I'm looking for a budget flashlight that I can use to shine a light on small objects for photography purposes. I want something with high CRI to accurately render colors. When it comes to emitters, I guess that means Nichia 219C or something similar? Or are there better emitters out there for this purpose? Can you guys recommend some flashlights for me to consider?
I don't know if a more focused or more floody beam would be better for this purpose. I want something to only light up the subject and not the surroundings, but on the other hand I know that very focused lights can produce more harsh results.
I don't care about cell format, although I do have plenty of 18650, AA, and AAA cells around.
If it doesn’t have to be a flashlight, I recommend the Viltrox LED panels. The big surface area helps photography as there’s no strong shadows like from a point source of light (of course you can ceiling bounce a powerful flashlight for a good even lighting). They’re very cheap and can be run on 7-12 volts via a Sony battery interface or DC 5.5×2.1mm plug. Stick two 18650s in a series holder and wire them to a DC plug or use any 9-12V wall wart from one of your battery chargers.
Here’s some measurements:
https://imgur.com/a/1fhBU
If you need a flashlight, the Astrolux MF01 is hard to beat for the output, high CRI and good price.
Funny you mention this. I actually purchased this Viltrox panel about a month ago, but I guess I don’t know how to use it correctly. The light spread is very wide, which ends up lighting up not only my small subject but also my background, which is what I am trying to avoid. Unless I am doing something wrong…
Thanks, but that’s huge. I need just a few lumens, not 12,000.
You need deflectors to cut off the light on the sides you don’t need/want it.
Do you see those dark panels in the center of the image ?
One side is white (reflective) the other side is black matt to cut off a part of a light source placed behind. Here they are using the reflective side.
You can hold a panel between your subject and the light source. Adjust the distance of the panel to have a sharper or blurrier edge of the cut off.
You also need to bring the light source very close to the subject in relation to the background to keep the background dark.
I’ve tried many torches for this sort of photography, but I found none of them are any good shone straight at the subject. What looks like a uniform beam profile to the eye is not to the camera. None of them that I have tried, where a 1/2 or 1/4 stop matters.
I have modified a few with heavy diffuser film on the front, and they are a lot better, but still not good.
Bouncing back into a softbox or other improvised thing works better.
Then you have the colour balance to look at. Maybe “Nichia 90 CRi” are the best, but I’ve tried a few of them and they still fell short.
Really the flat panels (with two types of LEDs, mixed) offered by the serious companies for this application seem to work much better for me, together with careful white balance, and then colourchecker calibration.
It was much easier, and warmer, just using photofloods (prehistoric). Or domestic halogens.
LEDs don’t emit a continuous spectrum. If you are lucky it might roughly match the RGB filtering on your camera. If not, it won’t and you will be chasing your tail.
How long are your exposures? For long exposures flashlights are OK as you can wave them around to even out the light. Diffusers help to. For short exposures you would be better off with dedicated lighting panels or flash units.
Recent Reviews: Best Flashlights for Light Painting Photography 2022 // Battery and Charger Buying Guide 2022 // Acebeam E70-AL CRI95+ // Antsonamelon RGB Critter 2.0 // Convoy S21E 519A // Wurkkos TS25 // Olight Marauder Mini // Noctigon KR4 // Convoy S21F //
Affiliate links: Olight AU // Olight USA // Nealsgadgets // Acebeam // Antsonamelon
Instagram: @stephenk_lightart
Have you considered the JAXMAN E2L high CRI version:
LG high CRI LED E2L flashlight-maybe this LED is unknow to everyone..
Should be 90 CRI at 5000K. Looks very promising.
I’d rather use my flashlight around the house than turn on the lights.
The more I think about it, the more I’m leaning toward short exposures so that I can eliminate most of the ambient lighting and make the background look very dark/black.
I did play around with the Viltrox panel and got OK results. Bringing it much closer to the subject did help. I just need to find a piece of reflective material to put on the opposite side of the panel to help bounce a little bit of the light back to help light up the subject from the other side, too. I suppose my photo umbrella lined up with the reflective fabric might work.
I do have a remote camera flash as well, and it does work, too (bounced back through umbrella). I was just wondering if there was anything better…
I currently have a project going for a pocketable macro rig that consists of a Canon S120, a homemade extension tube, and a Marumi 200 + Raynox 250 + Raynox 150. For light I use two Nitecore TIPS and a Convoy S 2+ with a 18350, mounted with cable ties onto a disfigured metal spatula I stole from the kitchen. The lights all have diffusers – the two TIPS the head of a plastic deep-sea fishing squid (9” ), and the Convoy a screw-on cap from Jabsco that I found in a chandlery ( I can find the exact part number if you’re interested). One Tip is a 219, the other is not. The mix of light is balanced and easily managed with your WB setting in camera, or via Temperature later in PP.
