FandyFire HD2010, looks like will be 26650 compatible
159 posts / 0 new
mitro
Last seen: 1 year 11 months ago
Man... I think these companies are starting to figure it out.  It even has knurling!
dthrckt
dthrckt's picture
Last seen: 28 min 26 sec ago
I'll probably buy it either way if reports are good.  If the lens works I'll find a suitable case to carry everything and use it both ways...
CopperTop
Last seen: 9 years 7 months ago
-Now if Xtar would just make a 5000mAh 26700 and the matching XTAR WP2 "III" ...we would all be VERY happy...
-are you listening out there XTAR and szwholesale...?
-while I am at it -how perfect would it be to have the option for a second battery tube on here... imagine 2 -26700's blasting 3 amps...
OK -I'm just dreaming... but it would still be nice
I don't have one on order yet and have exceeded my monthly "allowance" (even spent next month’s too!) Somebody get one in yet and tell me just how good this is!!! –maybe I’ll be convinced to spend by February’s allotment…
...why does the picture of the flashlight in the hand look like it is more like a 100mm bezel size rather than just 63mm
yavi
Last seen: 6 months 4 weeks ago
For those interested in a multi xm-l configuration, this one looks exactly the same body but being 3 XM-L:
http://www.ebay.com/itm/CREE-XM-L-XML-3xT6-LED-26650-18650-Flashlight-To...
A version with extension tube, would be appreciated by many of us, wouldn't it?
how2
Last seen: 56 min 40 sec ago
TMart has the triple XML version  for $50
r1derbike
Last seen: 1 month 5 days ago
Interesting!
I've always wanted a short stubby, instead of a long thinnie...
This might be the 'tweener light for me!
King-Kong, here I come!
yavi
That is really tempting, thanks for the info how2.
Night Breaker
Last seen: 1 year 9 months ago
Ordered this morning Smile
This configuration will meet my needs perfectly, if the light is reliable.
On the downside, now I have to hold off ordering
http://www.amazon.com/Maha-Powerex-MH-C9000-Advanced-Analyzer/dp/B00454Y...
and
http://www.amazon.com/Sanyo-Capacity-Pre-Charged-Rechargeable-Batteries/...
for my MCU-C88 with U2 1C XML (modded by E1320 - Erik) so that my wife does not freak out about me spending money right before Xmas, LOL. Reached my limit for a while. Going to use alkalines in the C88, probably until after the holidays.
saintfire
Last seen: 9 years 9 months ago
it is a good light,how much?
Hikelite
Last seen: 6 months 19 hours ago
You obviously have the links in the posts, and also prices.
So please stop spamming with different usernames.
Kajman
I ordered the one with 3 leds, it seems to be great light if driver is made right way, otherwise, what to use there to feed 3x xml?
Chicago X
Chicago X's picture
Last seen: 8 years 2 months ago
1) Direct-drive
2) Manafont 3 x XM-L driver (2- or 3-cell)
3) DRY driver from cnqualitygoods.com (3-cell only)
4) NANJG 2.8a 3-driver sandwich
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
mitro
Wait a minute... the DRY is wired with the LEDs in parallel?
Chicago X
Chicago X's picture
Series.
mitro
Then the DRY driver isn't going to work with a single 26650, unless it has a boost circuit (which I'm fairly certain it doesn't).
yavi
A 9A driver from kaidomain and parallel the leds?
Or would the Vf difference fry them?
Chicago X
Chicago X's picture
You are correct.  I was answering the more generic question of what 3 x XM-L drive options were available.
The Manafont driver is buck/boost, but 2-cell minimum.
The NANJG driver sandwich is the only one-cell option of which I'm aware.
Chicago X
Chicago X's picture
I have a KD SST90 driver, and it's closer to 6.5A than 9A. It requires 2-cells as well.
If this 26650 torch has a single driver pushing 3 XM-Ls, then it's a new boost driver that we've been waiting for.  I'm skeptical, but hopeful that that's the case.
Kajman
Chicago X
Chicago X's picture
I have no experience with that new driver.  I ordered two for testing, and will report back.  Thanks for the link.
