Serial battery charging with in series TP4056 modules? Sort of YES! :-D
34 posts / 0 new
Enderman
Enderman's picture
Last seen: 2 weeks 9 hours ago
I don’t think you understand.
This is not about trickle charging to maximum voltage.
This is about constant trickle charging that keeps a cell topped off at maximum voltage.
The trickle charging does not stop when the cell reaches max voltage.
There is still current flowing into the cell to KEEP IT at 4.2V.
The harm comes from the fact that it never ends charging and just keeps putting energy into the cell, even though it never goes above 4.2V.
Barkuti
Barkuti's picture
Last seen: 13 hours 9 min ago
Enderman wrote:
I don't think you understand.
This is not about trickle … to KEEP IT at 4.2V.
I fully understand.
Where is the source claiming the trickle charge is what damages the cell?
Is that the actual cause of cell damage, or is it the accelerated aging caused by the high voltage?
As I understand it, the actual cause is the latter.
Cheers Smile
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Enderman
Enderman's picture
I fully understand.
Cheers Smile
https://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
https://batteryuniversity.com/learn/article/how_to_charge_li_ion_with_a_...
https://en.wikipedia.org/wiki/Trickle_charging
https://ecs.confex.com/ecs/224/webprogram/Abstract/Paper23632/B10-1075.pdf
“increase in the thickness of the solidelectrolyte-
interface (SEI) film that formed on the anode
over time because the SEI film formation involves lithium
ion consumption, which reduces the number of mobile
lithium ions in the cell.”
