The There Are No Stupid Questions Thread
1670 posts / 0 new
Scallywag
Scallywag's picture
Last seen: 4 hours 44 min ago
sochi111 wrote:
Probably a couple of dumb questions: Smile
1) I already have an SST20 flashlight (Convoy S2+)
Is there any advantage getting a flashlight with SST40?
I was thinking of getting another budget thrower, I have a C8 XML,
but would prefer a side switch, or e-switch
2) Is this a legit store: Convoy Direct ?
https://www.aliexpress.com/store/3135023
SST20 is a small, throwy LED available at 5000K and below, and in high CRI below 5000K. To my knowledge, the 70CRI versions out-throw XPL-HI despite being domed.
SST40 is a large LED capable of very high output (over 2000 lumens at like 6+ amps). It’s not available below 5000K nor in high CRI. It’s a floody LED due to its size, but gets used in throwers due to sheer output and compromise of lumens vs. throw.
Skylight
Skylight's picture
Last seen: 8 hours 44 min ago
Tom E wrote:
I wouldn’t go that crazy with modding the driver or MCPCB. Keep the dual springs, don’t use bypasses, use long thin LED wires. 24 or 26 AWG should do with some extra length. I’m not sure what amp level the LED’s burn up at though – haven’t had that problem, I assume there’s been some LED testing to prove the burn out point?
I haven’t heard of Vf varying with tint before. Sure, a 2700K will be a lower bin but the Vf? Never heard of that.
Of course I assume you are using a TA driver specifically designed for 6V LED’s? That’s a must. Plus you have to mod the carrier for 2Sx2P.
Thank you, Tom E, good idea to use 24AWG wire.
Djozz tested the XHP50.2 up to 12A and it didn’t burn out. But once I read about a build with 7 XHP50.2 and two 26650 cells in direct drive where the XHP50.2 burned out one after another. So I’m concerned because it is said that the 6V XHP50.2 has weak internal connections and individual dies become dark easily.
I think with Cree leds the Vf is lower if they are 90CRI. I just assumed it would vary with the bin as well.
Currently, I want to mod the Haikelite SC04 whose reflector happens to fit a Q8 MCPCB perfectly. I have a TA driver with LDO and four Luxeon V2 wired 2S2P which work nicely. However, I want more power and a bigger hotspot. If it goes well, I might try it also for the Q8 with a 2S2P mod.
Tom E
Tom E's picture
Last seen: 4 days 5 hours ago
Ohhh, interesting bout the SC04, 2 cells config I'm sure. I've done the thin long wires in other lights to reduce amps - works well, and actually some stock FET based drivers simply use long twisty traces on the driver to result in the same thing.
This was an example from a 12X SRK. I bypassed the squiggles and got more amps:
JasonWW
JasonWW's picture
Last seen: 2 days 6 hours ago
I did not hear of a single successful use of 50.2 with FET driver. They all burned out. Some lights used really weak cells and lasted a couple months, but it eventually burned out as well.
This is why no one builds that combo.
Some leds work well with FETs and some don’t. I would ask around a lot more before committing very much money into the build.
The 3v versions are a different beast. They can handle FET drivers no problem. Of course using a single 26650 will reduce run times, but it might be better to just swap a new cell in than to have the 6v leds burn out.
xevious
xevious's picture
Last seen: 1 day 17 hours ago
JasonWW wrote:
SST-40 is just a bigger led so it has the potential for higher output. I know the FT03 is a great budget thrower using the SST-40. It will be brighter with more throw than both the lights you mention.
I dont know about that store. Why would you buy from them instead of from Convoy direct?
Hey Jason, in expanding my search for a mid-sized thrower, I was gearing myself up for the Sofirn SP70, but then reconsidered the FT03 with SST-40. Seems that dedoming it produces a reasonable bump up in throw. Not as much spill as the SP70, and not same output level (XHP70.2), but coming in at half the price it looks pretty attractive. Have you dedomed many LED’s? I’m trying to figure out the best way to do it without having to remove the star.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 5 days 5 hours ago
Trying to dedome without removing the MCPCB from the light is asking for trouble. If your cutting angle is slightly off you’ll scrape phosphor from the emitter and end up with a blue LED instead of a throwier version of what you had.
