GFS16 - Battery Indicator Tailcap Light & 1mR FET Tailswitch! (Rev B)
194 posts / 0 new
contactcr
Last seen: 1 day 18 hours ago
Lexel are yours also a FET switch? Does that allow the main current to bypass the switch?
Lexel
Lexel's picture
Fady wrote:
Nice work lexel!
1. If I put the board on my PSU and it is on I can connect it it is lightning up, reducing the voltage makes it go red and then turn off
But when I increase the voltage it does not turn on anymore or go from red to the other color.
I had the same problem & it turned out to be because of the high bleeder value I was using.
2. finally found it running the comparator on 2.8V LDO with a higher voltage from your voltage dividers at levels above the 2.8V did not work
running the Maxim 9022 with 2.8V reference from LDO and Vcc on battery supply works now
seems it can not compare higher voltages than its Vcc or close to it
The 9052 has a set Vref of 2.5V also a VCC of less than 2.5v will put the compactor to sleep, the 9039/9039 is set to 1.23V and the 9040/9043 is set to 2.048, which one are you using?
3. Vbatt x R4 / R3 + R4 =Vref
When battery level drops below 3.30V, Light up Red.
3.255V x 360K/270K+360K = 1.86V
I’m surprised you having it trigger at 1.86V, this is where I lost you.
4. 1.86V=2.8V*R8/(R7+R8)
R7=0,531*2.8*R8-R8
R7=182k
on 1S is max 4.35V, the calculated reference voltage should stay below 2.5V for 2.8V LDO
4.2V x 360K/270K+360K = 2.485V
Now I’m getting back on track again.
Whatever magic you did, I hope you’ll be releasing them for sale soon!!
The magic is use a Maxim 9022 which has no internal reference and only needs 2.8uA
The reference voltage is generated by a voltage divider off the LDO,
this is not so good when the LDO drops out of regulation at about 2.9V
(if you want the red burning quite down to a very low level as the reference voltage drops also, not sure what would happen)
positive is that the 9022 costs only 33% compared to the 9052
on the 9052 with a diode on vcc it could shut down at a higher voltage not draining the battery to the edge
with the 9052 you would need a 5V LDO for 2S lights, I am pretty much set at 2.8V for my lighted boards
you would run otherwise in the same probems like I had with higher compare voltages than the Vcc of the Maxim, as you cant run it on 8.4V
this would on the other hand give an option to run LEDs with less than 2.2V like green, red, orange and yellow as pair in series to cut current to half
especially on yellow and orange they get power hungry if you want them not dim
This is only lighted board I do not have a FET switch as local switch as the battery question is not solved,
yes basically having sort of button lithium rechargeable should work with a small coin cell if a diode is used to charge it
I asked the topic creator which battery and holder he is using but got no reply
The_Driver
The_Driver's picture
Last seen: 18 hours 23 min ago
There is no holder.
The battery is in the parts list in the first post:
Seiko MS412FE-FL26E
Fady
Last seen: 4 years 1 week ago
The_Driver wrote:
There is no holder. The battery is in the parts list in the first post: Seiko MS412FE-FL26E
Correct, the battery tabs just get soldered to pcb pads.
I tried everything with the FET switches including Lexel recommendation, the battery just dies in under 2 weeks.
Lexel
Lexel's picture
a solution would be the rechargeable version and a diode on the board, so the coin cell gets charged by the main battery if the voltage gets lower
https://www.mouser.de/ProductDetail/Seiko-Instruments-Micro-Energy/MS412...
Mouser and others dont ship those batteries outside USA
The_Driver
You can get them on Ebay from China as I did.
loneoceans
loneoceans's picture
Last seen: 7 months 5 days ago
Fady, you're right, you can change the resistor values to change the threshold voltages. Fady, are you also still having problems with the battery? It's fairly different to solder such a small package and you need to be very careful since too much heat can damage the cell. I've been using my lighted FET tailswitch in my main light for the past half year bringing it on many outdoor camping trips and it's been still working great.
