Lumileds Luxeon V 4000K CRI70 LED color, CRI and output testing
47 posts / 0 new
led4power
led4power's picture
Last seen: 2 hours 23 min ago
I wonder how would this graph look if LED is under frosted optics? "Average" seems to be very close to BBL.
maukka
maukka's picture
You should take into account that most of the output is in the hotspot. The average is therefore still above the BBL.
Here’s a measurement with a Convoy diffuser for a very effective averaging (but not necessarily perfectly neutral as can be determined from the CCT change) and d-c-fix:
Duv value tells the distance from BBL. Still above in both.
ImA4Wheelr
Thank you for this and your other very informative test results.  I hope to someday understand much of your reports.
Here is what may be a very dumb question.  One of my favorite aspects of this emitter is how it picks up reds (my personal experience).  I, however, do poorly in tests where I have to sort colors.   So I don't put much stock in my experience.  Anyway, my question is:  Doesn't the -32 R9 mean the emitter has poor color rendition when it comes to reds?
Depending on the answer, can someone please help me reconcile my experience with the test results?
maukka
maukka's picture
The R9 value of -32 means that compared to a reference blackbody radiator at the same color temperature the spectral intensity in the deep red wavelengths (above about 640nm) is very small. This results in duller red colors, but that doesn’t necessarily mean that the reds are anywhere close to invisible or grey.
ImA4Wheelr
Thanks maukka.  Seems I need to get out tonight and do some side by side comparisons to help me reassess what I think I'm seeing.  I'm thinking the tint is what caused me to assume I was seeing reds better.
Speed4goal
Last seen: 1 year 3 weeks ago
contactcr wrote:
Technically its better to gradually heat it and cool it which is easy on my cook top
It very well might be idk never damaged a led doing that way. That’s the way old lumens told me to do it. Instead of exposing the led long exposure to hundreds of degrees the solder melts and is cooled to the touch in 20 seconds
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
contactcr
Last seen: 3 hours 7 min ago
All the datasheets spend like 2 pages going over the proper temp and time to do it so i assume there is something to it. You might have damaged one just not enough to make it not work Smile
Speed4goal
Lol very true. I have no way of measuring output. Only current draw at the tail or led I’ve used my iron a couple of times. But takes to long for me. I’m sure there is something to it.
maukka
maukka's picture
Added output measurement to the original post.
The_Driver
The_Driver's picture
Last seen: 1 month 5 days ago
Super efficient!
It would be interesting to see at what current the efficiency peak happens. Every LED has such a peak. Sometimes very small LED actually have a better maximum efficiency compared to larger ones .
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 11 hours ago
Damn. It has the efficiency of the Samsung LH351D at all levels.
The low VF is appealing though compared to the LH351D.
That is great.
maukka
maukka's picture
It’s very low, since it starts dropping already at above 10mA.
maukka
maukka's picture
I need to get a precision source measurement unit to do and trust these, but just for the hell of it, let’s go lower. Wouldn’t hurt to test in a smaller sphere either, even though the meter still read 12.3 lux at 1 milliamp so it should be somewhat reliable (minus the 1 lux that seeps in through the heatsink gaps). There’s still some uncertainty which is apparent when you compare the 10/20/30mA results to the previous tests. Shouldn’t heat enough to create a 3% discrepancy at 10mA.
djozz
djozz's picture
Last seen: 3 hours 22 min ago
Except that at the lowest currents the
efficiency goes way over the theoretical max of white leds (~300lm/W) Party
(did not check source for reliability Innocent )
http://www.archlighting.com/products/leds-and-drivers/the-truth-about-how-efficient-a-white-led-can-be
maukka
maukka's picture
djozz wrote:
Except that at the lowest currents the efficiency goes way over the theoretical max of white leds (~300lm/W)
That’s why I said I don’t trust the measurements. The PSU can’t control such low currents. I’ll check later with a bench DMM what’s the lowest possible.
Bocian
Bocian's picture
Last seen: 11 hours 7 min ago
S2+ mod, luxeon V 4000K on board with TIR wide optic. 4,18A 100% mode, with 2.0 extended driver
First photo shape of the beam:
BTW, maybe the topic is not 100% convergent but it is testing output in practice Big Smile
