MtnDon's Entry, 2017 (5th Annual) BLF Old Lumens Contest, Handmade Category
68 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 10 min 20 sec ago
Moving on. I filed down one side of a pair of pre ’82, real copper, pennies to make two contact plates for the cell. Both have a spring soldered to one side and a wire soldered in place as well. I neglected to take pictures of one of them before I installed it in the cell hole. Facepalm I did photograph the other though. I’m planning on using a flat top Panasonic 18650B cell. The springs will also allow a button top to be used. The driver that is planned has LVP so I’m not thinking of a protected cell at all.
The disc below has the wire through a hole from one side.
The side with the spring in place. Yes, black = negative.
The first disc I made I glued in place before thinking of the camera. Darn. The red arrow points to the contact disc with the spring in place. Kinda hard to get a photo shooting down the cell hole.
This image from the bottom access hole view shows the edge of the copper disc with the + wire. The darkened spot is the result of the CA glue.
The switch is a small Omten 1288 reverse clicky. It needs to be mounted on the end of a dowel rod (wood) that the first item I made (the copper cap drilled for a switch boot) will fit over. The Omten 1288 is just a little smaller than the dowel rod. I needed to drill holes through the dowel to run the wiring. Some holes at an angle…
Here’s looking at the upper end with a tweezer through one hole…
This is the view of the bottom end. The slot on the circumference is a keyway that will slide over the protruding edge of the copper disc, in the access hole.
Here’s a couple of pre assembly shots showing the switch mount with wires running through the inner holes. That will slip into the hole in the body of the light.
Also note the rounded edges of the block. Those were done with a 3/8” roundover bit in the router. I sanded the block and gave it a couple of coats of clear acrylic finish. The final finish coats will be applied when it is complete.Right now I simply wanted to keep the wood clean and keep the orange color from wood dust from getting on me.
Lastly for today, another shot showing the + end copper disc. A little easier to see than in the other shots.
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
I could here my words echoing looking down the battery hole. Smile
The finish on your wood on the last picture looks so smooth.
MtnDon
MtnDon's picture
Thanks. I have a wide variety of abrasives that I use. I like the acrylic clear coat. (Minwax Polycrylic) Dries quickly, even more so in the low humidity of our desert. Makes a smooth finish that responds wellto the 280, 320 and 400 grits I’ll use between the final coats. Padauk though, has some rather large pores. Very obvious in the end grain and a little less so when cut with grain, but visible on most surfaces on this. Not objectionable on most things I’ve madewith it.
FmC
FmC's picture
Last seen: 6 months 3 weeks ago
Starting to look pretty slick – I wish I had used wood again this time.
CRX
CRX's picture
Good update, wood’s looking great Thumbs Up
MtnDon
MtnDon's picture
It’s raining cats ‘n’ dogs. Too wet to be outside and do what I am supposed to be doing. Smile
A little more work on this light. I have to come up with a name for it, something catchy? LOL
I soldered the switch wires.
Switch mounted to the top of the dowel insert with a dab of instant grab Loctite construction adhesive
The upper section of the dowel rod was filed and sanded to reduce the diamter a little. You’ll see why next.
The copper pipe cap with the switch boot slips over the dowel top and switch. Being conductive copper there is a need to insulate the soldered switch wires from that copper cap. I achieved that with self fusing silicone tape. The dowel diameter needed reducing to allow a couple of tape layers and still let the copper cap fit over. Here’s the wrapped switch.
I checked the switch operation and that the wires/connections were electrically isolated. All good!
Here’s what the switch looks like with the dowel rod inserted into the body of the light, but without the copper cap and the switch boot. That will go on later as it is a tight fit over the silicone tape. I’d rather install it and leave it at the end.
Here’s a shot of the underside with the switch wires looped in the access bay.
What am I up to now, with the cheap Chinese copy of a Dremel cutting wheel?
Yes, cutting a narrow slot! But for what? …an action shot…
After cutting the perimeter slots, a 7/8” forstner bit cleans out most of the cavity. (The drill press light is much more yellow than the general shop lighting.)
After cleaning out the corners with a chisel, here is what we have.
With that recess cut it is time for a recess. Facepalm That’s it for today. I put the project away in the cupboard with a Q8 for good company along with the someday-to-be-completed SRK-clone camping lantern.
