WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
1038 posts / 0 new
Coppet
Coppet's picture
Last seen: 11 months 1 day ago
Thanks to Jon_Slider, through him I got my first old RRT-01 and also thanks to M4D M4X for the money saved when buying the new 2019 RRT-01 Thumbs Up
Both are now converted to Nichia 219C 4000K and I am very happy about these two jewels!
Woody
Woody's picture
Code works for me – make sure you use CHERISH without any space at the end.
-X3-
-X3-'s picture
Last seen: 1 week 5 days ago
So I replaced the clip on my 2019 RRT01 by a shorter one, which is far better.
It’s the same as the pic just above my post, it comes from an Enogear SS 11 flashlight…
Does anyone know where I could source a spare one ?
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
jon_slider
jon_slider's picture
Last seen: 1 hour 21 min ago
yes, thanks to toddcshoe:
http://budgetlightforum.com/comment/1509719#comment-1509719
-X3-
-X3-'s picture
Thank you jon_slider !
moderator007
moderator007's picture
Last seen: 1 hour 42 min ago
With the help of BanL (Thanks BanL) I finally got a variety of reflectors. After trying several different reflectors from Fasttech that didn’t fit, I even cut one down on the lathe to fit but was worse than the stock reflector my KD shipment finally came in. I now have two reflectors here that drop right in to original RRT01 with no modifications.
The both produce a very nice beam compared to the original reflector. I have only tested them using a LH351D shaved dome led but I don’t expect them to be any different with a 3535 led. Nice hotspot with even spill and no visible rings.
Reflector #1 being slightly larger in diameter (19.4 mm in diameter).
http://kaidomain.com/S021514-19_4mm-D-x-13_4mm-H-OP-Aluminum-Reflector?s...
Reflector #2 slightly smaller in diameter (19.3 mm in diameter).
http://kaidomain.com/S023424-19_3mm-D-x-13_4mm-H-Light-OP-Aluminum-Refle...
They look identically to my eye but when measured KD list the right dimensions, one is .1 mm bigger than the other.
They are OP reflectors but are very fine ripples, barely noticeable.
To me with the shaved LH351D the smaller #2 reflector has a slightly better beam but ever so lightly. It could be it just looks better with the shaved LH351D.
There not that expensive so it might help to order both and see which one works best for you.
The best thing is they drop right in with no rings.. Thumbs Up
jon_slider
moderator007 wrote:
With the help of BanL (Thanks BanL) I finally got a variety of reflectors. After trying several different reflectors from Fasttech that didn’t fit, I even cut one down on the lathe to fit but was worse than the stock reflector my KD shipment finally came in. I now have two reflectors here that drop right in to original RRT01 with no modifications. The both produce a very nice beam compared to the original reflector. I have only tested them using a LH351D shaved dome led but I don’t expect them to be any different with a 3535 led. Nice hotspot with even spill and no visible rings. Reflector #1 being slightly larger in diameter (19.4 mm in diameter). http://kaidomain.com/S021514-19_4mm-D-x-13_4mm-H-OP-Aluminum-Reflector?s... . Reflector #2 slightly smaller in diameter (19.3 mm in diameter). http://kaidomain.com/S023424-19_3mm-D-x-13_4mm-H-Light-OP-Aluminum-Refle... . They look identically to my eye but when measured KD list the right dimensions, one is .1 mm bigger than the other. They are OP reflectors but are very fine ripples, barely noticeable. To me with the shaved LH351D the smaller #2 reflector has the a slightly better beam but ever so lightly. It could be it just looks better with the shaved LH351D. There not that expensive so it might help to order both and see which one works best for you. The best thing is they drop right in with no rings.. Thumbs Up
Great info on an alternative reflector for the Original RRT-01 to help eliminate rings in the beam
I will go ahead and order some to try out.
Thank you moderator007 for your efforts and generous sharing of information
a friend reports his stock reflector in an Original RRT-01 does not have a problem with rings in the beam using a 5000k 219c, but I certainly do have a problem with a 219b in an original RRT-01 w original reflector
I lent the Original RRT-01 w 219b to a friend, and he noticed the rings too, so Im really looking forward to trying the alternate reflectors.
It opens up some better possibilities for a run of Single N219b LED modded Original RRT-01.
woohoo!, going shopping Smile
Done! ordered 3 of each…
contactcr
Last seen: 2 days 8 hours ago
Awesome thanks for doing this. Ordered!