Lexel, yes the MAX9052 is definitely suboptimal in quiescent current consumption of ~55uA typical. LEDs should draw on the order of ~200uA for 3 LEDs, so the comparator definitely is a large power hog. For your voltage regulator, you can use a better one I think, since there exists a lot of sub 1uA LDOs, and yes you can then use a much more jellybean comparator.
Thanks everyone for the support! When I have time I'll maybe do a quick update on the design.
www.loneoceans.com/labs/
- Next-gen Switching Drivers: Lume X1 and Lume1
- High Power Boost Drivers: GXB100 GAN 100W, GXB172 17mm 50W
- Others: GXF22, GFS16, GXB17 & GXB20 / Random items for
Sale / Manker MK38
Fady
welcome back loneoceans!!, I still have plenty of parts… ill attempt to build again and be careful when soldering the cell, on the other hand Lexel came up with an improved design based on your LED board, he added a LDO regulator to have a constant voltage drop across the bleeder thru the entire battery voltage range.. so led current is constant therefore voltage sensing can be easily calculated. check it out here.
loneoceans
Fady wrote:
welcome back loneoceans!!, I still have plenty of parts... ill attempt to build again and be careful when soldering the cell, on the other hand Lexel came up with an improved design based on your LED board, he added a LDO regulator to have a constant voltage drop across the bleeder thru the entire battery voltage range.. so led current is constant therefore voltage sensing can be easily calculated. check it out "here.":http://budgetlightforum.com/node/61671
Sounds good, well the main idea was to keep this board as simple as possible! I think the LDO is more for a constant LED brightness. The voltage sense inaccuracy isn't so much of a big deal if the bypass resistor is small <=1kR, and the voltage divider is large (and everything else is within spec).
Anyway it's true that the quiescent current for my Rev A one is a little large (>50uA), which is a large % of the LED current draw (~200uA for 3 LEDs but depends on brightness), so over lunch I did a little revision replacing the comparator with an ultra low I_q one, and added another ultra low I_q voltage reference. I don't mind the LED brightness changing, I suppose it's easy to add another v-reg, but I'd prefer the LED brightness giving me another estimate on battery voltage, instead of just losing this information in the Vreg as heat. LED side remains the same..
Total I_q is an order of magnitude less and now closer to 5uA + LED draw. More details soon when I have time!
Sale / Manker MK38
Fady
Cool!! Hope you release this on ashpark soon, correct, the LDO is for constant led brightness but it also allowed the use of a larger value bleeder without effecting the accuracy of the voltage reading since the compactor Vref was driven off the LDO divider circuit which also remained constant… on your Rev A board.. increasing the bleeder value to 1K increased the hysteriss by a lot and really messed up the accuracy but I’m glad you updating this design!!!
gchart
gchart's picture
Last seen: 5 hours 14 min ago
Awesome, I can’t wait to see what you’ve come up with! Please include a BOM when you write about it (I’m mostly curious about what v ref you’re using and how it’s wired)
loneoceans
gchart wrote:
Awesome, I can't wait to see what you've come up with! Please include a BOM when you write about it (I'm mostly curious about what v ref you're using and how it's wired)
More to come soon and I'll update the front page, but here's a link to the OSHpark PCB design.
https://oshpark.com/shared_projects/L27QGJFW
*note: this Rev B board has now been successfully tested and recommend for your own builds*
I rotated the PCB 45 deg because OSHpark tends to make snap-off cutouts on the 4 sides which can cause the part with the cut-out for the tiny battery to break. Hopefully this helps.
Total I_quiescent:
  • Comparators (two) - 75nA typ x 2
  • Voltage Dividers at 3V - 2 + 1.8uA (I suppose this could be even lower)
  • Voltage Reference at 3V - 1.5uA
Total: ~5.5uA
Previous I_quiescent = ~70uA, so this should be a >12x improvement in standby time after the LEDs turn off, and a good 30% or more in regular standby time with LEDs on.