Now is a great time to learn to solder, desoldering and resoldering wires to the star is incredibly easy. Matt Smith has great videos giving soldering/reflow tutorials:
JasonWW
JasonWW's picture
The FT03 and SP70 are very different lights even though their throw distanceis about the same. The SP70 is like 6,000 lumen with a big hot spot and can light up a football field. The FT03 SST-40 is about 1,800 lm and has a much narrower beam. One is light and pocket sized (like jacket pocket) and the other is heavier and way too big for a pocket (I actually slip it in may back pocket with slacks). So it depends on your needs. Light up a football field or spotting smaller stuff at a distance. A bit like a shotgun compared to a rifle. Big wide beam of light or narrow and precise beam of light. Each beam size has their pros and cons.
I’ve only cut a couple domes. One was an old xhp70 just to see the change in hot spot size and throw, but I didn’t like the loss of lumens. One was a xhp50.2, but I didn’t like the tint shift. I dont really bother with slicing anymore.
You do have to remove the star. It’s a delicate process with a razor blade. I think the SST-40 needs to be sliced (some led models are chemically softened and lifted off).
Scallywag
Scallywag's picture
The star must absolutely be removed.
To do it properly, you should really reflow it onto a fresh star that has never had solder on its +/- wire connections. This will allow you to use washers of varying thickness as a guide.
If you search BLF, there are LED slice or slice and dice guides.
raccoon city
raccoon city's picture
Last seen: 12 hours 3 min ago
Post #1000!
(at the moment)
xevious
xevious's picture
I have done some limited soldering & desoldering. Actually replaced NiMH batteries in a rechargeable shaver, and reconnected a loose wire on a speaker circuit board. But I’m not adept at doing this (need more practice). I do realize the need for a totally parallel cutting angle. My expectation is that if the cavity is shallow enough, it would be possible to do with the star still in place. I’m lazy! But if it’s challenging to get a proper cutting angle, removal definitely makes sense.
JasonWW wrote:
The FT03 and SP70 are very different lights even though their throw distance is about the same. The SP70 is like 6,000 lumen with a big hot spot and can light up a football field. The FT03 SST-40 is about 1,800 lm and has a much narrower beam. One is light and pocket sized (like jacket pocket) and the other is heavier and way too big for a pocket (I actually slip it in may back pocket with slacks). So it depends on your needs. Light up a football field or spotting smaller stuff at a distance. A bit like a shotgun compared to a rifle. Big wide beam of light or narrow and precise beam of light. Each beam size has their pros and cons.
Yes, I do recognize the different form factors (FT03 closer to EDC, while SP70 is not) and the SP70 having tons more spill. I was thinking more about the effectiveness of the hotspots. Anyway, considering that I have an EA4 and a EC4GT for throwers, the FT03 is probably a bit of a duplicate (just 800 lumens more powerful). For a bit I was hung up on wanting Anduril (or NarsilM), but for a dedicated thrower, not as important. The SP70 UI actually seems decent.
BurningPlayd0h
Just taking the MCPCB wires on/off doesnt take much finesse at all and is some of the easiest soldering I’ve ever done honestly.
ryukin2000
ryukin2000's picture
Last seen: 2 days 20 hours ago
i have an LD01 that works Intermittently. the outer ring on the driver where the body makes contact when twisted seems to look scratched up. is it possible that this can wear down and prevent it working? how would one restore it? thanks.
JasonWW
JasonWW's picture
A Fenix LD01? That driver does not have a retaining ring, right? The battery tube just screws against it?
It’s possible it can wear down the metal pcb traces (copper I think). More likely it’s just a bad contact somewhere else in the circuit.
Power goes through the threads, battery tube, tail cap, springs, etc. I would clean all those first. They can get an oxide coating that hurts the electrical flow adding resistance. If the problem really seems to be wear related on the driver traces you’d need to add a thin layer of solder on top. Some people will add a small blob of solder on 3 points and then file/sand them down so they are the same height and the battery tube presses down evenly.
ryukin2000
Yes you’re correct, there is no retaining ring. its going to be a pain getting that driver out. i’ll try cleaning what i can first. thanks Jason.
Edit for Info: Its and older Twisty light
xevious
xevious's picture
I’ve not yet done it. I see photos & videos where it’s very small wires in tightly confined space. Desoldering? Sure. But soldering the wires back on? I’m assuming you need tweezers & clamps carefully applied to help keep the wires in place as solder is applied. Maybe I’m just paranoid & should dive into it. Try out on cheap lights first. Anyway, I thought it was worth exploring alternatives.
