WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
1038 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 3 hours 15 min ago
Looks like definitive proof Clemence.
I haven’t opened my 2019 RRT-01 to compare the driver to the old RRT-01’s, but I suspect they are probably the same design, but with a bit more current going through.
Back when the original RRT-01 was released, outputs were a lot lower and temp sensors on flashlights were rare. Today, outputs are higher and temp sensors are more common.
It sounds like the driver simply hasn’t been updated with a temp sensor or low voltage protection. That’s too bad.
It’s still a great light though, but just be aware when you use it that this one is lacking some of the safety features found in other lights.
clemence
clemence's picture
Last seen: 1 year 4 months ago
It doesn’t have LVP because it designed to also work with CR123. Protected 18350/16340 and temporary max mode are mandatory for this RRT01.
[Clemence]
Firelight2
I don’t think a protected cell is mandatory.
Just don’t overuse the light or leave it tailstanding.
clemence
clemence's picture
I mean for safety measures. Keeps out of reach of children too
jon_slider
jon_slider's picture
Last seen: 9 hours 13 min ago
clemence wrote:
Keep out of reach of children
definitely!
For Children, a High CRI HDS is safer than an RRT-01, because
HDS are not 18350 compatible,
are limited to 200 lumens,
have a 33% auto step down at 40 seconds,
and auto shut off at 3.0v
Preposterous Proposition Warning:
A resident of the State of California has determined that the RRT-01 is not suitable for children.
Responsible use of 18350 LiIon flamethrowers requires an “intelligent” adult operator.
Firelight2
I don’t think I’d want to hand a child a nearly $300 HDS flashlight either.
Safe for the child maybe. Safe for my wallet no!!!!
Child can make do with a $3 light from the local store.
xevious
xevious's picture
Last seen: 5 days 1 hour ago
No high powered flashlight is safe for a child. All they need to do is point it at their eyes and try to brave the light… leading to retinal damage.
-X3-
-X3-'s picture
Last seen: 2 weeks 4 days ago
For anyone interested, here is my review of the RRT01
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
jon_slider
outstanding review, thanks for the great photos too
and now Ti ala CRX
Laissez les bons temps rouler!
http://budgetlightforum.com/node/66975
jon_slider
Differences in the Original RRT-01 and the New Version with Brass pill.
1. The brass pill makes the New Version 1 ounce heavier and 1/8” fatter.
2. No strobe on Original RRT-01. Yes Strobe on New Version.
3. New Version pocket clip is long, past the control ring. Some Originals got short clips, and they can still be bought.
4. New Version is set for higher max power draw.
5. New Version fits 19mm Carclo without modification to the diameter of the optic. Original requires customizing the optic’s diameter.
New Version RRT-01:
Original Version RRT-01:
6. New Version is XP-L, Original is XM-L. They have different reflectors, the Original has rings in the spill beam.
Firelight2
Original RRT-01 / TCR-01 did not require any modification to the Carclo optic to make it a triple. The optic fits perfectly. However, the edges of the star do require a little filing down.
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 1 hour ago
Are you sure about that?
Firelight2
I stand corrected.
Based on that photo I opened up my TCR-01 triple to double-check the optic. Looks like I did modify the optic after all so that it would fit.
However the modification to the optic was extremely simple. All I did was file down about 1/4 to 1/3 of the outside of each of the 3 legs. Basically 5 minutes with a small handfile. None of the rest of the optic needed modification.. just the legs.
pinkpanda3310
Yeh, that sounds about right Beer
I wasn’t sure if maybe the rrt-01 or the optic might’ve changed slightly.
id30209
id30209's picture
Last seen: 19 hours 41 min ago
WTB Titanium 4sevens 2xAA tube
-X3-
-X3-'s picture
Why did he scratched them like this ? It’s ugly no ? Sick
Mine now rocks a 219B and an OP reflector from an Eagle Eye X2R.
I had to grind the outer diameter of the reflector by about 1mm.
