LiitoKala Lii-S1, successor of the revered Lii-100
150 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 2 weeks 1 day ago
Pete7874 wrote:
Quote:
I think they fixed the over charging of the 100. I can’t remember if I’ve tested all three, but at least the one I tested terminates at 4.18V.
The one I received last month overcharges.
… Then it’s a cheap charger? If there is variance resulting in some samples over charging… I think I’ll re-test all three of mine soon.
Barkuti
Barkuti's picture
Last seen: 10 hours 21 min ago
My home Lii units pump up to these voltages when set to 4.2V li-ion:
  • Lii-100 Mk1: 4.22V.
  • Lii-202: 4.14 and 4.16V.
Furthermore, my Lii-202 fills up Ni-MH cells significantly more than the old Lii-100 Mk1.
Cheers Smile
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
hIKARInoob
^^^ Do you think final voltage is also dependent on type of cell and internal resistance?
Barkuti
Barkuti's picture
The maximum cut-off voltage of each charging rail can be directly read over it when the charger is in CV mode, which is easily caused on purpose by attaching some high resistance in series with a cell like alligator clamps with magnets. Actual maximum resting voltage will be somewhat below this value depending on termination current and rail to cell total resistance.
Cheers Smile
Pete7874
Pete7874's picture
Last seen: 1 day 16 hours ago
How do you tell if you have an Mk1 or some other version?
Also, is 4.22V cell’s resting voltage right after you’ve removed it from the charger? Or voltage while still charging?
Barkuti
Barkuti's picture
Looks like this one and was bought on April 1st 2016, Pete7874. It's Big Smile vintage!
After removal from the rail plus a tiny bit of resting. Some would say it technically overcharges.
Cheers Smile
DB Custom
DB Custom's picture
Last seen: 3 weeks 16 hours ago
Nice find Barkuti….
Wondering myself how this one goes about it’s business, would like some quality chargers for those occasions I give away a light. Smile
My MAHA dedicated NiMH chargers have two charging rates for NiMH cells, standard and soft charge. Standard charge rate is 2000mA, one has 100mA soft charge while the other is 300mA, both are 8 bay chargers. The other day I was getting ready for a wedding, charging cells for my flash units… I had 5 of the 8 bay chargers going full out. These 2 MAHA’s and 2 Enova Li-Ion/NiMH with another Gyrfalcon also loaded. After the cells were done, I took my 2 sets of premium cells for two flash units and conditioned them in the MAHA chargers.
So my primary cells were charged, charged again, discharged, then charged again. I took 868 photo’s on my 1st set of 4 and my wife took 1025 photo’s also on her first set of 4… neither of us got into the second set. That’s some serious work from the Pro level NiMH LSD cells! (FWIW, we didn’t change the camera battery either)
To have a small single bay charger that works well, easily used anywhere… from a battery bank or solar panel or the car or whatever… this could come in quite handy.
Pete7874
Pete7874's picture
Barkuti wrote:
Looks like this one and was bought on April 1st 2016, Pete7874. It’s Big Smile vintage!
Thanks. Looks exactly like the one I received last month.
rizky_p
rizky_p's picture
Last seen: 2 months 3 days ago
I just read the specs battery polarity doesn’t matter it still charge the battery either way. cool i wish that we have flashlight like that Big Smile
Finnno
Honestly I can’t see the purpose of it
Spread love, it pays off
Pulsar
Pulsar's picture
Lazy people or people who dont know much about the hobby
Andrew_Debbie
Last seen: 1 day 4 hours ago
hIKARInoob wrote:
Nothing beats a $0.99 original Lii-100. Big Smile
Indeed. I bought mine for the sliders and case.
Still thinking about exactly what I’m going to do with it.
Andrew_Debbie
Barkuti wrote:
Lii-S1 spotted at …. I do not really want to judge but hell with the $9.99 jacked up pricing,
4BLF code works, dropping the price to $9.09. Innocent
Stittville Ed
Stittville Ed's picture
These will be great chargers to give away with a light you are Gifting to someone.
Will have to wait until the price drops.
Which could happen tomorrow Smile
Barkuti
Barkuti's picture
I have news:
Congratulations! Charger displays actual flowing current.
Cheers Smile
Pete7874
Pete7874's picture
We need proof. Who’s going to be the guinea pig? Smile
Barkuti
Barkuti's picture
Where did you got that new old stock right now?
Note: displayed current value is function of voltage drop and sense resistor values, which are implemented on the microcontroller unit's software. Bear this in mind for sense resistor mods to change current output, as the displayed current values won't change unless the sense resistor variable value is poked in the software.
If, for example, you 4x the sense resistor value (nice for small cells like 10440s) you need to divide by 4 the displayed current value. No big deal though.
Cheers Big Smile
Pete7874
Pete7874's picture
Gearbest still sells them… https://www.gearbest.com/chargers/pp_272183.html
Often for $0.99 and free shipping with coupon.
Barkuti
Barkuti's picture
Pete7874, I've bought more Lii-100s from GearBest than I personally need (like a lot of you), but only my first unit looked ”vintage”. The ziplock plastic bag was even removed from the package in the last unit I received (still another one Big Smile to go).
Cheers Party
P.S.: $0.99? LoL! I've got a couple $1.99 sales maybe. Now that you say this, could it be that these $0.99 units are new old stock they are getting rid of?
hIKARInoob
How can you tell between old and new? Mine came in cardboard box, exactly the same black/yellow style as Nitecore.
Pete7874
Pete7874's picture
That’s what I’ve been asking. I don’t understand what he means by ‘vintage’.
Barkuti
Barkuti's picture
Mmmkay hIKARInoob, does it looks like the one in HKJ's review? If so, it's an old revision.
Cheers
Pete7874
Pete7874's picture
Barkuti wrote:
Mmmkay hIKARInoob, does it looks like the one in HKJ’s review? If so, it’s an old revision.
Cheers
But if that’s “old revision”, then what does the “new revision” look like?
Or are you just saying that Lii-S1 is the new revision?
hIKARInoob
Mine look like this: https://www.gearbest.com/chargers/pp_272183.html
The 4 percentages on the left is like the shape of a battery. Mine were purchased November 15th last year. $0.99 was related to singles day I guess.
Pete7874
Pete7874's picture
Oh, I see it now. Thanks for pointing that out.
In that case, mine are not vintage. Crying
100 on the left, and 100B on the right.
Barkuti
Barkuti's picture
Internals of my early Lii-100 unit.
Cheers Smile
klrman
klrman's picture
Last seen: 2 weeks 6 days ago
Just grabbed the Lii-S1 from Banggood for $6.99 on their flash sale today.
Spiderlight
Me too. Thank you
cloggy
Last seen: 3 hours 41 min ago
Snagged a couple from Banggood- more available. Thanks Klrman.
cloggy
FPV
FPV's picture
The LiitoKala S1 can be had for 2.80 $US during the anniversary sale coming up on Aliexpress:
https://www.aliexpress.com/item/LiitoKala-lii-S1-18650-Battery-Charger-F...
There is also a coupon for 1$ off on minimum 3$ purchase for 50 AE coins.
I can not guarantee this deal will work and won’t change, just giving the heads up on this thread. Sorry if I posted this in the wrong location.