Geuzzz
Geuzzz's picture
Thanks! Ordered.
shirnask
shirnask's picture
Last seen: 47 min 51 sec ago
Thanks! Ordered
-X3-
-X3-'s picture
Now that I’ve used mine so much, I wish Jetbeam would make a 18650 body for it…
I thought about modifying mine with a lathe to add so length in the narrowest part of the original tube but I’m afraid of ruining it…
pinkpanda3310
pinkpanda3310's picture
Last seen: 11 hours 57 min ago
Niteye eye15… Question
-X3-
-X3-'s picture
Well it’s discountinued, plus I’d prefer to keep the RRT-01 and just have triple the runtime…
Thanks anyway !
pinkpanda3310
But if you could find one I’m sure it’ll screw right on to the rrt-01 head Thumbs Up unless you mean the new rrt-01 Oops
jon_slider
these tubes are made of UnObtanium:
yes, Eye15 legos with Original RRT-01 and Eye10, and TCR-1
X3 has the New Phat Head version, so needs to manufacture a new tube
or a custom adapter for the New Phat Head to fit something like the DSpeck UBH
http://www3.sympatico.ca/d.speck/UBH-Infopage/
Archibald Tuttle
Last seen: 1 year 9 months ago
For anyone who wants to run an 18650 with your original RRT-01: a Crelant 7G3CS battery tube fits nicely onto the original RRT-01’s head. Gives the RRT-01 more runtime with a lockout clicky. Overall length is roughly 120mm, IIRC . Anodize color will be off, but I use my lights for more than photo-ops.
Cheaper and much less time consuming than taking to the lathe and CNC.
The light lends itself to much improvistion. The screw in lanyard makes adding machined or 3D printed attachments easy as well. On a 3D printer, I made a twist off RRT01 lanyard cap for father-in -law that holds pills and hearing aid batteries Big Smile
moderator007
I’d thought about a adapter that would thread to the head and to the tube, like sunwayman did with the V11R and V10R.
-X3-
-X3-'s picture
Well if I could buy a spare 18350 tube, I would try to mod it but I don’t want to ruin the light at all
djozz
djozz's picture
Last seen: 5 hours 19 min ago
The new RRT-01 tube is built very thin, not much beef for modding is my impression.
Firelight2
Firelight2's picture
Last seen: 18 min 22 sec ago
Incidentally, the threads in the old RRT-01 are compatible with the threads in the Manker E14 / Astrolux S41.
This means you can take an 18650 tube from those lights and lego it onto your old version RRT-01 head to get instant 18650 support.
There also tailcaps available for that thread pitch without without switches on them. So if you want a flat back with no switch it’s possible to do. I just tried it with parts on hand and it worked.
While the threads on those lights are the same as the threads on the RRT-01 head, it should be noted that there are more threads on the Astrolux/Manker tubes. If you want it to be watertight and cover the o-ring on the body tube you may need to shorten the threads slightly by sawing or filing off the top of the battery tube.
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 1 hour ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
The old RRT01 also legos with a Convoy S2 tube, IIRC. But it requires sanding down the tube threads to make it short enough for a good fit. Or dealing with exposed threads and no waterproofing.
Anthon
Last seen: 1 month 1 day ago
Now let’s find where to buy and old RRT01 Big Smile
moderator007
http://www.aushunteronline.com.au/spotlights/torches-accessories/jetbeam...
jon_slider
and here is a replacement reflector for the Original RRT-01
following info courtesy of Coppet:
a replacement lens that also fits 2019 RRT-01
and a black clip option that also fits 2019 RRT-01
-X3-
-X3-'s picture
Lol 138 bucks for an outdated product
pinkpanda3310
Sounds better when you convert to USD. Don’t you feel sorry for us Aussies Crying
-X3-
-X3-'s picture
Oh, those are AUD ? sorry I didn’t see it Facepalm
ANyway, that’s still more or less the price for the 2019 version Tired
Geuzzz
Geuzzz's picture
X3 wrote:
Oh, those are AUD ? sorry I didn’t see it Facepalm ANyway, that’s still more or less the price for the 2019 version Tired
But most of us do prefer the old model.
djozz
djozz's picture
I like the looks of the new model, the old model looks somewhat boring (except the Ti model, but then: the new model in Ti would look even better Big Smile )
Geuzzz
Geuzzz's picture
I find the new model to bulky for EDC and almost double the weight.
