TrustFire IMR26650 3400mAh (Red-gold)
Official specifications:
Battery Capacity (Mfg Rated): 3400 mAh
Battery Chemistry: Li-Ion
Battery Feature: Rechargeable
Battery Form Factor: 26650
Battery Maximum Voltage: 4.2 V
Battery Minimum Voltage: 2.85 V
Battery Rated Voltage: 3.7 V
Anode material: LiNiCOMnO2-C
Discharge Rate: 20C
Maximum discharge current: 68A
300-500 times rechargeable
This 26650 cell is fairly low capacity, but high current.
The discharge curves looks good, it can deliver up to 20A with nearly constant capacity.
Conclusion
This looks like a fairly good battery for high current application, but capacity is fairly low by todays standard.
Notes and links
Compare to 18650 and other batteries
