I'd been reading up about more flashlights here (mostly budget-level ones), and since I don't have a working AA/14500 flashlight yet (actually I had an UltraFire UK68, but it worked on AA the first time I got it, but subsequently it doesn't work with AA, it now only works on 14500), I got the UTorch UT01 when it was on flash sale sometime back. The lights just arrived (I got 2pcs - CW and NW).
Now, upon checking the UT01 NW, the tailcap spring PCB fell off (is it supposed to be glued?), but apart from that, it seems to work.
I then checked the UT01 CW, and it does not turn on -- nothing at all.
Since I have 2 versions, I decided to mix and match the body tube and tailcaps. I find that when I use the tailcap/spring of the UT01 NW on the UT01 CW, then I can get the flashlight to work properly. So for some reason, the tailcap spring of my UT01 CW does not function (and it's glued on the cap; unlike the one on my UT01 NW which fell off immediately the first time I inserted battery.
What might be the problem?
Update:
So I decide to test continuity of the tailcap with a multitester, and both seem to be working....
But when I screw the tailcap to the body tube (I tested both body tubes, and even flipped them over and tested again), and test for continuity with multimeter, then there's a difference:
Connecting the tail cap (from UT01 NW) to the body tube (any), there is continuity.
Connecting the tail cap (from UT01 CW) to the body tube (any), shows no continuity.
What's wrong with the UT01 CW's tailcap, I can't seem to notice defect. And strangely, the tailcap from the UT01 NW which immediately fell off on first use, it works properly.
