Test/review of LG 18650 HB4 1500mAh (Yellow)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 16 hours 6 min ago
DSC_7337
Official specifications:
  • Maximum Capacity: 1500mAh
  • Nominal voltage: 3.60V
  • Discharge end voltage: 2.50V
  • Standard charge current: 1.25A
  • Maximum charge current: 10A
  • Maximum continuous discharge current: 30A
LG%2018650%20HB4%201500mAh%20(Yellow)-info
This is an older high current cell.
DSC_7335 DSC_7336
DSC_7338 DSC_7339
DSC_7340
DSC_7341
LG%2018650%20HB4%201500mAh%20(Yellow)-Capacity
The discharge curves tracks fine and it can nearly constant capacity up to 30A, but the output voltage is a bit low at 30A.
LG%2018650%20HB4%201500mAh%20(Yellow)-Temp-15.0
LG%2018650%20HB4%201500mAh%20(Yellow)-Temp-20.0
LG%2018650%20HB4%201500mAh%20(Yellow)-Temp-30.0
LG%2018650%20HB4%201500mAh%20(Yellow)-CapacityTimeHours
LG%2018650%20HB4%201500mAh%20(Yellow)-Energy
LG%2018650%20HB4%201500mAh%20(Yellow)-PowerLoadTime
LG%2018650%20HB4%201500mAh%20(Yellow)-TripCurrent
LG%2018650%20HB4%201500mAh%20(Yellow)-Charge
Due to a mistake I used the low current program for one of the cells, this means 0.5A charge current and protection test only up to 7A, discharge currents are the same, except the low current program also includes a 0.1A discharge current.
Conclusion
This looks like an upgrade to the HB2 cell. The high current performance is good, but the capacity is low by today’s standard.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
Henk4U2
Henk4U2's picture
Last seen: 4 hours 32 min ago
Thank you for once in a while reviewing a battery that isn’t quite the state of the art.
But keep up the good work and someday someone sends you a “Batterie Napoléon”.
You can auction that at Sotheby’s and you will never have to work another day in your life Evil
PS Congratulations for (silently) passing the 6000 posts mark.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
