Hello,
I already have the BLF GT, and after VOB’s video, I was planning to mod it with an XHP-70.2. With the MF04 still available for a good price, it got me thinking on which light would be a better host.
Does anyone know or have an opinion?
I’m not sure I want to do the FET driver mod as I feel like I will be satisfied with dome sliced led at the 4.5 amps provided by modding the resistor on the existing GT driver.
I feel like the lower amount of heat would allow for better sustained run time and allow the light to operate continuously possibly? I believe VOB’s temperature readings showed that the FET driven GT is really only useable for a couple of minutes due to heat.
Could the resistor modded GT maintain the 6,000 or so lumens after heat production/gain equilibrates? For how long on 8 of the Samsung 35E(is 30q better at this amp draw?)?
Assuming the MF04 driver(which I am assuming is also a buck driver?) can be modded similarly, will the GT(with 8 cells) or MF04 allow greater sustained output taking into account heat dissipation and battery power? The mf04 isn’t quite the GT killer it was promised to be in terms of throw right? So the reflector/throw attributes should be similar?
Thank you
GT, no doubt.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
Anyone offended by my signature please fill Complaint Form. Thank you.
If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
hmm… if you can do your own upgrades… my gosh man… CFT90 in the BLF GT and your good to go
Pussycat pussycat where are you? What's up pussycat meow meow meow. "Tom Jones"
I have already modded my GT for XHP-70.2 and a FET driver and is a monster…
I have fitting buck drivers for both 12V 6-7A makes sense
new MOSFET is better at those currents, also the inductor can get a smaller value
Modding a 25mm or 32mm MCPCB to 12V works on both lights
Modding the original driver makes not sense if you do not upgrade a lot components and change the switching frequency
I have calculated the resistor modded does not look good at high currents
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: overview of sizes and types
DD+AMC based drivers Anduril or Bistro OTSM 12-24mm, S42, 24-30mm L6, Q8, MF01(S), MT03, TN42
Anduril or Bistro 8A buck driver for 20-30mm, MF01/02/04, TN40/42, Lumintop GT, MT09R
UVC and UVC+UVA drivers
programming key
Remote switch tail DD board with FET
Aux boards:
Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
Could you explain that in a slightly more simplified manner?
I don’t really understand it.
Can there be different output levels using FET?
Thanks
I’m trying to keep up here, reading about the CFT90 and XHP70.2 output LM’s , voltage , amps, etc… If you could cool the CFT90 and use 8 × 21700 batteries, would it substantially produce more lm’s that the XHP 70.2 with the same configuration ? I’m tyring to put together a long thrower with a single led and using MT35 PLUS aka MF04 as a host, water cooled of course. Any suggestions ? And I will need the highest amp driver that will not burn up the led or me…..
Water Cooled MT35 PLUS RE-MODDED------MT35 Plus with SBT90.2 mod ( GT90 kit from Texas Ace )
7th annual BLF/O-L contest Haikelite MT07 upgraded-----8th annual BLF/O-L contest “SKELETON”
Water Cooled 20K lumen POT LID LIGHT------ Cyclops 18M cd flashlight Mod------Q-beam mod to led
Convoy 4x18 Luminus 90.2 mod with 86mm reflector
Think outside the box too long , cannot find your way back in
What size has the MCPCB of the MF04? The same 28mm as the MF02?
Does anyone know?
