There is also an 18650 version called the TC7. I can’t imagine that this isn’t a Soshine branded version of a light available under other brands, but I haven’t found the others yet.
As it happens, I happened to order a different light from the same seller a couple of weeks ago. They gave me a ePacket tracking code 11 days ago and it still isn’t recognized by any tracking system. I’ve complained and so far, they’ve given my the run around. Not happy with them at all. Plus, they are charging more than Banggood.
In any case, I’ll be curious to see a teardown if anyone gets one of these before I do.
Looks like a nice host… But I hope that horrible wide thingy under the tailcap is removable. Looks really uncomfortable to hold the light with it. Why would they put it there? What’s the reason?
I see, thanks. Never seen such a big ugly one like that. I guess it would kind of make sense if it was a tail switch only light but it has dual switch. If someone gets one, please check if it can be removed easily.
I know, I know… I hate those ugly-ass things, too.
Guess they intend it to be that you set the mode via the side-switch, and then just flick it on/off with the tail-switch.
Unless it’s glued on or torqued so tight as to torture the threads, it has to be removable, else instead of a nice slim tube they’d have to use a thick block of Al to machine the thing.
