High CRI flashlight for photography?
I'm looking for a budget flashlight that I can use to shine a light on small objects for photography purposes. I want something with high CRI to accurately render colors. When it comes to emitters, I guess that means Nichia 219C or something similar? Or are there better emitters out there for this purpose? Can you guys recommend some flashlights for me to consider?
I don't know if a more focused or more floody beam would be better for this purpose. I want something to only light up the subject and not the surroundings, but on the other hand I know that very focused lights can produce more harsh results.
I don't care about cell format, although I do have plenty of 18650, AA, and AAA cells around.
If it doesn’t have to be a flashlight, I recommend the Viltrox LED panels. The big surface area helps photography as there’s no strong shadows like from a point source of light (of course you can ceiling bounce a powerful flashlight for a good even lighting). They’re very cheap and can be run on 7-12 volts via a Sony battery interface or DC 5.5x2.1mm plug. Stick two 18650s in a series holder and wire them to a DC plug or use any 9-12V wall wart from one of your battery chargers.
Here’s some measurements:
If you need a flashlight, the Astrolux MF01 is hard to beat for the output, high CRI and good price.
Funny you mention this. I actually purchased this Viltrox panel about a month ago, but I guess I don’t know how to use it correctly. The light spread is very wide, which ends up lighting up not only my small subject but also my background, which is what I am trying to avoid. Unless I am doing something wrong…
Thanks, but that’s huge. I need just a few lumens, not 12,000. :slight_smile:
You need deflectors to cut off the light on the sides you don’t need/want it.
Do you see those dark panels in the center of the image ?
One side is white (reflective) the other side is black matt to cut off a part of a light source placed behind. Here they are using the reflective side.
You can hold a panel between your subject and the light source. Adjust the distance of the panel to have a sharper or blurrier edge of the cut off.
You also need to bring the light source very close to the subject in relation to the background to keep the background dark.
I’ve tried many torches for this sort of photography, but I found none of them are any good shone straight at the subject. What looks like a uniform beam profile to the eye is not to the camera. None of them that I have tried, where a 1/2 or 1/4 stop matters.
I have modified a few with heavy diffuser film on the front, and they are a lot better, but still not good.
Bouncing back into a softbox or other improvised thing works better.
Then you have the colour balance to look at. Maybe “Nichia 90 CRi” are the best, but I’ve tried a few of them and they still fell short.
Really the flat panels (with two types of LEDs, mixed) offered by the serious companies for this application seem to work much better for me, together with careful white balance, and then colourchecker calibration.
It was much easier, and warmer, just using photofloods (prehistoric). Or domestic halogens.
LEDs don’t emit a continuous spectrum. If you are lucky it might roughly match the RGB filtering on your camera. If not, it won’t and you will be chasing your tail.
How long are your exposures? For long exposures flashlights are OK as you can wave them around to even out the light. Diffusers help to. For short exposures you would be better off with dedicated lighting panels or flash units.
Have you considered the JAXMAN E2L high CRI version:
LG high CRI LED E2L flashlight-maybe this LED is unknow to everyone…
Should be 90 CRI at 5000K. Looks very promising.
The more I think about it, the more I’m leaning toward short exposures so that I can eliminate most of the ambient lighting and make the background look very dark/black.
I did play around with the Viltrox panel and got OK results. Bringing it much closer to the subject did help. I just need to find a piece of reflective material to put on the opposite side of the panel to help bounce a little bit of the light back to help light up the subject from the other side, too. I suppose my photo umbrella lined up with the reflective fabric might work.
I do have a remote camera flash as well, and it does work, too (bounced back through umbrella). I was just wondering if there was anything better…
I currently have a project going for a pocketable macro rig that consists of a Canon S120, a homemade extension tube, and a Marumi 200 Raynox 250 Raynox 150. For light I use two Nitecore TIPS and a Convoy S 2+ with a 18350, mounted with cable ties onto a disfigured metal spatula I stole from the kitchen. The lights all have diffusers - the two TIPS the head of a plastic deep-sea fishing squid (9” ), and the Convoy a screw-on cap from Jabsco that I found in a chandlery ( I can find the exact part number if you’re interested). One Tip is a 219, the other is not. The mix of light is balanced and easily managed with your WB setting in camera, or via Temperature later in PP.
With the lighting I can keep the shutter speed high, f/stop low and use a reasonable IS O of 800 or lower. I balance the rig on a stick I use for beating back errant goats and stuff. Simple but effective.
Here are a few samples:
A bush cricket
A green-eyed horsefly
The Marmalade hoverfly
A green shield bug
A muscadae fly
A southern emerald damselfly
A European paper wasp
A Common darter
I can post you some pics of the rig with the lighting rack if you need details. Hope this helps! And thanks for the opportunity to post some insect pics :smiley:
Excellent photos!
Please do. I’m curious how you have it all set up.
Okay - no worries - it will be tomorrow probably, I’ll send them via PM……
Have you checked out the Lume Cube? Can be triggered by other flashes (by light) but not by radio triggers. Apparently is quite cool white and not high CRI. Can also be controlled from smart phone via Bluetooth.
Gorgeous photos! My favorite is the ‘common darter.’
Looking forward to seeing your rig.
I’m off to check out your flickr page. Hoping to see a few of those goats you mentioned. :smiley:
You may want from clemence Nichi 219 9080 LEDs
The better CRI will be good for photography
thanks for posting those images, the colors and detail are amazing!
I would be curious to see how a couple of tips contribute to your lighting
I would of though the pics were taken during the day.:slight_smile:
Those photo’s are amazing, please feel free to post up more!
Sweet photos, DrHook59!
Thanks for the compliments guys :smiley: I couldn’t help myself, sorry. And as there seems to be some interest in the rig I’ll post the pics here later this morning. It’s FUGLY, I’m warning you. :smiley:
goshdogit - you’ll find my flickr page here if that helps.
jon_slider - if you visit the page above you’ll see the pics in better resolution if you want to look at them in detail. Be aware though that these are taken on a compact camera, so the IQ is not great.
Okay, sorry for the delay. Here are some photos of my S120 rig. I forgot to mention that the Convoy S2+ has a triple XP from kiriba-ru in it. This gives a whack of light when one needs it.
The flexible arms the NiteCore TIPS are attached to are these. I really want to get a couple of the new clips for the TIPS and ‘sugru’ them to the flexible arms instead and then I’ll be able to take the TIPS on and off for charging much easier. As you can imagine the TIPS can be made to shine anywhere - up, side, above, under, behind and all :slight_smile:
