EBL 14500s?
144 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 9 hours 7 min ago
EBL 14500s?
Anyone ever try them?
Got enough eneloops and LFP/LiFePO4 cells to last me probably forever (how many AA lights can a guy use at once, anyway?), wanted to try some Li 14500s just for s&g, and these popped up.
Amazon got ‘em, other places like The New Egg got ‘em, they’re generally favorably reviewed (not that it means much), but am curious if anyone here ever gave ‘em a whirl.
I ordered an 8-pak, so I’m already committed. Worse comes to worse, if they don’t fare well after testing, I’ll bounce ‘em back.
e1000
Last seen: 8 hours 30 min ago
Recently bought 4. They come in a plastic carrying case and are exactly 50mm. I haven’t had time to run mine down and see how many mAh they charge up to, they came with a good amount of charge. They’re about 2mm shorter than a 850mAh Nitecore 14500. See pics
https://imgur.com/a/RVPtE
https://imgur.com/a/dhszn
Blackbeard
Blackbeard's picture
Last seen: 1 day 9 hours ago
lol, I saw that 8 pack while browsing the sp10a page, seems like a good price but no idea of the quality
toddcshoe
toddcshoe's picture
Last seen: 21 hours 43 min ago
I have 4 of them. I don’t have a charger that can tell me the numbers yet. I did do a rundown test on 2 thorfires TG06S’s. Put fully charged fresh EBL’s in both of them, turned them on high and let em run until they got down to about 10 lumens or so. Took almost an hour and 15 minutes to get that dim. Battery voltage was at 2.81. Recharged them back up to 4.1 and they have been doing just fine. They maybe have 6 charge cycles on them by now. I’ll do another run down test tomorrow on them and see how they are holding up.
"Everywhere I go, there I am"
Lightbringer
Kewl, so they’re to-spec at least as far as size. Big Smile
Maybe the NCs are protected?
Hopefully when I get ‘em I’ll put ‘em through a torture test and see how they fare. As long as they’re not rewrapped HouseOnFire cells, and are at least close to the claimed 800mAH, I’ll be happy.
The LFPs that I got were claimed to be 600mAH but regged just a hair under 500mAH on my almighty Miboxer. ~490mAH or so.
So at least 750mAH would be what I’d expect, else I’ll p&m to the seller.
Lightbringer
‘Sokay, I’ll take one for the team…
Lightbringer
Hey, that’s encouraging…
I’ll run them through my Ope and get all 4 bays cranking at once, probably on the conditioning/refresh cycle.
Snoballz
Snoballz's picture
Last seen: 6 months 1 week ago
I picked up an 8 pack on Amazon. So far so good. I have no way of measuring drain, but did a capacity test on a single battery using a Zanflare C4 and got 840 mAh.
Lightbringer
That’s definitely encouraging, then. Big Smile
e1000
Yeah the NC is a protected cell
Lightbringer
There ya go…
Lightbringer
Bugger. Arriving the 16th-20th…
Zappaman
Zappaman's picture
Are these the ones you guys bought?
https://www.amazon.com/EBL-Li-ion-Rechargeable-Batteries-Flashlight/dp/B...
EDIT: My very first 18650s were EBLs. I bought them (with a charger) with an el-cheapo’ Ebay C8 head set— still working great after 6 years). They run today about 70% what they originally did (after being mostly sitting at 70% charge). But looking around lately as a flashaholic, I thought of them to be a decent, no frills option that maybe got within 80% of the advertised rating- on a good day.
So if these are HITTING spec- I’m buying a set!
Lightbringer… you’ll have to let us know how you do here after you run a few of these 14500s through one of your: almighty, bad-ass, wiz-bang battery torture devices. Silly
ZappaMan
Lightbringer
That’s the one.
Yeh, will put them through the wringer for a bit just to see how they fare.
pennzy
pennzy's picture
Last seen: 1 hour 17 min ago
If a cell’s capacity is as advertised , does that generally mean they are safe ?
e1000
I’m a bit new to this world but here’s my opinion.
If a company states a capacity and produces a product that matches those claims, it goes a long way to establish credibility. If they advertise something much higher but can’t deliver, then to me that already makes me wonder about what other claims they’re inflating or misrepresenting.
