[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
3422 posts / 0 new
arow55
Last seen: 5 hours 4 min ago
Lonelydad wrote:
I’ve been carrying one of my C01S lights in my pocket for months, and have never had the head come off. How often does this occur to you guys?
Never
shirnask
shirnask's picture
Last seen: 12 min 16 sec ago
Never for me
arow55
Like the new version of co1 better than old one.
Hugh Johnson
Hugh Johnson's picture
Last seen: 1 month 1 week ago
I also like the newer 3,400k Sophia better than the 3,200k Yuji.
The Yuji Tint seems a bit “muddy” by comparison and my perception is that cri is lower.
gravelmonkey
Last seen: 14 hours 30 min ago
Stoopid question – I’ve searched but can’t find the answer, how does one remove the ‘driver’ and LED from these?
I’d like to scuff up the LED on my C01R but can’t get it out!
Cheers!
Unheard
Unheard's picture
Last seen: 8 hours 22 min ago
supreme wrote:
How is the beam of the C01 red supposed to be? Mine has a small hotspot, very tiny corona, no spill. There is zero flood. Not sure if this is normal since the hotspot isn’t bright enough to illuminate anything.
It’s normal, except the hotspot is quite bright on my samples. It’s just very narrow.
Smile, you cannot kill them all.
Unheard
Unheard's picture
It’s glued. Brute force helps.
gravelmonkey
Whoops, turns out it was potted, tore the PCB off. Bugger.
Unheard
Unheard's picture
Potted? Then it’s a C01, not a C01R. Big difference.
supreme
Last seen: 7 min 13 sec ago
Like this?
Unheard
Unheard's picture
Exactly.
Henk4U2
Henk4U2's picture
Last seen: 5 hours 54 min ago
Would be nice if Sofirn would reserve a small batch of 5mm drivers to sell separately to the unlucky.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Unheard
Unheard's picture
Yes. And some hosts. OTOH, they’re still at $3.99 (white) and $4.49 (red). I think they are gifts to the community and wouldn’t expect any kind of service or spare parts.
gravelmonkey
Ahhh I was under the impression the red 5mm led version was C01R, I now believe the C01R is actually the ?SST ?XPE Version!
Ah well, perhaps it will save someone else’s light
iamlucky13
Last seen: 56 min 21 sec ago
I previously posted this at CPF, but might as well reformat it for BLF’s forum software.
Sofirn C01 Family Comparison Table
Model (Edition) LED Modes Max Output Other
C01 (2018 Edition) Yuji BC 5mm – 3200K or 5600K, 95 CRI 1 ~5 lumens Potted driver, 3 body colors
C01 (2020 Edition) Sophia 5mm 3400K, 95 CRI 1 ~5 lumens 5 body colors, some colors potted
C01 (2020 Edition, red) Unknown 5mm deep red (670nm) 1 Unknown Red body, potted?
C01s (original) Luminus SST-20, 4000K, 95 CRI 2 (high, low) 100 lumens 3 body colors
C01s (BLF and current edition) Luminus SST-20, 4000K, 95 CRI 2 (low, high) 100 lumens 6 body colors
C01R (original) Cree XP-E2, photo red (660nm) (LMH or HML configurable) 36 lumens Red body
C01R (current edition) Luminus SST-20-DR deep red (660nm) 3 (LMH or HML configurable) ~36 lumens? Red body
Common features:
  • AAA-powered (Lithium-ion not supported. Unsure if it’s been tested)
  • Twisty user interface
  • 71.6mm long x 14.5mm diameter
  • Approx. 15 grams weight
  • Tail stands
  • 5mm x 3mm Magnet pocket and 1mm x 6mm tritium slot.
gchart
gchart's picture
Last seen: 1 hour 49 min ago
Well… somehow my kids have managed to bust the inductor on my 3-month-old non-potted orange C01. The body is nearly perfect still, so either is was just destined to happen or that C01 took just the wrong drop. :-/ I can’t complain for the $4 I spent on the light, but I guess that goes to show that being potted is certainly a benefit.
iamlucky13
I think the battery hammering on the bottom of PCB’s during head down drops flexes the PCB and can crack solder joints. Drivers with springs on them are better protected from this, but space and cost are reasons for not putting a spring on the head side of a light like this.