Components:
  • R1a,R1b,R1c - 30kR 0402
  • R2a,R2b,R2c - 12kR 0402
  • Q1 - RZM002P02 or any other SOT723 P-Fet
  • Q2,Q3 - NTK3043NT1G or any other SOT723 N-Fet
  • D1a,D1b,D1c - Blue 0603 LED 150060BS75000 or colour of your choice
  • D2a,D2b,D2c - Red 0603 LED 150060SS75000 or colour of your choice
  • C1 - Any 10-100nF 0402 capacitor
  • R3, R7 - 619kR 0402 resistor
    note: You can also use R3 = 681kR or 750kR depending on the threshold voltage setting
  • R5 - 470kR 0402 resistor
  • R4,R6 - 1M 0402 resistor
  • U1 - MAX6007BEUR+T
  • U2,U3 - TLV3691IDCKR
Features:
  • Low I_q for longer standby
  • Simple
  • 3.32V low voltage threshold (R3 and R4, sensed with R4 as lower), depends a little on your driver bleeder resistor.
  • 3.01V turn-off threshold (R5 and R6, sensed with R6 as lower)
  • Careful component placement so no components hit the shelf on the LED side
  • Works well with GFS16 system
More to come soon!
Sale / Manker MK38
loneoceans
I had some time to put together the Rev B of the GFS16 LED Taillight board.
Here's how it looks like. The OSHpark boards turned out great, especially with the 45deg. rotation to avoid a chance of the oval-cutout breaking.
The board seems to work just as expected, and has an actual measured current draw of (5.6+-0.1)uA at a 3V LED Turn-off threshold, exactly as expected. This is over 10x LESS current draw than my Rev A version, so I think that's not a bad thing :). As the battery voltage drops, current draw should drop further.
Made a quick video of the board in action, and here's it with a 330 ohm series resistor and a power supply. The threshold voltages are about 3.4V and 3.0V for Low and Off respectively. Note that the bigger the bypass resistor, there will be a larger possible error of the threshold voltages from the voltage divider, as well as a larger hysteresis. This was discussed in some detail in previous posts.
I've also tested this with a 560R bleeder resistor across a Convoy S2+ standard driver, with R3 = 681kR. This gives a 3.55V low-voltage threshold (hysteresis at 3.75V).
Regardless, I just wanted this board to be simple and no frills. Tested all the way down to 0V and it fixes an issue with the previous Rev A design (where if the voltage drops below ~2.5V+, we were out of spec for the comparator, so the red LED could come on again dimly).  No such issues for Rev B.
OSH Park boards and parts list are available in the previous post as well as the first post.
Many thanks to all the support I've received on this forums, members who've had good success building their own despite the annoyingly small components, and feedback and suggestions for improvements! Again I understand it's not the perfect tail-light, but it does provide some simple extra features over a regular tailight board.
[Edit] - I understand the components are a little bit of a pain to solder by hand... when I have time I think I'll have a go at changing the components to be larger and easier to solder.
Enjoy!
Sale / Manker MK38
gchart
gchart's picture
Thanks for the update, LO!
DavidEF
DavidEF's picture
That looks really nice! Thanks for sharing it on OSH Park too! I’m hoping to see some of your driver designs going ‘live’ as well soon! Innocent
- The YKK Philosophy
Fady
Thanks loneoceans, I already have the boards on hand and the components are coming in today… but I wont have time to build and test until the weekend.. so ill be sure to come back and update!! Thaks again loneoceans!!!
clientequator
clientequator's picture
Last seen: 2 min 58 sec ago
Wow this update look quite good. Fady and others, have you built your own? I am thinking of combine this with my gxb172 build as well.
Sirius9
Sirius9's picture
Last seen: 1 day 11 hours ago
Hi loneoceans,
this is very nice project, I wanted to order couple of boards but unfortunately I usually don’t use reverse clicky switches Sad
Can your board be used for forward clicky switch without redoing components layout?
Because forward clicky swithc is a bit larget at about 12×12mm.
There are several lighted tailcap project and all of them are for reverse clicky and non for forward clicky…
Thanks
The_Driver
Fady had a big problem with the first rev of these switches. The battery kept dying. Loneoceans never mentioned if he solved this problem.
schizobovine
Last seen: 3 years 5 months ago
Tried to build one, and finally managed after destroying the first two batteries (puffed up, I assume because shorted). This was despite using kapton on both the battery and tweezers (in case it slipped off the battery a bit like it did for the first one).
