Found a Quality Battery Resistance Tester
98 posts / 0 new
klrman
klrman's picture
Really nice looking unit until I saw the price!
https://www.itm.com/product/hioki-bt4560-battery-impedance-meter-5v?gclid=EAIaIQobChMIjt3ivN3U2wIVD9VkCh3ESAheEAYYASABEgIWLPD_BwE
Is there any reasonable tester that is fairly accurate without costing an arm and a leg?
AlexGT
AlexGT's picture
Last seen: 19 hours 1 min ago
WOW, that is expensive!
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 36 min ago
@kirman, yes, yes there is something that will only cost you a toe and works very well:
https://www.ebay.ca/itm/Battery-Resistance-Voltmeter-Internal-Impedance-...LCD-Rechargeable-SM8124A/273104104104?hash=item3f9645eaa8:g:BEIAAOSwWmNapAyf
You are in luck, as that one is pure quality, with very nice probes. It has been tested, and work very well.
klrman
klrman's picture
BlueSwordM wrote:
@kirman, yes, yes there is something that will only cost you a toe and works very well: https://www.ebay.ca/itm/Battery-Resistance-Voltmeter-Internal-Impedance-... You are in luck, as that one is pure quality, with very nice probes. It has been tested, and work very well.
Thanks BlueSword, just what I needed.  Never heard of it before but if you say it's good, I want it!  Update, just ordered it. Another nice addition to my collection, thanks.
BlueSwordM
There is a review of it by Daromer, one of the most trusted people on DIYPowerwalls, that says it is great:
https://www.youtube.com/watch?v=w5GFp8QBxP8
In fact, the version he reviewed is actually one which is slightly less accurate than the one I linked.
klrman
klrman's picture
Very nice and informative video, thank you.  Looks like a real decent tester, I'm looking forward to this one, especially after seeing him test and compare it.  The one you linked to has nicer probes too.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 26 min ago
Hioki is Japanese and made in Japan still thus the price is high. They also make great Multimeters.
d_t_a
Last seen: 33 min 45 sec ago
klrman wrote:
BlueSwordM wrote:
@kirman, yes, yes there is something that will only cost you a toe and works very well: https://www.ebay.ca/itm/Battery-Resistance-Voltmeter-Internal-Impedance-...LCD-Rechargeable-SM8124A/273104104104?hash=item3f9645eaa8:g:BEIAAOSwWmNapAyf You are in luck, as that one is pure quality, with very nice probes. It has been tested, and work very well.
Thanks BlueSword, just what I needed.  Never heard of it before but if you say it’s good, I want it!  Update, just ordered it. Another nice addition to my collection, thanks.
Would that be better than the Vapcell YR1030 battery impedance tester reviewed by HKJ?
http://budgetlightforum.com/node/56582
BlueSwordM
No, about the same.
The one I linked is more straightforward to use, and easier to find.
Nicer probes too.
ActiveAl
ActiveAl's picture
Last seen: 4 months 1 week ago
BlueSwordM, thanks for the info - just ordered one of these. It is frustrating getting a wide range of IR reading on my LiitoKala and MiBoxer chargers when evaluating Li-ion batteries!
tatasal
Last seen: 1 hour 30 min ago
For those who want free shipping from China, you may check this out:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_2018062723...
adam7027
Last seen: 1 month 14 hours ago
Thank you for this find, I will order one as well.
I am also frustrated with IR reading battery chargers (but at least, when I insert a battery, I have a rough measurement of whether I inserted the battery with proper contact, or not – which is good for making charging termination faster for a given current limit).
Btw, you might want to include BlueSwordM’s and tatasal’s links into the original post as an update. I’m usually not the TLDR man, but that would add convenience Wink
ActiveAl
ActiveAl's picture
Mine arrived yesterday and I immediately did a series of measurements to compare suspected fake 30Q batteries to baseline 30Qs. Results are posted HERE (comment #283) in the Massive sale on 18650s in the Littokala Aliexpress store! thread.
I have to admit that this Battery-Resistance-Voltmeter-Internal-Impedance-Meter-LCD-Rechargeable-SM8124A exceeded my expectations. The performance I saw exceeded that demonstrated in the YouTube video: Internal resistance test of SM8124A - Is it worth it. The improvement may be due to a difference in probes. My meter also came sans case. Thank you BlueSwordM for providing this tip on a realistic IR meter!
Zebretta
Last seen: 1 week 3 days ago
Just ordered one. Should have it in a few weeks from now. Thanks for all the feedback.
