I cannot agree with the “stop buying LiitoKala” thing. Judging others is no good, that is not the vibration of the original Creator which is unconditionally loving. This is something I've finally come to understand and my purification endeavour finally started.
Cheers
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
As I've said other times, AliExpress sellers can change their store names anytime. Clearest example I can show you is store number 1721160. I can recall it being named Colaier Direct Sales Store, then AM battery Store, later it was LiitoKala 0ficcial Store (notice the 0 instead of an O) and as you can see it now is Charger Battery Store. Suffice to say it is run by a crook.
Cheers
Settled for 192 led, the estimated shipping is conservative, final shipping to the US for me was $1.94, -$1 new user discount, final price $23.53
So thanks for the deal! hope this one actually ships
9 days since I ordered something from 192led and no sign of the tracking number…
Ok, after forgetting about it a while, its been two weeks and the tracking number is not active. The contact page promising 24 hour response does nothing, tried several times, and the live chat never works.
This is just a fraud site, guess add 192led to the list, have to file a paypal dispute now. Thought people recommending things in this thread had actually used the stores before, guess not.
Zeroair tested one variation of these “30Q” Liitokalas from Aliexpress.
Spoiler: was not Samsung 30Q. Good capacity, useless in high current applications.
Good chance they are LGF1 3350mAh 4.8A cells. Looks just like them, 4 posts and all. The LGF1 is commonly used in powerbanks and various battery packs. In bulk, they cost well under a dollar each.
If they just market the cells as what they really are then there would be no problems and probably have a lot of happy customers. They appear to be way better than xxxFires and also suitable for low drain applications. Then again almost anything is better than xxxFires, excluding Windyfire and maybe a few others.
They can do it this way and make way more profit without facing consequences. Honestly the majority of their customers probably don’t even know (or want to know) that the cells they received are counterfeit.
Until now, I only bought from aliexpress from all the liitokala stores.
- 6 pieces 26650 black liitokala (very good)
- More than 20 pieces 18650 (Panasonic 3400mah cells, samsung 2600mah)
-I have to get home and 2 pieces LG 3000mah.
Until now, I had no problems. XHP70 does not work with turbo mode when using Panasonic 3400mah, but when using samsung 2600mah it works
Unfortunately, we received 5 liotokala (panasonic) 3400mah batteries with PCB, and one of them fired in the charger.
See the last one star review. I also put pictures.
Neat MOSFET gate feeding strip short-circuit.
However, we still do not know what sort of cell is that. Could you please completely unwrap and carefully photograph one of the cells, Coman? So we can see its actual flat top clearly, and the cylinder markings if present.
Cheers
Oh god... The protection circuit actually failed to open. …
What makes you think the protection circuit failed to open? I am pretty sure it opened up.
What happened there is the original cell wrap got torn below the cathode to anode nickel strip, causing a short-circuit. That's all folks.
Cells protected with P-channel MOSFETs do not have this problem. It has to do with the way cells are because the whole can body apart from the inner flat top is at cathode potential.
Cheers
This Liitokala fraud is unacceptable. Should this forum ban all Liitokala ads and sales here? I think it’s not similar to fake lumens number of flashlight. This is misleading buyers into believing there are genuine branded cells under Liitokala wrapping.
This Liitokala fraud is unacceptable. Should this forum ban all Liitokala ads and sales here? …
No one forces you to buy LiitoKala. This problem namely has to do with the battery market and spurious AliExpress. Many independent sellers under AliExpress umbrella, and they're not the same thing.
Right now I am not buying Liitowhatever cells because of deception. It has to do with them liking to overstate wrap figures and falsifying brand names. Very much like what vaping cell rewrappers do blatantly.
Cheers
Yep.
They pulled a bait and swap on the buyers.
I think we should push it a step further.
How about we stop buying any of the Liitokala batteries? Even 26650s and 21700s?
That might stop the bad behavior. Maybe.
Cheers
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
Yeah. I didn’t actually mean all of their products though. Their chargers are good.
All this talk about Liitokala has got my curiosity up.
I have found two different websites & two different stores on AliExpress. They are listed below.