JasonWW
JasonWW's picture
You need a decently powerful iron because a lot of the mcpcbs are really good at soaking up heat plus that heat can transfer to the head. You need narrow long tweezers or some small tool that fits in there. I use a dental scraper. As you heat the soldered connections the wire might pop up or you might have move it to the side. Same for resoldering. You’ll need to hold the wire in place while you attach a blob of solder to the iron and reach in to attach it.
Once I remove the star I clean the old solder off, apply flux and put new leaded solder in it’s place. The stock solder can be unknown and might be poor quality. I put the good stuff on it. Once back in the light I use alcohol on a q tip to clean the excess flux and make it look nice.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 2 min ago
Maybe someone can explain this to me, as I seem to be too dense to comprehend it.
Why is it that if I were to go to Amazon and buy X (coffee-grinder, bluetoof earmuffs, sock-hangers, anything), within a week I’d get inundated with emails from them that I “might be interested” in another X (coffee-grinder, bluetoof earmuffs, sock-hangers, etc.), as if one just ain’t enough?
ArtieT59
ArtieT59's picture
Last seen: 3 hours 29 min ago
Im new to flashlights and own a few.
What are the differences in drivers used in todays hi powered lights. I see FET, buck, boost, I don’t know what any of them mean, and why sometimes one is used over another. Help?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
JasonWW
JasonWW's picture
You must not have clicked the “don’t send me email promotions” box. I never get emails like that, yet I buy from them.
Lightbringer
Mmm, maybe I should.
Some, related, things are useful. Like, buy bbq tongs and get recs for cookbooks about outdoor grillin’ recipes or something. But not 13 ads for more tongs.
xevious
xevious's picture
Are you new to Google too? Wink
Simple search took me all of 15 secs to find a few sites to help explain:
Flashlight WIKI Drivers
Reddit – Drivers – boost, buck, linear, FET, direct?
HTH
JasonWW
JasonWW's picture
Wow, for some reason I did not see your post. Try this thread. http://budgetlightforum.com/node/33820
xevious
xevious's picture
Excellent follow-up Jason. It’s always nice to have some photos & diagrams. Using multiple sources definitely helps expand understanding.
BaronVonEissler
BaronVonEissler's picture
Last seen: 1 year 6 months ago
I have One Emisar light. The K1 SBT90.2. Great light.
Question: How come no where on the light OR the box is Emisar inscribed? Never had a light where the manufacturer left that info. off of their product.
You can't hide me from me.
JasonWW
JasonWW's picture
It’s technically not an Emisar, it’s a Noctigon. Hank at Intl-outdoor is behind both brands.
BurningPlayd0h
Yeah Emisar is lights with linear chips + direct drive, Noctigon is lights that use constant current or boost drivers.
jeff51
jeff51's picture
Last seen: 1 day 6 hours ago
If you can see the Internet.
the Internet can see you.
Someone is always willing to pay for every click and every mouse hover.
I wonder if someday some mogul will say:
You know, I’m not sure paying to collect all this data is really doing us any good.
Lets drop the whole thing.
24Hrs later the WWW collapses.
All the Best,‘Jeff
jeff51
jeff51's picture
I’ve got an SP70 with the 70.2 LED. I really like it.
It’s big and heavy and clunky.
If I was going on and extended S&R type of thing (which I never will I suspect).
It’s the one I would grab.
PWM is so fast you will never see it. Like 19K if I remember.
Being able to turn the light off with the side switch is a big plus over, say, the L6.
The only thing I don’t like is the position of the front strap attachment.
It’s right in front of the switch. The clip folds back and blocks the switch.
Also it makes the light front heavy. So carrying by the strap, slowly the light dips toward the ground.
Move the front connection point closer to the font fixes this.
Wish is was available in a warmer color. Warm works better for me outside.
All the Best,
Jeff
JasonWW
JasonWW's picture
The first batches used a CW, maybe 6000-6500K, but now they offer it in 4700-5300K. Nice for new buyers, but those that already have it would have to swap it out.
Lightbringer
So… Internet = The Abyss.
Makes sense.
Mmm, I can deal with that.
