Efest IMR20700 3000mAh (Purple) 2017
Official specifications:
Rated capacity: 3000mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 30A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 20 (±0.20)mm x 70 (±0.2)mm
Efest do also have a battery in one of the new sizes that is slightly larger than 18650. The extra size is used for better high current handling in this cell
The two batteries are not perfectly matched, there is a small difference. The batteries have fairly constant capacity at any current.
At 30A they get very warm and I had to stop shortly before they where empty.
Conclusion
This is a nice high current battery and the slightly large size compare to a 18650 can be seen on the improved performance.
This battery is mostly for people that needs well above 10A, for lower currents look at a 18650.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
