Test/review of Golisi IMR21700 3750mAh S35 (Black)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 47 sec ago
DSC_5204
Official specifications:
  • Size: 21 × 70mm
  • Model: 21700
  • Capacity: 3750mAh
  • Constant Current: 40A
  • Nominal Voltage: 3.7V
  • Charging cut-off voltage: 4.20±0.05V
  • Internal resistance: 30mOhm
  • Standard charging current: cc/cv(<=3A)
  • Cycle times: >800
  • Operate temperature: Charging: 0°C ~ 45°C), Discharging: -20°C ~ 60°C
Golisi%20IMR21700%203750mAh%20S35%20(Black)-info
A high current with fairly high capacity 21700 cell.
DSC_5203
DSC_5205 DSC_5206
DSC_5207
DSC_5208
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Capacity
The two cell has different capacity, but both has fairly constant capacity even at high load. One cell is close to stated capacity at low low, the other is a bit low.
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Temp-15.0
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Temp-20.0
Temperature is acceptable at 20A
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Temp-30.0
But at 20A I had to stop the discharge due to heat.
Golisi%20IMR21700%203750mAh%20S35%20(Black)-CapacityTimeHours
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Energy
Golisi%20IMR21700%203750mAh%20S35%20(Black)-PowerLoadTime
Golisi%20IMR21700%203750mAh%20S35%20(Black)-TripCurrent
Golisi%20IMR21700%203750mAh%20S35%20(Black)-Charge
Conclusion
The current and capacity is good, but I do not like that the cells have different capacity.
Notes and links
The battery was supplied by Golisi for review.
Compare to 18650 and other batteries
shadockan
shadockan's picture
Last seen: 1 week 17 hours ago
Thanks Henrik for the test.
I want a favor .
Can you test the Basen 21700 4000?
Comparing the positive pole with the photo ….., they seem to be the same.
In the test I made in Basen, I saw that the battery is capable of 15A performance without exceeding the temperature limits.
But some say they are the same battery.
I know Basen 21700 4000 is Lishen’s construction.
Do you know which company is making the battery used by Golisi, Ijoy and others?
HKJ
HKJ's picture
Sorry, but I do not have the Basen cell, and I do not know what cell is inside.
shadockan
shadockan's picture
Thank’s Henrik.
