Test/review of Vapcell INR18650 2400mAh (Purple)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 hours 37 min ago
DSC_5549
Official specifications:
  • Model: INR18650
  • Size: 18.3*64.8mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2400mAh (0.2C discharge)
  • Min capacity: 2300mAh (0.2C discharge)
  • Weight: Max:46g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Charging Time: 3.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
Vapcell%20INR18650%202400mAh%20(Purple)-info
This is a high current cell with not that much capacity.
DSC_5547 DSC_5548
DSC_5550 DSC_5551
DSC_5552
DSC_5553
DSC_5554
Vapcell%20INR18650%202400mAh%20(Purple)-Capacity
The two cells tracks nicely and they can deliver 30A.
I had to skip the temperature curves, I forgot to replace the battery (It last about a year).
Vapcell%20INR18650%202400mAh%20(Purple)-CapacityTimeHours
Vapcell%20INR18650%202400mAh%20(Purple)-Energy
Vapcell%20INR18650%202400mAh%20(Purple)-PowerLoadTime
Vapcell%20INR18650%202400mAh%20(Purple)-TripCurrent
Vapcell%20INR18650%202400mAh%20(Purple)-Charge
Conclusion
The battery is a bit low in capacity, but it can deliver a lot of current.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
djozz
djozz's picture
Last seen: 1 hour 37 min ago
Thanks for the test HKJ!
Agro
Agro's picture
Last seen: 4 hours 6 min ago
Beats VTC5A. Smile
Barkuti
Barkuti's picture
Last seen: 2 days 2 hours ago
Interesting discharge curve shape, remembers me to that of Vapcell INR18650 2000mAh (Black) and those of Samsung INR21700-30T 3000mAh (Gray) and its Vapcell INR21700 3100mAh (Purple) rewrap.
One of the 30A discharge curves is trimmed off. Maybe the cell overheated?
Cheers Smile
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
HKJ
HKJ's picture
It lost contact, maybe due to overheating.
HydrAxx
HydrAxx's picture
Agro wrote:
Beats VTC5A. Smile
At the same time, it’s quite normal is the rewrap of the cell Samsung INR18650-24S (2400mAh typical and 30 amps continuous real), the best cell 18650 in 30A continuous of all time nobody did better than this cell until then in this type of cell 18650 (30A continuous).
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
