Plastic box, upgrade to lithium battery charger!
Make three exquisite boxes.
Place the 4056 charging pad in the narrow end of the box.
Put the spring on the other end and do the negative pole.
Put a copper plate as a positive pole in the front end.
Make a charging line.
I changed the inner core of the phone line.
Open two holes in the head,and put the USB cable on the welder.
Cut down a piece of plastic for the indicator light window.
The appearance after putting on is as follow. And the power indicator marks on the above.
Add a charging head to test.
Put in a section of 18650 lithium battery and charge directly.
After charging, the transformation of battery voltage was successful.
For the convenience I made two chargers, which charge 18650 conveniently and quickly.
The production is finished, welcome to discuss.
