ENEDED
551 posts / 0 new
DENGOH
DENGOH's picture
Last seen: 6 hours 55 sec ago
I’ve just sent an email to Vishay. Most likely they won’t reply me with helpful answer though.
On the webpage, Vishay acknowledge there are a lot counterfeits and advise their direct customer to buy from approved distributors only. But I think that doesn’t solve the problem of indirect customers buying a circuits having counterfeit Vishay components.
cool i'll see you when you get there
Texas_Ace
Texas_Ace's picture
Last seen: 1 week 2 days ago
DENGOH wrote:
I’ve just sent an email to Vishay. Most likely they won’t reply me with helpful answer though. On the webpage, Vishay acknowledge there are a lot counterfeits and advise their direct customer to buy from approved distributors only. But I think that doesn’t solve the problem of indirect customers buying a circuits having counterfeit Vishay components.
Let us know what they say, I have not tried contacting Vishay, I got fed up after trying 2 or 3 other companies first lol.
DENGOH
DENGOH's picture
Sure. Beer
DENGOH
DENGOH's picture
Having mosfet fever, so I bought 3 mosfet. Checking the resistance between D and S, they are all non measurable, that means they can be considered completely open. I will use the Infineon mosfet to repair another Haikelite TA driver and put it into my old MT03 12000lm.
And the two Haikelite SIR800 are each about 42Mohm and 55Mohm. This is good indicator it is not open enough.
Two SIR800, BSC009NE2LS5ATMA1, SIRA22DP-T1-RE3, NTMFS4H01NT1G
DENGOH
DENGOH's picture
OMG Infineon mosfet is crazy. Now my old MT03 is the brightest. Much better than Vishay SIRA60.
DENGOH
DENGOH's picture
Was too excited and forgot to mention this.
Both Haikelite TA driver having glowing during off with SIR800 mosfet. They are out of box defect, without extended use.
Both are successfully repaired by swapping with Vishay SIRA60 and Infineon BSC009.
Texas_Ace
Texas_Ace's picture
Yep, that is what I expected. The FET is generally the weak link with this sort of issue.
Good to know you got them fixed!
Agro
Agro's picture
DENGOH wrote:
I finally got my FET replaced with Vishay SIRA60DP just now. The printing on the FET is very sharp compared to the FET used by Haikelite. I highly suspect Haikelite uses fake FET.
It is not leaking faint light anymore. Will continue to monitor.
!{width:88%}https://lh3.googleusercontent.com/wO9jpnwjjnfVS1xl5W55vpU7DtXmVLq3qhznbM...!
I’m very glad that the culprit is confirmed.
I already have a replacement FET (BSC009NE2LS5IATMA1) thanks to Arrow’s free shipping but I need more soldering practice before I attempt the repair.
Scallywag
Scallywag's picture
Last seen: 20 hours 4 min ago
This is good to be aware of. I'm close to pulling the trigger on a MT03 TA. I guess I'll plan on ordering a new mosfet as well
JasonWW
JasonWW's picture
Last seen: 1 week 1 day ago
I don’t think there’s much soldering involved. You need a hot air gun for mosfets.
DENGOH
DENGOH's picture
Ya, FET definitely is the culprit in my two drivers.
I am glad it got sorted out and now I have over 32k lumens with two MT03 left and right. They got hot from cold really really fast. I plan to play with momentary mode side by side.
Thanks to you all who care, for all the help provided to me.
Agro
Agro's picture
Yeah, I’ve got hot air. I just need to reflow quite a few more things before I take on my most expensive light.
DENGOH
DENGOH's picture
That’s the craziest FET. I think you will notice at least 30% boost on brightness.
I didn’t practice, I was afraid of damaging FET with hot air, but it turned out working fine. Hot air temperature was 400c, I tried to complete it within 15s.
DENGOH
DENGOH's picture
Scallywag wrote:
This is good to be aware of. I’m close to pulling the trigger on a MT03 TA. I guess I’ll plan on ordering a new mosfet as well
For modders, it is great light and really easy to open and repair or upgrade.
Agro
Agro's picture
My FET is different from yours.
BSC009NE2LS5-I-ATMA1 vs. BSC009NE2LS5ATMA1.
I got the product number from Lexel but now I see that yours has lower RdsOn, higher current rating and lower price. Oh well. Anyway, it surely is a good FET. Smile
JasonWW
JasonWW's picture
The key with hot air is distance. You can set an arbitrary temperature, on the high side, and control the heat by moving it closer or farther. Start off maybe 8 to 10 inches to heat up the FET and everything around it. After a minute or so have your tweezers ready and move your nozzle closer to the FET. Hopefully the solder will go liquid in about 10 seconds. Then lift it out of the way.
I usually remove the old solder with an iron and solder braid. Then I add flux and fresh leaded solder to the pads. Then add more flux and set the FET on top.