I removed the stock centering gasket to allow a better focus, but the beam is not that good…
I might try with a 219C, the old 219B is too cold (I think it’s 5700K)
Tally-ho
Tally-ho's picture
id30209 wrote:
Just found this one
Triple 219B 4500°K…
…150$
id30209
id30209's picture
Tally-ho wrote:
id30209 wrote:
Just found this one
Triple 219B 4500°K…
…150$
!https://media.giphy.com/media/ph6ewybUlGbW8/giphy.gif!
Where???
Tally-ho
Tally-ho's picture
@id30209, check your link >> options >> TRIPLE 219B 4500K
id30209
id30209's picture
OMG! There was only W2 option when i saw it this morning!!!!
Thx for opening my eyes bro!
Tally-ho
Tally-ho's picture
@-X3-, since you live in france, I can throw a 219B 4500°K and a 219C SM4070e in an enveloppe if you give me your address in MP. Can’t do more, I don’t have much left.
id30209
id30209's picture
X3 check your inbox
jon_slider
thanks for sharing the link
I agree it changed during the day
a triple sw45 for 150 cant be bad.. Im impressed
add trits for $75.. and Glow!
Rotary UI
High CRI LEDs
Game Changers
-X3-
-X3-'s picture
Tally-ho wrote:
@-X3-, since you live in france, I can throw a 219B 4500°K and a 219C SM4070e in an enveloppe if you give me your address in MP. Can’t do more, I don’t have much left. !https://forum-images.hardware.fr/images/perso/spamafote.gif!
That’s a lovely offer, PM incoming
-X3-
-X3-'s picture
My 2019 version :
SST20 3000K, triple MCPCB from KD (1mm thick) and their optic (really smooth beam), plus a small alu spacer that I made today at work.
I had to add some length to the stock wires, but the good news is that the stock pill already have a 4mm hole right in the center.
It’s not waterproof anymore, I like when the optic sits flush in the bezel but it’s doable with an o-ring too.
I love it already.
Oh, it does 600 lumens on the highest mode too… not too shabby for a 95CRI 3000K source !
(the precedent LH351D with stock reflector was about 470 lumens, talk about low current efficiency !)
jon_slider
beautiful work!
thanks for the photos and info about LED options, parts, and optics you used
you could almost build a kit, or people could copy your example, if they had a few specs for the spacer.. etc
http://budgetlightforum.com/comment/1501366#comment-1501366
X3 wrote:
Mine got a 4000K SST20, then a 5700K 219B with an OP reflector, then a sliced LH351D with the stock SMO reflector and now a triple 3000K SST20…
can you line up some of those LEDs so I can see what they look like?
iphone, daytime, white printer paper:
moderator007
moderator007's picture
Last seen: 6 hours 34 min ago
If anyone would like to buy the new model RRT01, Fasttech has a 20% off sale going on that brings the price down to about $49 bucks shipped to the US.
Use code CHERISH for 20% off. https://www.fasttech.com/products/9691168
Nice comparison pics jon_slider Thumbs Up
jon_slider
thats a great price!
and thanks for liking my pics
a couple advantages, or differences, of the New model
1. Strobe
2. Protected 18350 fits
3. unmodified Carclo fits, so people can add a tritium head from Andy
New model RRT-01 on left:
note slight tribute resemblance to McGizmo PD
maybe your little cnc shop or RPM will offer a trit bezel for the new and original RRT-01’s
and Big Hope that a Titanium Version of the Original RRT-01 is re-released, with tritium fins… in my dreams.. lol
(factory trit precedent: Sunwayman Ti Dream)
I started a trit bezel poll here, for the Jetbeam Rotaries:
http://budgetlightforum.com/node/67361
dmsoule
Last seen: 1 week 7 hours ago
moderator007 wrote:
If anyone would like to buy the new model RRT01, Fasttech has a 20% off sale going on that brings the price down to about $49 bucks shipped to the US. Use code CHERISH for 20% off. https://www.fasttech.com/products/9691168 . Nice comparison pics jon_slider Thumbs Up
Maybe flash sale is over? Coupon code invalid, but current price is $55.67 which is still very good.
Leif
Leif's picture
Last seen: 2 months 1 day ago
M4D M4X has a code for this light, I cannot say the price. See his thread for details, or just message him.
This forum may contain nuts.
No animals were harmed in the creation of this post.
Be nice to people. It annoys them no end.