After mine arrives I intend to take IR readings of batteries from the SM8124A but unlike other reviews which showed only battery IR readings, I intend to post tables comparing the IR results I get from My MC3000 and IQ338XL vs the SM8124A on the same batteries to show how far off (or how close) the chargers were to the readings from the SM8124A
The MC3000 I have gives IR readings on the same battery that are often way off from the IR readings I get on the AccuPower IQ338XL although both seem to stick to their guns and present fairly consistent readings for those same batteries on subsequent test cycles. An EE could perhaps use the SM8124A to calibrate the chargers by adding or changing resistors as needed.
I realize that every charger could be slightly different in the IR readings it gives but this should provide a baseline or at least the results from one for general purposes.
I tend to believe the readings on the MC3000 more so than the IQ338XL. But this new device should help resolve the mystery.
In any event….new toys are always fun Smile
A word of note: The SM8124A shown in the video review on YouTube in the link above is obviously different than the one received when ordered on ebay.
The ebay seller does not provide a case and the lead tips are different. What this indicates I do not know. A knock-off maybe?
Or maybe this is the difference between the SM8124 and the SM8124A ??
Some show dual tips on the probes while others show a single, more stout tip.
klrman
klrman's picture
Zebretta wrote:
Just ordered one. Should have it in a few weeks from now. Thanks for all the feedback. After mine arrives I intend to take IR readings of batteries from the SM8124A but unlike other reviews which showed only battery IR readings, I intend to post tables comparing the IR results I get from My MC3000 and IQ338XL vs the SM8124A on the same batteries to show how far off (or how close) the chargers were to the readings from the SM8124A The MC3000 I have gives IR readings on the same battery that are often way off from the IR readings I get on the AccuPower IQ338XL although both seem to stick to their guns and present fairly consistent readings for those same batteries on subsequent test cycles. An EE could perhaps use the SM8124A to calibrate the chargers by adding or changing resistors as needed. I realize that every charger could be slightly different in the IR readings it gives but this should provide a baseline or at least the results from one for general purposes. I tend to believe the readings on the MC3000 more so than the IQ338XL. But this new device should help resolve the mystery. In any event....new toys are always fun Smile A word of note: The SM8124A shown in the video review on YouTube in the link above is obviously different than the one received when ordered on ebay. The ebay seller does not provide a case and the lead tips are different. What this indicates I do not know. A knock-off maybe? Or maybe this is the difference between the SM8124 and the SM8124A ?? Some show dual tips on the probes while others show a single, more stout tip. !https://images-na.ssl-images-amazon.com/images/I/51GFo-sHHBL.jpg!
I'm pretty sure the newer version is the probes with two ends that we got.   Also, by looking looking at many sellers, looks like the blue case and box come with the older version and they tried to keep costs down by just sending the unit itself on the newer version.
Zebretta
That helps. Thanks.
Was just wondering why the difference.
BlueSwordM
@klrman and ActiveAI, thanks for the compliments.
I should get myself a resistance tester, but I already have a 4 wire tester that does the job quite well.
slowtechstef
slowtechstef's picture
Thanks BlueSwordM for suggesting a SM8124A battery resistance tester. Today mine arrived from AliExpress.
It came with a pouch by the way, although another than displayed in the sellers picture. My 30Q test 7 mOhm and my VTC6 test 6 mOhm. I guess these cells (both from nkon.nl) are real Wink
ActiveAl
ActiveAl's picture
slowtechstef wrote:
Thanks BlueSwordM for suggesting a SM8124A battery resistance tester. Today mine arrived from "AliExpress":https://nl.aliexpress.com/item/Big-Discount-Brand-New-SM8124-Internal-Ba.... It came with a pouch by the way, although another than displayed in the sellers picture. My 30Q test 7 mOhm and my VTC6 test 6 mOhm. I guess these cells (both from nkon.nl) are real ;-)
Did it come with the new two-prong probes? This seller is displaying pictures of both the old and new SM8124A models together. Thanks!
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 months 3 days ago
Can anyone please post a link to the SM8124A we can 100% trust? I mean there are how many sellers on AliExpress….six, seven?…who offer this nice device, sometimes with different brand names, sometimes without the “A”, sometimes with two cables on both probes, sometimes just one cable. I find it hard to decide whom to trust.
I was unfortunately unlucky with some of these Dolidada batteries…claimed to be IMR-55A cells (like Shockli/Keeppower) but they turned out to be of rather poor quality with much less capacity and even less power drain capabilities.
ImA4Wheelr
Good question.  I ordered one from the same ad as slowtechstef.
Thank your klrman, BlueSwordM, tatasal, and others for your contributions to this thread.  Been wanting a decent budget IR meter for a good number of years now.
contactcr
Last seen: 1 day 18 hours ago
I think it’s worth mentioning that the resistance values from this $50 AC tester should not be compared to other chargers and things that give resistance.
AC resistance measurements are pretty far apart from DC load resistance measurements.
