I ordered some cheap 30q’s from GearBest awhile back, dropped them in a Lii 500 for capacity testing with the Nor (discharge measuring) test. Results were:
2880mah
2890mah
2941mah
3005mah
I suspect these are close enough to be safely used in a 4x parallel light (ie Q8) but wanted to check with you all first. Thanks in advance!
Those Samsung 30Q batteries are virtually the same capacity, particularly when you take into account that the Lii 500's capacity testing has an error range (+ & -).
Russian:
Если честно, то вопроса не понял, даже с гуглем. Если имеется ввиду, можно ли соединять элементы с разным внутренним сопротивлением, то я ответил на него - да, можно, и пофиг на сопротивление и ёмкость. Если имеется ввиду, изменяется ли внутреннее сопротивление батареи по сравнению с отдельными элементами, то ответ - конечно, закон Ома ещё никто не отменил и считается оно соответственно.
The thing is it was a bit silly reaction from this Australian guy, but you see you Wildcat look not much different
Again, for God’s sake, will someone answer: Is internal resistance (let’s limit discussion for LiIon batteries, for example) dependent on their actual capacity – I assume it somewhat may be
More capacity -> less internal resistance -> more current in the circuit
The same obvious things: increasing the capacity can be considered as a parallel connection of batteries. The capacities are added together, and the total resistance decreases and is calculated according to Ohm’s law for parallel resistances.