My Sunwayman R01A (unpotted) died from a head-down fall from about 5 feet.
jon_slider
jon_slider's picture
Last seen: 5 hours 32 min ago
for future, the C01 w 5mm 670nm Red LED can be scuffed up without removing it from the light, since there is no glass lens.
imo, the C01 Red is pretty useless, has a low output, and terrible beam.. scuffing just makes it dimmer
I do not recommend the single mode C01 Red 5mm 670nm LED,
otoh
I Highly recommend the C01R xpe/sst 660nm red LED, it has a great beam, with 3 well spaced modes.
gchart wrote:
my kids have managed to bust the inductor… destined to happen or … I guess that goes to show that being potted is certainly a benefit.
sorry to hear the light is broken
would have thought djozz son would have managed to break the unpotted C01 he tested…
Either your light was destined to fail, or your kids have more destructive skills than djozz’s boy
iamlucky13 wrote:
I think the battery hammering on the bottom of PCB’s during head down drops flexes the PCB and can crack solder joints….
sad.. maybe it can be repaired, if its a solder joint failure…
gchart’s failure sounds like a broken component, not just a solder joint.. not sure
fwiw, the body colors of the 2020 C01 w 5mm 3400k High CRI Sophia LED that are potted are the
*black
* and *green
* models
gchart
gchart's picture
Yeah, the ferrite broke in half. I’ll likely pick up a new inductor on my next Mouser order. Too bad, I just placed an order like 2 days ago.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 min 6 sec ago
jon_slider wrote:
(...)imo, the C01 Red is pretty useless, has a low output, and terrible beam.. scuffing just makes it dimmer I do not recommend the single mode C01 Red 5mm 670nm LED (...)
I agree but using the diffuser makes C01 670nm much more sexy.
jon_slider
wow.. your kids have skills.. LOL
the good news is, since its not potted, it will be easier to fix Party
Lonelydad
Lonelydad's picture
Last seen: 1 hour 34 min ago
I dropped an NiMH AAA cell into one of my C01s lights, thinking to see how well it worked, with the idea of saving a little on cells. It lights up, but only on low. I’m guessing the 1.2v is just too low to power the high mode. It will work great if all you are interested in is using the low for nighttime navigation around the house.
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
SammysHP
SammysHP's picture
Last seen: 7 hours 51 min ago
The C01S works fine with NiMH. No problems with high.
Fescron
Last seen: 4 hours 13 min ago
Yes I use mine with only NiMH rechargables. I use the C01S daily and if the high mode starts to dim very fast after I put the light in high I just put in a new NiMH battery and recharge the old one. The light maybe doesn’t get as bright or works as long compared to non-rechargeable batteries but that’s fine by me. I always got some spares in my backpack anyway.
SammysHP
SammysHP's picture
NiMH batteries have better performance than alkaline.
gravelmonkey
!{width:500px; max-width:75%}https://i.imgur.com/psXhI4a.jpg!
Do you know if this broke with the light off or on?
The djozz torture video has the light switched on, if I remember – with the light switched off, the cell can then move inside the tube and act like a hammer, perhaps what happened with your light?
djozz
djozz's picture
Last seen: 6 hours 18 min ago
Pretty amazing that that happened with such a small and shallow inductor. But children have special talents for these things Party
Lonelydad
Lonelydad's picture
OK, I did my test with a cell straight from the package, so the voltage may have been down a little. I’ll throw the cells in the charger for a while, then test again.
Lonelydad
Lonelydad's picture
Lonelydad wrote:
* AAA-powered (Lithium-ion not supported. Unsure if it’s been tested)
I am embarrassed to admit this, but it wasn’t a C01S, it was just a C01. No wonder it would only have one output level! Dropped a NiMH into a real C01S and it works fine.
Unheard
Unheard's picture
No need to be embarrassed. Thanks for clarification Thumbs Up