The issue is that the side of the battery is still + so you have to scoot it as far as possible away from the negative contact on the board, else you can trivially solder bridge the battery (the fate of battery #2).
Third try was sorta the charm (as in it worked), but when I broke out the milliohm meter, it never did better than 33-35mOhm (it was near 50mOhm if when I clamped to the top of the 45% IACS unbridged spring from MTN). I compared a bridged plain Omten 1288 (and not one of my better ones, either) and got 19mOhm.
And then while trying to install in a light, the negative contact ripped right clean off the PCB from the most minor pressure against the battery (it was encased in two layers of kapton, btw). I’d liked to have run a test with spring bypassed for the most fair comparison, but after 3 batteries and nothing to show for it, I was done.
If you’re using a S2+ host, you’ll need to trade your metal washer bottom plate for something thinner, or the retaining ring for the spring assembly won’t sit flush with the shell (risking a short, depending on how much of the bottom of your battery is a contact).
If you could use the through-hole legs, this would be MUCH easier to assemble and try to use — and much less likely to rip apart just trying to install it.
This is a neat idea, but the battery choice / mounting is too fragile, making it practically unusable. Pretty disappointed. Sad
schizobovine
My (attempted) design change. Not yet assembled or tested, but idea was to switch out the LFPAK56 FET (so only uses the LFPAK33 FET) for a coin cell retainer that the same sized cell should fit (4.6mm). The pathway to load it has to be free(ish) of components, and I tried to keep the components out from under the switch otherwise. Comments/feedback welcome (trying not to be just a negative review, but rather a suggested direction for improvement).
https://oshpark.com/shared_projects/paPrb43Z
EDIT: Fixed error in first revision (via that was too close to the spring contact area)
clientequator
very good job schizobovine! I hope to see this project work for you.
In your new pcb, does this mean the switch is sitting on top of the small battery? Will this be bad for battery?
when my gxb172 driver is finished, may try to build this tailswitch also!
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 29 min ago
So, is it possible to only get the FET switch without the battery needed at all?
That would be really nice, as I only need very low resistance.
Lexel
Lexel's picture
this is not possible
BlueSwordM
Oh sorry I meant without a rechargeable cell.
Would it be possible to just use a non rechargeable cell?
clientequator
It is possible, but you may need to replace cell when it is empty. Rechargable battery avoid the need for this. I also have pcb order for this to finish my s2+ flashlight, hope it work out since schizobovine had a few problem with the battery..
WTF
Last seen: 1 year 8 months ago
Do you think a super capacitor could run the fet for very long?
It could be recharged quickly and most of the time my small convoys are on less than 10 minutes continuously anyway.
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 8 months ago
I wouldn’t write it off, I’ve got a project I’m in the midst of right now running the entire driver at the tail of the light off a capacitor bank charged up through the bleed resistor(s).
If I can run an entire driver off caps I would think someone could run just a FET, and just full-on/off in the same manor.
50ohms of resistance at the head (needs to be rated 1w or using a bank of 1/4 or even 1/10 Watters) and ~350uF at the tail has been working on the breadboard without issue. Time will tell when I switch to a real PCB with smaller package caps but folomov did it so I’m betting I can too.
I bring this up here cause like I said, I don’t think it should be impossible or even difficult at all to run the switch FET without a battery, just need to do a lil backyard EE’ing.
Oh also lumintop does it in the Ti Tool AAA (but their implementation isn’t all that great TBH)
BlueSwordM
I slept way too late yesterday after doing tons of work, so sorry if I sounded tired.
Come to think of it, couldn’t we just use a small super cap instead of a lithium-ion battery?
In this small size, and a lower value bleed resistor, it should work very well actually.
BlueSwordM
Ah! Found the battery from a Canadian supplier:
https://www.e-sonic.com/product-detail/seiko-inst-battery/ms412fefl26e.html
Nice Smile
Scratch that. You literally need to order 100$ worth of stuff to get it actually shipped to you.
Again found a replacement Smile
https://www.mouser.ca/ProductDetail/Seiko-Instruments-Micro-Energy/XH414...