MtnDon
MtnDon's picture
A little more wore work tonight. Using a Dremel cutting burr I made some grooves and drilled some more holes to carry wires from here to there. When it’s all done hopefully it will be more pretty than it is now.
I drilled a total of 5 holes tonight. The three illuminated above only go part way through to the wire gallery that will be covered by the bolt on back slab. Two other holes go from that rectangular recess right through to the other side. Hereare the two exit points.
The two holes that pass right through are difficult to see in the shot. The start on the right side of the recess, about a1/4 inch from the lower right recess corner. They look like a black ink mark, but are blacker than the marker lines. From this side they diverge slightly to emerge slightly further apart than on this side. Drilling through wood close together often results in the holes bending towards each other. I shimmed the block to intentionally try to keep some distance bewteen the holes on the far side. It worked.
Tomorrow I hope to review the wiring plan, then connect up some parts.
Thanks for looking.
MtnDon
MtnDon's picture
Ooops. I take back what I said about tomorrow and wiring. I still need to drill / carve two more holes or access ports. Facepalm Getting excited as I get close to completion.
MRsDNF
MRsDNF's picture
Thats a good sign you getting excited. Smile
I to can C your getting to the pointy end. Silly
MtnDon
MtnDon's picture
I had meant to drill this access port before I set the switch mount in place. Sad So I had to use the dremel with a couple of different cutting burrs. The tape was a guide for placement. This is to allow wiring the LED.
Light from a flashlight aimed in the intersecting hole…
0.025” (0.76 mm) thick copper sheet that has been around the shop for decades. The stock piece keeps getting smaller… Polished up. There are a couple pit marks but this won’t be on a direct easy to see line of sight.
The emitter (XT-E) will be mounted to this copper plate.
More to come a little later today/tonight.
MtnDon
MtnDon's picture
I’m back sooner than I thought I would be. Now to some hitherto undisclosed details. There will be an integral charger, a TP4056 board. That is what the previously shown rectangular cutout in the side is for. However the USB socket is mounted remotely…
This is for the USB inlet port. The grooves adjacent to the left is where I was first going to place it. But I changed my mind.
The TP4056
Thanks for looking.
MRsDNF
MRsDNF's picture
Looking good MD. Its good to see an item stashed years ago with the thought it will get used one day actually get used. Thumbs Up
CRX
CRX's picture
Getting there Thumbs Up
MtnDon
MtnDon's picture
More parts. One is store bought and was retrieved from my box of miscellaneous metal odds ‘n’ ends. Stuff that was intended for some other previous project or just “collected” because it was cool. That one is about 1 × 1.5 inches and from 0.040” (1 mm) copper sheet. I needed one a little larger so traced the store bought onto my 0.025” copper.
I cut it out with av snips.
Then, clamped between wood blocks, I filed it to refine the shape and smooth the edges.
Store bought on the left, my handcrafted one on the right. I’ll press that oops out.
Originally my plan was to use the larger one by itself. However, stacking the two is more attractive to my eye.
Holes drilled for mounting… #2 × 1/2” brass screws.
That’s all for today. Hopefully I’ll be back tomorrow with more progress. Thanks for looking.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 24 min ago
Everyday is looking better Wink Good work Thumbs Up
MtnDon
MtnDon's picture
EDIT:Forgot a picture and messed up the order on one of theothers. Facepalm
MRsDNF
MRsDNF's picture
Nice work Don. I dont know how you keep the thin material so flat.
MtnDon
MtnDon's picture
I wired the USB port up to the power in terminals of the TP4056. Some kaptan tape was used to temporarily tape it in place. Then a brass escutcheon pin wasdriven in through one of the unused board connection points to secure the USB port board from pulling out of the block when unplugging a cord. Escutcheon pin = fancy name for a decorative nail. That’s it in the middle of the 5 holes along the one edge. The pin head will require a slight dimple in the wood cover plate.
After careful measuring the TP4056 was affixed to the copper plate using Arctic Alumina adhesive and some kaptan tape to ensure electrical isolation from the copper plate. Inside the charger board recess, lower left edge, you can see two small greyish looking circles. Those are fiber optics.
Here we have a test underway. The charger is charging. The red light from the LED on the TP4056 board is piped through the fiber optic so we can see a charge cycle is underway. A change of lighting has made the wood appear more red than it really is. The color of the padauk will change over time, as both light and air does cause a shift to darker shades.
