Jetbeam E20r and E40r
19 posts / 0 new
A-MAC
Last seen: 1 year 1 week ago
These were sent to me by FastTech for review.
Two more winners from Jetbeam. The E20r and E40r would be a great EDC light to add to your rotation. Both are well built and provide pleasing beam patters and tint. They both come packaged similarly with a lanyard, USB charge cord, extra o-rings, instructions and warranty card with the E40r also coming with a nylon belt sheath. Both use the same micro USB charge port built into the head, opposite the electronic side switch they both share. They come in a very cool dark gray color with a blue accent which adds just a little POP! to my mostly black/silver rotation without scaring me too much . Both share the same sturdy pocket clip/lanyard attachment though they attach differently, which I will cover later.
That’s it for the similarities, now onto the differences. Starting with the E20r. Odviously its much smaller, taking a single rechargeable CR123 cell, which Jetbeam provides. To attach the pocket clip to the E20r you unscrew the retaining ring, which is separate from the light and does not open the battery compartment, from the tail end of the light. You slip the clip over the body of the light and reinstall the retaining ring. Normally I am a fan of bolt/screw on pocket clips. A flimsy pocket clip will break a light for me. The method used on the E20r provides a very secure feeling. The pocket clip is sturdy and the method of attachment is sturdy with no negative give or spinning on the body. The UI on the E20r is slightly different than the E40r, and it takes a little getting used to. On the E20 you press the side switch for slightly longer than usual (long press) to activate the light. You do not press and hold until the light activates, doing so will put you in beacon mode. When on a short press advances mode and a double tap gets you to strobe. Double tap from off gets you directly to strobe and the light has mode memory so you have direct access to any mode you want. The E20r also adds a magnet to the tailcap that isn’t present on the E40r.
The E40r is enough different that its worth mentioning. It takes a different battery, its an 18650 light. You get two extra o-rings with the E40, my guess is that is because the pocket clip fits under the tail cap, you need to remove the o-ring to install it and there in lies my problem with the E40. With the pocket clip fitting under the tail cap it allows the cap to spin easily. With the E20r I can position the clip where I want it, which has more to do with being able to position the on-switch where I want while clipped in my pocket, the E40r doesn’t allow me to do that because it moves so easily. The other difference, which might be better, comes when activating the light. With the E40r you press and hold the switch until the light activates, where as with the E20r you just press slight longer than normal. This gives you a definite point of reference, you push until the light turns on instead of just guessing.
The run times for these two are on par with the back of the box with the E40r giving you longer run time due to cell size. It’s kind of weird that the modes (low, medium, high, turbo) aren’t the same between the two lights until you get to Turbo. I would have expected for low, medium and high to be the same with Turbo being at a little higher output for the E40r. Overall though fit, finish and presentation are good. If you are adding it to an EDC rotation you will just need to get accustomed to a slightly different interface then you may be used to but that’s not a big deal. Both are priced similarly, around $60 and for that much you get a complete turn key EDC light package. Everything you need to carry the light and replenish it when the time comes is in one box. Overall either is a great light that will provide reliability and enough light to get the job done.
A0617173_5866_4_EAA_BF95_84152_FCC278_B
4234170_E_6_C98_4529_8129_2_C0388_AC4_C5_F
B6_A7_F4_F1_F523_42_AB_94_AB_234_CC8_E51194
4827_B167_441_D_426_B_A153_4_B2990_A2_FEEE
8405_D3_B5_0250_45_A4_B782_62_A190314_B39
78_AC1_E00_1_C9_D_4428_9_F4_B_9_B5127_BD0452
6_FC95_F72_6_BF9_4389_BCC1_CB638_B282776
73_ECFFAD_5643_424_A_BE75_36894_CD17_A32
3_F229_E98_36_FF_4_BC0_AC55_856553524_CB5
A81_FDA12_94_B9_486_D_9_CF2_FA597_C9_B1_DCA
48_CB9_E5_F_CDFB_4055_9050_A03_ECAD45759
0_D8_C0980_DAE4_4422_85_E1_EA4517843951
67_D2_A077_0_B15_4770_AB31_7_E50_CD0_B9_A26
4_E600703_22_EA_4_E04_B332_C0_A0_F04_C4_BCF
E86_BC18_A_77_FE_44_A5_9_A9_D_7323_B8_E4_B08_D
14_A4_B322_91_B8_415_F_82_C5_F1290985_A998
B533_C413_5132_48_F8_8_AD6_AC17103_D26_F6
FC2_D0670_5244_4_CA6_A3_E7_C504_F2_A72_FBD
C0005427_2_B95_49_C6_9234_B0_F3666486_A4
0_CDF8995_2077_4592_9_A87_4_A3029791_A57
758381_AA_6278_4_BBA_95_EE_6_BC450_A6_F350
9_D10_BCA9_13_E0_4970_8638_9_E4891_A6910_B
22008606_2_E78_4_ACC_852_B_D9536_A0_AFDC4
11424_BA1_2246_40_C2_8_DA6_0_C5_AB71_D07_E4
48_BDBD7_F_C47_F_4347_83_B8_D0_B6361540_E8
E15179_D2_CE8_A_4_AA4_821_E_CA3_CB669_AB2_D
4_AB87_E07_3_D77_4_D6_E_B330_C3_DDC4465_D1_B
1_B5_D307_A_1339_4115_958_A_DB0178_A0_F711
1_C8_BEDDC_E6_D0_433_C_9_AD9_1_D0_E35_E78221
beam0
beam0's picture
Last seen: 1 day 4 hours ago
You wrote:
“On the E20 you press the side switch for slightly longer than usual (long press) to activate the light. You do not press and hold until the light activates, doing so will put you in beacon mode.”
