really will have to get the correct drill for this size tap. Luckily for me it wont matter as the MCPCB’s will also be held down with the reflectors.
Six 1/8’‘ holes are through holes that will let the cap screws pass through from the reflector part with the reflector threads in it, through this section end up screwing into the next section which will hold the driver.
The two random holes are to allow the power wires to feed through to power the leds.
The four large holes here are for the fan cavity.
And a moat appeared.
The through holes for the cooling are yet to be machined.
And finally the fan in its new home, temporarily at least.
CRX
CRX's picture
Third time lucky, cool Smile Thumbs Up
MtnDon
MtnDon's picture
I’m glad to see you had perseverance. And enough aluminum stock at hand. Smile
MRsDNF
MRsDNF's picture
I realised while asleep last night that I need a 12V fan, not 5V. I hope I can find one in the size the hole is.
FmC
FmC's picture
Nicely progressing Smile
If you don’t mind, I’m going to take small comfort in knowing that someone else’s fails were more expensive than my fails Oops
MRsDNF
MRsDNF's picture
Thanks FmC. The bills in the mail as the good wife wont pay this one. Thumbs Up Smile
MRsDNF
MRsDNF's picture
On testing the fan it was found the more gap on the inlet side between the fan itself and obstruction above it the more air it moved. On this basis the hole recess was deepened further.
A hole was then milled out to 19mm in diamter through the copper heat tubes.
This was then machined out in the lathe.
And a view of the heat tube holes where the air blows through under the leds.
I have no idea at all if this is going to cool very well in the light of reality but we shall soon find out.
The fan is in operation here blowing out a gail force wind, I wish. Facepalm
The next part on the agenda to be made is the battery tube.
The problem of battery holders was solved with a quick solution as time is rapidly running out. I had previously purchased in a group buy three battery holders which are 4S1P. I will be running two of these in parallel.
An old aluminium tailgate cylinder rod off cut was found to be around the right size.
This was taken to work to rough it as it would of taken me a week to machine this out on my lathe where at work it was quickly machined out during my lunch break.
The big lathe at work board this depth easily without chatter.
The rough outside was turned down to the same diameter as the Q8 battery tube and the knurling tool set up.
There is no drawing for this part as its just being made up on the go. The battery tube will be part of the naked design when its finished.
After a few anxious minutes which seemed at the time an eternity we had knurling.
At this point if I still drank I would of put the beer down and had a Scotch. I hope someone out there has one for me. Beer
Agro
Agro's picture
Last seen: 16 hours 43 min ago
You have quite a lot of aero resistance already. If you can, pick a high-pressure fan. Also, I would try positioning the fan higher, I have a hunch it would work better.
I would also suggest machining the fan hole slightly deeper and putting a small heatsink at the bottom to add some fin area.
JamesB
Last seen: 2 weeks 4 days ago
SU-PER-B
I have a hunch that the fan would be more efficient (due to much less turbulence in the chamber) sucking though the holes than blowing though them.
MRsDNF
MRsDNF's picture
The fan is what was available quick as there is a time limit on the build.
As for sucking rather than blowing I think it will work better blowing through the holes as the intakes will be a lot larger than the outlets. Then again maybe not. I’ll just get it together and if more work needs to be done I’ll worry about it then.
On a side note I may try and taper the sides of the recess on top of the fan for more of a venturi shape.
djozz
djozz's picture
Last seen: 2 hours 31 min ago
Looks great sofar!!! Following your work in awe again! Smile
Agro
Agro's picture
Sucking is better, always.
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
Man I miss this stuff, feels like im peering through a window at a party I can’t join. Toss one back for me too, will ya?
Scott
CRX
CRX's picture
Lovely craftmanship Thumbs Up
The air output vents would be best adding up to the air intake area, maybe larger or thereabouts I think, plus taking in considerations for right angled bends, reducings, friction etc, there are calculations for that type of thing I’m sure.
Of course I could be wrong about that as it’s not my field but it looks great.
Nice to see you RBD.
MtnDon
MtnDon's picture
A good time to have a wee dram of the ever dwindling supply of Mortlach Thumbs Up Star
pommie
Jusht won mor
Still sitting on the edge of my chair waiting Big Smile
Cheers David
Nothing to see here folks, move along...
MRsDNF
MRsDNF's picture
Thanks for the input Agro. I may come across a bit like that (agro) at times but dont mean to. Wink
I’m always open to suggestions.
I may have to restrict the three holes that dont travel directly under the leds as they may end up shorter in the final shape of this block. My thinking is the shorter tubes will flow more air than the longer tubes travelling under the leds which I dont think will be good.
Good to see you dropped in for a visit RBD. You are sadly missed but then you do have a life away from here. Smile
Looks like Don is about to throw that drink to you. Thanks Don.
Crx. Like your builds you have me lost, with your input. Facepalm I’m just a simple Moose. Silly RBD has spent a lot of time and effort explaining all sorts of topics around here to me and for some reason seems to understand the Moose’s inability to communicate better than lots of others, my wife included. Silly
FmC
FmC's picture
We’re getting to the pointy-end Thumbs Up Sorry, I can’t have a drink for you yet, as I’m about to head off for work Glasses
Your build is really taking shape.
Agro
Agro's picture
Yes, shorter tubes will flow more air. How much? I can’t tell.
Cooling strength is proportional too temperature delta * airflow * cooling area.
By closing the shorter tubes you put much more more airflow to where temperature delta is higher. But you get lower total airflow (not 4 times, but much lower nevertheless) and much lower area. Is it a good idea? I don’t know, but something tells me it’s not.
It will certainly be better initially as heat will arrive in that tube much earlier than in the others.
But as the block saturates with heat, there delta T will not be several times higher in one place than elsewhere.
Agro
Agro's picture
I believe TomE has some experience with thermal analysis of flashlights. Maybe he could tell something about the expected temperature deltas?