With the lighting I can keep the shutter speed high, f/stop low and use a reasonable IS O of 800 or lower. I balance the rig on a stick I use for beating back errant goats and stuff. Simple but effective.
Here are a few samples:
A bush cricket
A green-eyed horsefly
The Marmalade hoverfly
A green shield bug
A muscadae fly
A southern emerald damselfly
A European paper wasp
A Common darter
I can post you some pics of the rig with the lighting rack if you need details. Hope this helps! And thanks for the opportunity to post some insect pics
Excellent photos!
Please do. I’m curious how you have it all set up.
Okay – no worries – it will be tomorrow probably, I’ll send them via PM……
Have you checked out the Lume Cube? Can be triggered by other flashes (by light) but not by radio triggers. Apparently is quite cool white and not high CRI. Can also be controlled from smart phone via Bluetooth.
Looking forward to seeing your rig.
I’m off to check out your flickr page. Hoping to see a few of those goats you mentioned.
You may want from clemence Nichi 219 9080 LEDs
The better CRI will be good for photography
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: overview of sizes and types
DD+AMC based drivers Anduril or Bistro OTSM 12-24mm, S42, 24-30mm L6, Q8, MF01(S), MT03, TN42
Anduril or Bistro 8A buck driver for 20-30mm, MF01/02/04, TN40/42, Lumintop GT, MT09R
UVC and UVC+UVA drivers
programming key
Remote switch tail DD board with FET
Aux boards:
Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
thanks for posting those images, the colors and detail are amazing!
I would be curious to see how a couple of tips contribute to your lighting
I would of though the pics were taken during the day.:-)
Those photo’s are amazing, please feel free to post up more!
Sweet photos, DrHook59!
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread // raccoon's light reviews
Thanks for the compliments guys
I couldn’t help myself, sorry. And as there seems to be some interest in the rig I’ll post the pics here later this morning. It’s FUGLY, I’m warning you.
goshdogit – you’ll find my flickr page here if that helps.
jon_slider – if you visit the page above you’ll see the pics in better resolution if you want to look at them in detail. Be aware though that these are taken on a compact camera, so the IQ is not great.
Okay, sorry for the delay. Here are some photos of my S120 rig. I forgot to mention that the Convoy S2+ has a triple XP from kiriba-ru in it. This gives a whack of light when one needs it.
The flexible arms the NiteCore TIPS are attached to are these. I really want to get a couple of the new clips for the TIPS and ‘sugru’ them to the flexible arms instead and then I’ll be able to take the TIPS on and off for charging much easier. As you can imagine the TIPS can be made to shine anywhere – up, side, above, under, behind and all
Interesting setup, DrHook, although I’m not sure this would accomplish what I’m trying to do. I want black/unlit background in my photos. I suppose it’s more about the positioning of the lights than anything else.
Pete, easy enough to do. Find an empty cardboard box and paint the inside of it black, and put a plinth in there to put your objects on and paint that black too. Or line it with black foam board, that’s very effective too.
A home-made one of these, but basically free
I can’t believe you get photo’s that look THAT GOOD out of that Dr Jekyl setup, amazing and unbelievable innovation!
Impressive lighting setup!
Seriously though, there is nothing existent on the market for this camera – you have to make anything you want, sigh. And as I don’t have much more than a hacksaw and a drill, I had to be inventive, especially as I wanted to keep things ‘pocketable’
As it happens, I use plastic fishing squids for all sort of small diffusers, and I have quite a collection of bastardised cutlery now, in a box. I’m done for if the head chef ever takes a stock count
I know I’m in good company though, as if you look through a macro forum you’ll see similar contraptions made out of all sorts for more expensive cameras. And when it comes to diffusers, the amount and breadth of imagination knows no bounds! Plus, you get exactly what you need.
I think it’s the Mark IV BLF set-up. Been around for ages. Standard practice amongst all good macro people.
Honest
cough
What advantages do you hope to get by using LED lighting? (vs. tungsten)
If accurate color rendering is important for your work, you might be disappointed by the results you get from using even the highest CRI LEDs.
In a remote shoot with no plug-in power, LEDs definitely have some advantages (heat, run time, cost of flashlights).
But if you can plug in to a wall outlet, no LED is going to achieve higher color rendering than a 50¢ incandescent bulb.
If you decide to go the flashlight route, borrow an old school halogen flashlight and compare the results
Or just shoot in RAW and adjust colour balance in post
Cheers David
Nothing to see here folks, move along...
I admit to doing none of that. All my shots are simply adjusted with whatever White Balance setting is needed during shooting.
That’s if it is needed anyway, and half the time I don’t think it is. I must have a colourblind camera,
You cant photoshop CRI on a non CRI light source
White balance cant fix it, a CRI light wih more red illuminates only red parts, more amber, cyan also come in play with high CRI light source the same way
[Sale]
programming key
Aux boards:
I was about to mention that. You beat me to it.
