Emitter swap on Quark Pro QP2A-X
12 posts / 0 new
ryukin2000
ryukin2000's picture
Last seen: 2 weeks 6 days ago
Hi i have a QP2A-X with a somewhat greenish tint. I prefer neutral white. Is an emitter swap easy to do? I run the light with a 14500 cell in the 1AA body. Not sure what size the LED MPCB is. Any tips would be great. Thanks.
Edited by: ryukin2000 on 12/11/2017 - 01:45
netprince
Last seen: 13 hours 8 min ago
Yes they can be modded, the trickiest part is getting the bezel off without scraping up the annodizing. It is usually glued down pretty well. After that the mod is pretty easy.
ryukin2000
hmm i guess i should attempt to remove the bezel first before ordering any parts. Thanks.
kramer5150
kramer5150's picture
certainly do-able.
I modded a ~5 year old Quark AAT with a neutral XPG3, in the brightest flux BIN I could easily source, mounted on copper.
They use red loc-tight on the bezel threads, which is basically glue. I heated it around the bezel little with a small butane torch, and then chilled it with an ice cube around the perimeter. This in theory anneals the loc-tight and makes it very brittle. I then used a pair of strap wrenches and torqued the snot out of it to get the bezel off. Easy mod, and it looks 100% factory too.
I often prefer this light to my manker E11… its been so bomb proof reliable for 5 years.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 29 min ago
Yeah, same for my 2AA-X. Glued tight.
ryukin2000
kramer5150 wrote:
certainly do-able.
I put it in a vice with protective rubber and tried with a wrench. Didn’t budge. I guess heat is the only way as you said. Need to buy some strap wrenches too.
Whats the best flux bin for neutral white XM-L2?
ryukin2000
Success!! Renewed love for the light now. No more ugly green tint. Fitted with XM-L2 T6 4C on a 16mm Noctigon from Mtnelectronics. Had to grind it down to 14mm to fit though. Messed up the head anodization but totally worth it.
Lightbringer
4C would be perfect with a TIR instead of a reflector, but dunno what size the head is.
Reflector… OP or SMO?
ryukin2000
It’s an OP reflector. Never thought of TIR! like a triple? the dia of the head is around 22mm so i’m guessing the reflector is 18. i run the light on 14500. is that efficient for triple emitters?
Lightbringer
Sounds like a standard 20mm TIR might fit. Check the front glass, if 20mm, you’re good to go.
You got a huge variety of TIRs to choose from if so.
WalkIntoTheLight
Last seen: 8 months 1 week ago
Cool. I’ve got to try this mod on one of my Quarks. Are there Nichia 219 MPCB’s that will work in this light, or is the forward voltage too different for it to work with the Quark’s driver?
Lightbringer
Shouldn’t make a diff. Ain’t a FET driver as far as I know.