There’s also a factor of being realistic, if a capacity doesn’t seem to line up with competitors, there needs to be a good reason it’s so much better or worse. If 10 other manufacturers are making 14500 cells with similar dimensions and similar capacities, then there’s also more credibility that this product is at least within a good working range. The outliers worry me because if it sounds too good to be true, it usually is.
Apart from this, in my research you really don’t know until someone takes these cells apart. You can do a exterior visual inspection to get an idea, but there are ways to hide flaws, and that still doesn’t tell you a whole lot about how something is made on the inside.
Zappaman
Zappaman's picture
Or… we let Lightbringer blow up one of his chargers— that’s easier Blushing
Hey, and welcome to BLF e1000! Lots of smart dudes (and a few like me missing fingers/eyes) here to learn from. Silly
ZappaMan
e1000
Thanks for the welcome! Does seem like a lot of smart people, I hope to contribute. Hey if you’re still posting then you’ve got at least 1 more test left in ya!
Lightbringer
Just got ‘em today, will wring them out tonight to see how they fare.
Maybe longer, if I go through some “refresh” cycles.
Zappaman
Zappaman's picture
Wow… they must have been shipped from across the street— that was fast!
Eagerly waiting for your report Big Smile
ZappaMan
Barkuti
Barkuti's picture
Last seen: 1 day 18 hours ago
Quite likely from the same OEM under the wraps of Soshine 14500 900mAh and Nicjoy 14500 850mAh cells. After all, how many OEMs in the world are producing li-ions in this format and capacity range?
Good for up to ≈2A, 3A at most.
Kudos to the rating chosen by EBL.
Cheers Smile
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Lightbringer
Yeh, I tried getting the Shoshines, but shipping was obscene (and cumulative). Tried Sofirn, but they ostensibly can’t be shipped to the US. So tried these EBLs.
Look nice in the SP10As I got today, will torture a few tonight, see how they hold up. If well, will probably order another batch while the getting’s good.
Ain’t gonna be using anything more than a coupla amps in any 14500 light anyway, so I’m okay with that.
Pete7874
Pete7874's picture
Last seen: 13 min 40 sec ago
Which is probably what Sanyo UR14500P is good for as well, but at a much higher price.
I’d buy them if I had more use for 14500 cells. I typically prefer to just run NiMH cells in my single AA lights.
Zappaman
Zappaman's picture
That is the battery I run (but I’d never pay $7 a pop for one— got lucky and stole it off eBay on a slow auction for $2.40 shipped!)
I ALSO did order the Soshine 4 pack (retail) still coming— it was hard to drop $10, but shipping was (somehow) 10 cents, so I did it. But if Barkuti is right (and he always is), then I’m also dropping an order for two sets— before they are gone.
Give us some good news Lightbringer!!!
ZappaMan
e1000
They’re an Amazon Prime eligible item, and although not the best in the industry, Amazon return policies are pretty good.
Edit: BTW, I also bought the 18650’s and 26650’s for fun. The 26650’s are being used in a 2D maglite conversion and work well.
Barkuti
Barkuti's picture
Zappaman wrote:
… But if Barkuti is right (and he always is), …
Dunno dafuq has happened to GearBest but at least for me the shipping rates have somewhat increased, massively and namely for cells which usually kills the deal. By the way.
Cheers Party
Lightbringer
Here, too. Tried ordering 14500s from GB but shipping killed the deal. Hence the EBLs from Amazon.
Ordered 8 more BT 30Qs from FT, ‘cause 1) GB doesn’t list BTs, and 2) shipping is likely to be prohibitive, too.
So rather than ordering the wraps, tops, etc., from FT and the cells from GB, I just ordered the complete BTs directly from FT, with <2bux shipping! And price was comparable to GB.
Wellp, one’s loss is another’s gain… whaddya gonna do.
Nev
Last seen: 2 years 2 months ago
Pk cell 14500’s are a decent low cost cell, from alixexpess.
snakebite
snakebite's picture
Last seen: 1 week 5 days ago
very conservatively rated at 750mah.
i have seen several hit around 840@1a
Lightbringer
Did a 4-pak in my Ope… talk about cutting it close!
500mA up and down, 4 cells clocked in at:
801mAH, 801mAH, 817mAH, 800mAH.
All arrived at about 3.7V.
Zappaman
Zappaman's picture
KICK ARSE!!! I’m ordering two sets NOW!
You ARE truly the “Battery Dude” Lightbringer Thumbs Up Beer
ZappaMan
