I also have an A6 I plan to install one of these in.
Off topic I know but quick question: Are there any good 5050 LED’s on the market besides the XM-L2? I have a light I want to upgrade the LED’s in but it uses a custom 4x XM-L2 mcpcb that I could not easily replace. I would prefer not use xm-L2’s.
Just installed 3x LH351Ds in my C8F from the last batch and shipments. They look too cold, I knew it at first sight. I've compared the beam against a 30° TIR equipped S2+ using a known good LH351D 4000K CRI90+ from the first set of shipments, I must have received 5000K CRI70+ emitters.
Could you please confirm if possible, AEDe? Thanks.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
After a quick glance at 'em they look pretty similar. Will take a shot or two out of their strip packages later. Optics from the above flashlights are completely different, thus the comparison isn't fair. Colors look good but I don't have a known low CRI emitter flashlight at hand now. Got me alarmed, though.
Will have to wait a bit for now, thanks.
Cheers
No need for photos, they're definitively orange. In fact just noticed the only unused and not orange looking emitter I have in my cardboard cache emitter box is one of those 5000K CRI90+ XP-G3s (1 out of 46).
The second batch is an L6 chromaticity bin, ≈125K cooler than the first (L7). I am impressed by how much a reflector can influence the final perceived tint, beam corona looks yellowish while hotspot and spill are a noticeably cooler white.
Thanks all for the input.
Well, sort of Lightbringer. The hotspot is sort of yellow, the corona is yellower and the spill is of a cooler temperature.
Yeah, I got a bunch of lights where the corona is lemon-yellow while the hotspot is also yellowish but not nearly as much, and the spill is blue-white.
Anyone have an idea or guess how the Vf of the 351D 4000K 90CRI emitter compares to the Vf of the 219CT 5000K 90CRI emitter? I put 2 of the Samsung and 2 of the Nichias (from a D4) in a Q8 and visa versa. My impression is that output decreased a little in the D4, but tint, CRI, and throw improved. I don't want to push the Q8 too hard due to the 3 additional cells. I did turbo a bit and detected on no blue tint warning of overheating. I'm not a good judge of output, tint, and CRI by eye though. I'm assuming the CRI didn't actually increase, but it appeared like it did to my eye.
I really like the combo tint and CRI wise, but I don't want to fry one set of emitters due to significantly lower Vf. I really need to setup a heat sink with light tube and test each emitter, but I'm hoping someone in the know already knows.
EDIT: Clarified wording.
EDIT2: Caught typo (strike out above). Sorry for all the edit's folks.
I put 4 of the new batch in my D4…and I don’t like them
I see a green hue in the color. It’s a shame because the beam is way smoother than with 219C, there’s no artifact.
What’s strange is, I put another one in my Sofirn SP32A and the color is as nice as the old batch…
Could it be the AR glass ? Or the TIR ?
"-X3-, is there any place in your house without a flashlight ?"
Well that’s simple to correct with a minus green filter.
What filter would you recommend for the job?
I keep meaning to order one of those kits but never seem to have the money when I am thinking about it and don’t think about it when I have some money lol
Depending on the severity of the green tint, which isn’t horrible with the LH351D, I’d say a Lee Zircon 804 is probably a good bet. If you want to make sure it lands on the rosy side, pick the 803 which usually fixes the XP-G3+d-c-fix combo very well. 802 is probably overkill.
Thanks! I am thinking I will buy a sheet of 803, 804 and 805. The output loss sucks but at least it could make otherwise unusable lights look good.
Would you say these are the best sheets to get if I can only get 2 or 3?
That’s what I got. The 805 is very subtle though. I wouldn’t probably even fix something that only requires so little shifting. I’d probably go for the 802 instead for the extreme cases of green.
I could probably say the output of my now LH351D modified C8F is subtly/very subtly greenish in the low modes, something which vanishes as you up the driving current. You must be very picky.
Cheers
Cheers
Yeah I fear that I’ve became a tint snob
The green hue does disappear with higher modes though,but since I love to use the <350mA modes more often, I have to fix that
… The output loss sucks but at least it could make otherwise unusable lights look good. …
At times I've thought the lower CRI emitters “exploit a sort of cheat” with the lumen output, because our eyes, brains and minds are more or less sensitive depending on light frequency:
Thus, output from lower CRI emitters may seem to dazzle or blind more because they're using more power output in the light frequencies we're more sensitive to. But their light is a cheat that does not abide well to the spectral power distribution profiles of the sun/blackbody radiator, something which can be felt.
Cheers
Cheers
I haven’t tried the new batch yet. But I bought a noctigon M43 mcpcb with the 4000k LH351D 90cri from kiriba-ru and thought it looked acceptable until I compared it with my 5D tinted flashlights, which is when I realize how yellow the tint is on the LH351D. Even white objects become yellowish with the LH351D, whereas my 5D tint and my 219B 4000k 9050 flashlights render white as white. The yellow is so bad that I find my 5D 70cri Cree XHP HI and XPG2 lights render colors better and more natural than the 90cri LH351D. I guess a LEE filter can fix it but that takes away 17% or more lumens and the LH351D is already not efficient compared to the XP-L HI. The LH351D M43 measured 4310 lumens whereas the XP-L HI 4000k 5D measured 5,172 lumens at turn on. Surprisingly the XP-G2 5D version measures 6000 lumens. These are after Maukka ANSI calibration. The LH351D is probably still brighter than 219c version though, which I don’t have for comparison.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
SST-40 mostly.
Or maybe Luxeon V if you want to buy MCPCBs from Led4Power, since it is in the 4040 footprint.
Both are excellent 3V 5050 LEDs
Luxeon V is 4040 LED.
led4power.com
recieved your led today
will reflow them on weekend.
kaaaaaachinggggggggggggggg
Nico -.-
Theoreticaly I can made a mistake…
Could you send me macro photo of 351D 4000K from first butch together with “351D 4000K” from last one?
colors of luminofor of 4000K is very differ from colors of 5000K ones
If is really 5000K, I ll resend 351D 4000K to you.
Cheers
5000K has yellow luminophore white 4000K has a bit orange one.
Put them under UV light, like 365nm and they’ll show you if they’re a difference :
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Hence the dreaded “fried egg” beam…
Yellower center/hotspot, bluer outside/spill.
Okay, now I want some fried eggs…
The LH351D certainly doesn’t like larger SMO reflectors.
Mine arrived today
How does the tint on the new batch compare with the old? Is it greener or less green? The tint batch is supposed to be below the BBL?
Mine arrived yesterday, forgot to check the mail
Thanks!
Great, thanks for the tip.
Cheers
Light Measurement @ TutorVista.com
Cheers
Yes, I agree, the low CRI emitters are much more harsh to the eyes.
