Test/review of TrustFire IMR16340 650mAh (Red-gold)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 hours 25 min ago
DSC_8939
Official specifications:
  • Battery Capacity (Mfg Rated): 650 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 16340
  • Battery Maximum Voltage: 4.2 V
  • Battery Minimum Voltage: 2.85 V
  • Battery Rated Voltage: 3.7 V
TrustFire%20IMR16340%20650mAh%20(Red-gold)-info
This is fairly cheap 16340 batteries that is rated as high current types.
DSC_8937 DSC_8938
DSC_8940 DSC_8941
DSC_8942
DSC_8943
DSC_8944
TrustFire%20IMR16340%20650mAh%20(Red-gold)-Capacity
The discharge curves looks fairly good up to 3A, but the battery cannot handle 5A
TrustFire%20IMR16340%20650mAh%20(Red-gold)-Temp-5.0
TrustFire%20IMR16340%20650mAh%20(Red-gold)-CapacityTimeHours
TrustFire%20IMR16340%20650mAh%20(Red-gold)-Energy
TrustFire%20IMR16340%20650mAh%20(Red-gold)-PowerLoadTime
TrustFire%20IMR16340%20650mAh%20(Red-gold)-TripCurrent
TrustFire%20IMR16340%20650mAh%20(Red-gold)-Charge
Conclusion
The cell is a fairly good high current 16340 cell, but the current specification is way to optimistic.
Notes and links
Comparison to other LiIon batteries
Geuzzz
Geuzzz's picture
Last seen: 1 week 22 hours ago
Looks pretty good. Thnx for testing!
Barkuti
Barkuti's picture
Last seen: 1 hour 59 min ago
The chemistry of these is for sure different to that of the IMR14500 and quite likely from a different manufacturer.
A nice cell in the sea of 16340s.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
FPV
FPV's picture
Last seen: 7 months 21 min ago
thank you for the test. I might pick up a few.