Rather than wait for the Samsung cell to reach full charge I changed to a fully charged Panasonic cell. The blue LED light now illuminates to indicate a full charge has been reached. (The charger was previously tested and it does function properly. I was just in a hurry for the photo.)
The charger side, opposite side of where the fiber optics exit. The copper plates are affixed using brass screws. They do multiple duty as access cover for the TP 4056 board and a heat sink.
That’s it for now. Gotta get back to the shop. Thanks for looking.
MtnDon
MtnDon's picture
One more image for tonight.
I have a few things to note.
The upper left side bore hole, the one with the penny visible in it, is where the 18650 cell is located. Plus end is inserted first. There is a spring at the bottom end, the + end and another spring soldered to the down side of the penny. The short walnut dowel rod fits into the upper end of that bore hole to hold the cell firmly between the + and the – contacts.
The cell is not meant to be removed for charging. The cell can be changed out if that is necessar, by removing the three Phillips head screws that secures the wood back plate, similar in concept to the LiPo that CRX used in his beautifully crafted entry for this years contest. Changing the cell is a bit more involved than with a conventional flashlight with a threaded tail cap but is still less hassle than my laptop or an iPhone.
As things sit right now some of those visible wires are not yet connected. The ends are just pushed into the various nooks and crannies to allow me to trial fit the cell with the connector plates. The walnut plug is long enough to fit the flat top Panasonic 18650B cell. The springs provide sufficient squish room to allow for a button top, maybe a protected cell. I have not tried one. The driver is equipped with LVP so I don’t really feel the need for a protected cell.My plan is to use the flat top as I have a few without homes.
Maybe I can get this done tomorrow. Smile I need to fit the driver and connect it to the MCPCB/emitter, mount the copper emitter plate, complete the wiring and see to a few other details.
Thanks for looking.
FmC
FmC's picture
It’s really coming together now Don Thumbs Up
I see you went the smart route & didn’t braze any of the copper….. Facepalm
MRsDNF
MRsDNF's picture
Big Smile
MtnDon
MtnDon's picture
Reviewing my original design notes, the first thing on the page is “practice brazing”. I skipped, never got around to, that step, though I did get some Fuze-CleanFS. The acetylene bottle has been empty for months though… keep forgetting… Sad
MtnDon
MtnDon's picture
C’est fini!!
It’s finished!. Here’s the back with the driver installed at the right and all the wiring complete. Kaptan tape used to keep the wires out of the way. I glued a piece of tool drawer liner to the bottom; just visible to the left.
This is it, upside down. The back plate has been installed with the three 8-32 aluminum screws.
A three quarters frontal view, from the brown wood side…
Three quarter frontal view from the orange (padauk) side…
Showing the rear plate…
The rear with the other, brown panel, side…
Showing the bottom…
MtnDon
MtnDon's picture
Views with the LED lit… There are 6 brightness levels; reverse clicky switch. I did the pictures on either level 1 or 2; I forget. Getting old. Facepalm The 2 × 7135’s (700mA) give plenty of illumination for the intended use. In fact I’ll probably never run it on high. The driver is a Nanjg 101-AK-A1 that came with 4×7135’s. Two of them are now in a parts box.
MtnDon
MtnDon's picture
Smile Beer
I’ll be happy to answer any questions.
FmC
FmC's picture
Well, there’s three things I didn’t have going for me; Design notes, Practice, & Acetylene….
I managed to clean mine up over the weekend, & it’s not too bad now. I may still be able to use Yellow Submarine for a sound track Big Smile
MtnDon wrote:
C’est fini!!
WooHoo! That looks great! Beer
What a lovely talking piece to have on a table/desk, etc.
Congrats, Don!
MtnDon
MtnDon's picture
Yessir! That is one of it’s intended uses. Thank you.
I have several USB power heads and cords right at hand there so keeping a charge will be easy. I put the store bought goose neck LED lamp away.
MRsDNF
MRsDNF's picture
Good to see the finish Don. How did you do the radius’s on the corners? They look so neat.
CRX
CRX's picture
Cool Thumbs Up
Looks smaller & better than I thought it was now seeing it next to the laptop, what are the dimensions?
MtnDon
MtnDon's picture
CRX wrote:
… what are the dimensions?
Looking at a side, say the brown wood side with the copper plates, 4-15/16” ( 125 mm) wide x 5-9/16” (140 mm) tall. The block is 2-11/16” (67 mm) thick. The diameter of the original large hole through the block was 3-1/8” (80 mm).