The other E20R review states single click for turn on. And a long press from off puts it in lockout (press/hold for 3 seconds – blinks once)
(review about 30 days before yours) http://budgetlightforum.com/node/56422
The company website also shows single click for turn on.
And neither the other review or the company website shows it having a Beacon mode, only Strobe.
http://www.jetbeamlight.com/products_show265.html
Has something been changed?
toddcshoe
toddcshoe's picture
Last seen: 11 hours 26 min ago
My E20R operates as you describe beam0. No beacon. Single click on. Double click from anywhere for strobe. Long 3 second press to lockout from off.
"Everywhere I go, there I am"
vresto
vresto's picture
Last seen: 2 hours 54 min ago
nice review.thank s a lot.i was thinking sst40 is more powerfull….
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
beam0
beam0's picture
toddcshoe thanks! Do you like it, any complaints? Have you tried 18350?
toddcshoe
toddcshoe's picture
Yes, I like it just fine. A hint of green in the tint but nothing I can’t live with. Haven’t tried a 18350 as I don’t have one but, I did see if the end of a 18650 would fit the tube and it’s too tight to fit. It does come on very easily in a pocket if you don’t lock it out but other than that I don’t have any complaints. It’s in my rotation of lights I carry daily. Plenty of light when I need it. More flood than throw. I will probably pick up the E40R if I find it at a too good to pass up price.
vresto
vresto's picture
where you bought them?
beam0
beam0's picture
toddcshoe, thanks for the feedback! I’m curious what 18650 (brand/model) did you try for the diameter? was it protected?
The reviewer from Poland tried an 18650 for diameter and it did fit, but he said a protected cell would not. Also someone replied in his (same) review on CPF that an18350 did fit, I just wanted a 2nd confirmation.
I was also interested in the E40R but as I recall there was something about the UI that was a deal breaker for me, E20R must have a different UI.
beam0
beam0's picture
I’m wondering that too, E20R is sold out at Banggood and that’s where madmax had the coupon deal, also discontinued at Fasttech.
Gearbest does show it available, (ships on May3-6): https://www.gearbest.com/led-flashlights/pp_1625713.html?wid=1433363
djozz
djozz's picture
Last seen: 1 hour 33 min ago
The loooooooooooooooong press for switch-on makes me not using the E40R. I tried if swapping in a really nice led would changes things, and still it does not work for me.
beam0
beam0's picture
Yep, that was it!
But I like this E20R, not sure why this UI wasn’t also in the E40R, not the greatest UI but it sure is better.
vresto
vresto's picture
beam0 wrote:
I’m wondering that too, sold out at Banggood and that’s where madmax had the coupon deal, also discontinued at Fasttech.
E40R is not sold out on banggood….
vresto
vresto's picture
iam reading well,when i see,that for ON you have to push the button for 3 seconds??? and the same to off??
beam0
beam0's picture
Wasn’t your question replying to toddcshoe’s post (#6) directly above yours? (He has the E20R not E40R)
To clarify, I was referring to the E20R which is showing sold out on banggood. (I also edited my post to indicate E20R)
toddcshoe
toddcshoe's picture
I apologize, I was thinking of a different 16340 light I have. Yes the 18350 does fit, it’s super tight but, it does fit. Well let me say this, since I don’t have a 18350 to try. I can fit 30Q’s, VTC6’s, and HG2’s part way in the tube so i’m assuming 18350 cells will fit. Being there is quite a generous spring in the tail I don’t see a problem with a unprotected 18350 fitting just fine.
toddcshoe
toddcshoe's picture
I got mine off a autction on Ebay about a month ago. $30 with free shipping. Cheapest I see on Ebay now is about $49.
RobertB
RobertB's picture
Last seen: 1 hour 46 min ago
Apparently Jetbeam doesn’t notice the error.
beam0
beam0's picture
Cree? That too funny. I’m surprised Luminus hasn’t seen this and made them correct it.
beam0
beam0's picture
Thanks toddcshoe. Wow you did get a great deal!
