Hi Guys,
Got a question that I have not found much info on. Has anyone tried de-doming IR LEDs such as the Osram 4715AS? If so what was the effect? Some who tried it said it that while the projected die is smaller it didn’t have any more density. How much wave length shift would I expect, ie 850nm shifts to 800nm? Is it similar to de-doming a white LED. I have a AS in a T67.
Also if I was to put an RA on above the 4715AS will it have the same effect as a RA on a white LED in the sense that it will excite the emitter?
May have a few more questions coming up
Yabba
Dedoming will have no tint shift as no phosphor is used
The 4716AS has a very shallow dome which gives a way smaller projection of the die
https://dammedia.osram.info/media/resource/hires/osram-dam-2496394/SFH%2...
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: overview of sizes and types
DD+AMC based drivers Anduril or Bistro OTSM 12-24mm, S42, 24-30mm L6, Q8, MF01(S), MT03, TN42
Anduril or Bistro 8A buck driver for 20-30mm, MF01/02/04, TN40/42, Lumintop GT, MT09R
UVC and UVC+UVA drivers
programming key
Remote switch tail DD board with FET
Aux boards:
Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
Thanks,
Makes sense the 150 deg beam will give a smaller die projection, but wont the advantage with the extra throw be wasted due to the lost spill as opposed to the 90 deg beam?
So if I was to put a RA or wavien collar over my de-domed 4715AS what would the effect be?
Are you sure about the shallow dome? Normally it should be the other way around. High domes with small emittance angle give you a very small spot and lots of spill when used with a reflector (with an aspheric lens you the will get a bigger spot). Low domes will give you a bigger spot (makes better use of a reflector in my opinion). This can be checked with carclo’s beamshots of their optics and Osram Osslon SSL80 and SSL150 LEDs on their website.
Project Excalibur - Next Generation LED Thrower (UPDATE 2018-01-15: 1.7Mcd)
Portable Thrower Comparison
I have no info on the dome.
Just don’t combine these or the SFH4725S with a direct drive driver or “test” them directly to a 18650. The will blow immediately. Don’t ask how I know
Narrow angle LEDs are terrible for reflectors because very small amount of light hits reflector surface.
led4power.com