Kajman
I have ordered one, hope only, that it finds out how many cells are connected, that KAI didn't put constant cell protection on 5.7V and we will not be able to use it with one cell despite it can work like this. And second thing is size, but that may be solved on host already.
Night Breaker
This FandyFire HD2010 accepts a 26650 battery, and the hot spot on it is extremely bright. I look forward to testing the output on this light tonight.
I was initially planning to upgrade this to a U2 emitter, but it looks like this won't be necessary.
Preliminary indoor testing, which usually doesn't reveal too much, indicates this light will probably far exceed the throw of my 3xT6 SkyRay SR3800.
Update to come.
dthrckt
dthrckt's picture
great - finally someone has one in hand!
also - very interested in the KD driver testing, since their description doesn't make sense (ie 1 cell, 5.7v cutoff)
Kajman
Nightbreaker, update soon Smile Measure driver diameter please and maybe how much place is in there in deep?
2100
Last seen: 2 years 10 months ago
Don't forget that the S1 and TM11 accept 4.2V input for at least 2000 lumens.  But those cost much more of course so definitely more design and engineering goes into their driver.
scheven_architect
Last seen: 3 years 9 months ago
Let's hope this is a great thrower, i like it being compact.
Is it worth buying a charger and 26500 instead of using 18650?
Hikelite
With KingKongs for example you know that you get over 4000mAh even on a 10A discharge. So, yes you get better runtimes and the cells can deliver high currents if you need that now or in the future. For the price you can almost say that you have 2 x 18650 cells in one.
What charger do you have, any charger can charge 26650 cells with you use some wires and a couple of magnets.
Night Breaker
The HD2010 is a great thrower. I tested it last night at work. Beats anything I have, but my next best thrower is the UltraFire MCU-C88 modded by E1320 (Erik) with a Cutter U2 1C driven at 3.5A.
I will post beam shots soon, after Xmas. For now descriptions will have to suffice.
The HD2010 far outclasses the MCU-C88 for throw, and it spanks my TrustFire TF-R2, which has a T6 pill screwed in. However, the smaller lights are more compact. I'm currently modding a holster for the HD2010 to see how comfortable it is on a duty belt...
However, comparing these three lights, the beam on the HD2010 is more spotlight-like, whereas the C-88 and TF-R2 have brighter/larger coronas around their hot spots, which provides more of a spot/flood beam that comes in handy for lights used on night patrol.
BTW, my King Kong 26650 batteries fit in my C-88. I just can't screw the tailcap all the way down. There is a 2mm gap produced by screwing the cap on about 80%, which seems adequate. Also, the 26650 batteries charge fine with no mods/magnets in my TrustFire TR-003P4 charger that a received recently. I can charge two 26650 batteries simultaneously in this charger by just popping them in. The King Kong batteries seem very high quality. I'm thinking I'll order a few more... I also ordered a USB single 26650 charger, but I haven't used it yet because the TrustFire charger accepts the 26650 batteries.
Also, the HD2010 out throws my SkyRay SR3800 3xT6, but the flood on the SkyRay far outclasses any other light I own for sheer light output. This is why I'm looking forward to receiving my BeamTech BT-4000, which I think has started shipping.
http://www.tmart.com/BeamTech-BT4000-CREE-XMT6-18W-2700LM-5-Mode-Flashli...
This is the light that I have the highest expectations for ATM. But for now, the HD2010 is a very impressive spot/search light that I'm sure will be easy to carry on a duty belt. Last night I kept it in a cupholder, which makes it very accessible for spotlight use from the vehicle.
I'm sorry I don't do the multimeter testing to see what the light pulls. I still need to order one of those inexpensive multimeters so I can do this and report on this stuff. However, it seems to my eyeballs that this T6 is driven fairly hard, like maybe 3A or more, but this is a guess. I'm thinking the T6 is driven hard because the hotspot appears quite bright...
More updates to come on all this.
how2
Can someone post some pic of the pill and driver etc, please.
Hikelite
Buy a luxmeter, measuring the tail cap current tells only one part of the story.