Has anyone found any other “Littokala Stores” besides the two I have listed below??
https://m.aliexpress.com/store/activities/seller/storeHomeFromAms.htm?st...
These are the two different websites I found:
Below is some of the info & contact info that came from the websites:
Liitokala Power Company
http://liitokala.com.cn/
ShenZhen LiitoKala Power Co.,LTD(ShenZhen charger factory)
Add: The 6F building 1,MaoBang industrial Area,No.8 Lingwu Industrial Road Junzibu, GuanLan Town,Baoan District,Shenzhen City,Guangdong,518110,China
Contact: Ashley zhang
TEL: +86 13760394452
website: www.liitokala.com.cn
Email : sales@liitokala.com.cn
Office hours: (HK Time) Mon – Sat: 9:00am – 22:00pm
LiitoKala Power Co.,LTD(DongGuan battery factory)
Add: No.38 Changsheng Road, Tiantangwei, Fenggang Town, Dongguan City, Guangdong,523690,China
Contact: ZhangNi
Email and Skype : liitokala@126.com
HongKong LiitoKala Power Co.,LTD(Hong Kong office)
Add: room 01,21/F,Prosper Commercial Building,9 Yin Chong Street,KowLoon,H.K
Contact: Cherleen
Email : liitokala@126.com
LiitoKala belonging to shenzhen XinShengLi power co., LTD
http://www.liito-kala.com/
Add: 6th Floor,Ling wu industral Road 8 D,Shenzhen Guanlan Junzhibu,Guangdong province,518110,China
Tel: +86-13417331508
Email:emily@liito-kala.com
Office hours: (HK Time) Mon – Fri : 9:00am – 6:00pm
Purchase link:
https://liitokala.aliexpress.com
LiitoKala Official Flagship Store [Store #133859] https://m.aliexpress.com/store/activities/seller/storeHomeFromAms.htm?st...
(from http://www.liito-kala.com/ )
Liitokala Official Store [Store #217753]
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
I found another one….
Cheers
/\ ….. Thanks for sharing that info & link maukka. .
Today I received an order of 12 30Q for $ 34.22.
Possibly they are the same ones that tested Zeroair.
First tests.
- four leg positive terminal.
- between 3.73 and 3.90V.
- between 45.6 and 46.3g.
I would have been surprised if I had received legit cells.
I will update…
Yeah, I don’t like zeroair’s conclusions.
He should have said not to buy these cells at all. I don’t give money to fraudsters like the folks at Liitokala.
Four positive terminals means it’s a no go.
And why is there a 0,17V difference between cells? That’s not good…
@RobertB, it’s an LG F1L.
However, there have been reports of cells leaking, having extremely high internal resistance, high self discharge(3 months!), etc.
I would not risk it.
You can still dispute it. NCR18650B is Panasonic’s part number and nobody else’s. And the listing says “Original”
I know what it is, I have several of them from a powerbank. Haven’t heard or seen those reports
using that @xxx, doesn’t page anyone.Sorry, just wanted to precise it’s an F1L, not F1. Might have been a bit too precise :\
If you want to get real precise call it a LGABF1L. In the mean time, I’ll call it an LG-F1
Those F1s are apparently really cheap in bulk too. I can imagine it would be pretty profitable to re-wrap and sell some for certain shady dealers…
https://www.aliexpress.com/item/4PCS-LOT-Original-18650-NCR18650B-3-6V-3400mAh-Rechargeable-Li-ion-Protected-Batteries-with-PCB-For/32304934813.html?spm=2114.13010708.0.0.3a994c4dM6iWBD
When did you submit the original review?
I can’t see which one it is.
23 Nov 2018 09:43 , and feedback 26 Nov 2018 11:56
I’ve lost faith in using them … including the charger.
Cheers
Oh god… The protection circuit actually failed to open.
A protected cell got damaged by its own protection circuit.
That’s even worse if a cell would fail, as it would shut down by itself.
A protection circuit failure can take a down an 18650 with it, which is way worse.
Scary. Good thing it didn’t start a fire.
Cheers
Some related information:
Cheers