Then same thing, heat from a distance for a minute or so, then move in close looking for the FET to drop into position. Then I push it down with tweezers and remove the heat. Once cool, I clean any flux residue and it’s just like factory.
I’ve only done a few, but they came out perfect. If anyone has any more tips, I’m interested.
Agro
Agro's picture
Thanks JasonWW. Will keep your hits at mind until I’m ready to do the repair. Smile
JasonWW
JasonWW's picture
You can also practice on junky circuit boards to get a feel for it.
wstrachan
Last seen: 6 months 6 days ago
Interested!
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
JasonWW
JasonWW's picture
wstrachan wrote:
Interested!
Your saying your interested in buying one and want the coupon code?
After all that has been said? Lol
I guess Freeme is still doing coupons for this light, I’m not sure. This thread was started in 2017. Just keep in mind there is a small chance you’ll need to replace the big FET on the driver.
DENGOH
DENGOH's picture
I see. An extra “I”, yours is faster FET I guess.
Can you take picture on the FET when you got it, would like to see what’s the printing on the chip?
DENGOH
DENGOH's picture
Now they can sleep in total darkness inside my camera bag that I have betrayed. Cool
DENGOH
DENGOH's picture
Anyone knows is there a way to reprogram the low voltage protection through the firmware?
If it can’t be done through firmware, may I know which resistors to change and how is the calculation for resistor values?
Texas_Ace
Texas_Ace's picture
You can adjust it in the firmware, although it can be tricky as you will need to use TK’s voltage hex file to figure out the right settings and then test it at a few voltages.
Is the voltage reading off? It is common for it to be off 0.1v, even 0.2v is not something I would worry about since there is a fair amount of margin for error on this.
DENGOH
DENGOH's picture
Ya, one driver battery check is out by 0.2v. The LVP seems to kick on prematurely. So I thought if user can do manual offset via clicks on buttons.
Texas_Ace
Texas_Ace's picture
Sadly no calibration is possible via the menu, only in the firmware code.
You can adjust the voltage divider resistors to correct the voltage but that is not always easy.
Although it may actually be working just fine. If you are running it in a high mode the voltage in the cells will sag lower, causing the LVP to kick in but when the load drops the voltage increases, which is why you get higher readings without the light being on.
Tom E
Tom E's picture
Last seen: 9 hours 56 min ago
It's something I want to add (i.e. voltage calibration), looked at it briefly, little involved but I'm getting, really really desperate to get this feature in for both voltage and temp. NarsilM uses voltage levels to the 100ths, not 10ths, so the data entry should be 2 digits - I want to make it work just like other config settings. In 100ths you can get it very accurate. In the firmware it's roughly 10 to 40 for 0.12V to 0.40V (usallly tighter from 0.20V to 0.36V or so) addition for taking the diode drop into account. I do this manually by checking batts at differing levels, again to 100ths precision.
In theory, I believe the diode I use supposed to be a ~0.24V voltage drop.
The variation from piece to piece is probably because of variances in the diodes and MCU's. I'm not really sure though if the bulk of variance if from driver design to driver design, or more from piece to piece. It's hard for me to tell because I generally reflow one driver at a time when I need it, and almost never use the same driver back to back.
To me, the ideal UI for this would be press&hold while in voltage display (blinking out) mode, the it goes into config, for data entry of 0.35V, blinks twice, then you click 3 times, stop, then it blinks twice again to confirm, then you click 5 times, and it blinks the final confirmation blinks - 4 quick ones. It should feel exactly like entry of other config settings.
Should work the same way for temperature calibration of entry of a 2 digit celsius temperature.
Texas_Ace
Texas_Ace's picture
Tom, you might look at the Anduril code, I think TK has managed to get at least some of this implemented already. It would be cool if we could merge anduril and Narsil. They both have pros and cons and I think they could be blended together really well to get all the pros without the cons.
Tom E
Tom E's picture
Yes, somewhat. Unfortunately I really don't like the turn OFF delay in Anduril - last I heard from her there's no fix for it, and not sure if she will fix it based on her response - it's not important to her, least not as important as it is to me. Actually I'm surprised no one else noticed or complained about it, or if they did, I didn't see it. It's something very basic with the most rudimentary action of the UI -- turning off the light, and it has an annoying delay... I don't get it.
If this delay is not fixed, I'm not gonna give up on NarsilM.
When I checked Anduril source code for voltage monitoring, I don't think she's using the full resolution that DEL developed and I brought into NarsilM, so she stuck with the old method with resolution in 10th's not 100's. Forgot the details, but DEL used higher resolution AtoD on the reading. He shared his code and I like it - dropped it right away into Narsil.
JasonWW
JasonWW's picture
Fireflies is the only company using Anduril so far. I haven’t followed their lights, but it seems Anduril is well liked.
The Sofirn 21700 C8F has a little bit of a turn off delay. It bugs me a little, but not too bad. I do prefer the instant off of Narsil, though.
I haven’t tried Anduril yet, but I want to.