Article:
http://batteryuniversity.com/index.php/learn/article/how_to_measure_inte...
So while this device is still useful it is not giving you the same measurement you might find in other sources. Also, I don’t think it is as good of an indication of the max discharge a battery can sustain. (like what HKJ or Mooch are giving you)
BlueSwordM
+1
I forgot to mention. The resistance measurements are at AC 1kHz sine wave. So while accurate, the resistance numbers are often measured to low.
A 4-wire constant current tester is the only way to measure the real DC load resistance measurement.
ActiveAl
ActiveAl's picture
contactcr wrote:
I think it's worth mentioning that the resistance values from this $50 AC tester should not be compared to other chargers and things that give resistance. AC resistance measurements are pretty far apart from DC load resistance measurements. Article: http://batteryuniversity.com/index.php/learn/article/how_to_measure_inte... So while this device is still useful it is not giving you the same measurement you might find in other sources. Also, I don't think it is as good of an indication of the max discharge a battery can sustain. (like what HKJ or Mooch are giving you)
I read through the article you linked and it was helpful. Thanks. Fortunately, there is a lot you can do with AC resistance measurements, such as:
  1. Measure new cell when you first get them, and then take periodic reading afterward to monitor their health.
  2. Compare measurements against the battery's  datasheet to determine if it is in specification. For example, the Samsung 30Q datasheet identifies a typical 1 kHz AC resistance specification of 13.13 ± 2 mΩ. The  SM8124A  I recently purchased measured my six Orbtronics 30Qs with an average resistance of about 11.5 mΩ (See Table 2.), which is within the datasheet specification. I was shocked that my $50 AC tester was able to provide measurements with this seeming accuracy. Perhaps this is a one-off fluke.
  3. Compare a known battery with one that is suspected of being a fake. For example, if a battery measures considerably more AC resistance than a real 30Q, then it is probably not a 30Q.
Update: I saved this post too quickly and had to make edits. Thanks!
klrman
klrman's picture
ActiveAl, those numbers are really close to the spec sheet. I would say more than good enough for a $50 tester, especially considering the consistency of the readings which is what I really like about it.  My numbers are higher on my cells as they are all protected, but soon my 30Q's will arrive and I can see what numbers they read.
klrman
klrman's picture
FlashTom wrote:
Can anyone please post a link to the *SM8124A* we can 100% trust? I mean there are how many sellers on AliExpress....six, seven?...who offer this nice device, sometimes with different brand names, sometimes without the "A", sometimes with two cables on both probes, sometimes just one cable. I find it hard to decide whom to trust. I was unfortunately unlucky with some of these Dolidada batteries...claimed to be IMR-55A cells (like Shockli/Keeppower) but they turned out to be of rather poor quality with much less capacity and even less power drain capabilities.
I have the latest model with the two prong cables that BlueSwordM linked in post #3 https://www.ebay.ca/itm/Battery-Resistance-Voltmeter-Internal-Impedance-Meter-LCD-Rechargeable-SM8124A/273104104104?hash=item3f9645eaa8:g:BEIAAOSwWmNapAyf
ActiveAl
ActiveAl's picture
I also purchased mine from the same ebay seller (i.e., tangzhimin1008) as Kirman (link above). We got the new model with the double-pronged probes and, so far, it is exceeding my expectations in performance. I used it to determine that six 30Qs from the LiitoKala Factory Store  were probably fakes. In this endeavor, my SM8124A  readings were very consistent and reasonable. See Table 1 and Table 2 in this post for my data. Note that the average reading for the six real 30Qs (Table 2) was within the typical 1 Hz AC specification of 13.13 ± 2 mΩ  given in the 30Q data sheet. This blows me away.
The cheapest purchase alternative for a SM6124A appears to be from this Ali Express Store. But there is no confirmation that they are selling the new model. Suspiciously, this store is displaying pictures of both the old and new models.
Lux-Perpetua
Did you get the SM8124A with the two prong-probes or the predecessor without the „A“ and single-prong probes?
Lux-Perpetua
Has HKJ already put an eye on this fine device?
ActiveAl
ActiveAl's picture
I sent the following message to  the AliExpress store in question (NewBeautifulLife Store, #1183073) last night:
Reference: Battery Resistance Voltmeter Internal Impedance Meter LCD Rechargeable Battery Impedance Internal resistance Tester SM8124A
Are you selling the newer version of this meter that has the two-pronged probes, or the older version that has the thicker single probes? The reason I ask is because you have both versions pictured on the product page. Thanks!
And got the following response this morning from Summer Sun:
Just the new version SM 8124A with two pronged probe.
After receiving this documentation, I would be willing to take a chance on ordering from them to get the best known deal on a SM8123A. Thanks!
Lux-Perpetua
Thanks for asking. I just bought one via your link.
