(Translate via Google)
Designed for urban cycling commuting, C01 is a versatile rechargeable bicycle headlight. By adopting the anti-glare multi-faceted reflector, it produces a equal ray, takes care of near and distance illuminations. At the same time, it prevents dazzle to the on coming people and vehicles. Utilizes Cree XP-G3 LED with neutral white color, it has better penetrability, even in rainy and foggy weathers. Three general output levels plus Strobe, SOS, and Beacon with a max output of 400 lumens, it meets the commuting and daily lighting demands. The built-in 1,400mAh high-capacity lithium polymer battery provides a maximum runtime of up to 10.5 hours which meets long-distance cycling requirements. Micro USB direct charging function allows you to charge the light at any time to ensure a sufficient power of your ride. Charging indicator, low-power warning, quick-release structure, IPX-8 waterproof design etc., C01 is your reliable partner in daily commuting, road riding, or in daily use.
packaging
Unpacking box
The product includes the main body of the lamp, Bracket, USB charging cable, user manual and the guarantee card
Features
- Utilizes Cree XP-G3 neutral white LED with better color rendering and a 50,000 hours lifespan
- Three output levels with Strobe, SOS and Beacon, max 400 lumens
- Built-in 3.7V/1400mAh Li-polymer battery, provides a 10.5 hours max runtime
- Micro USB rechargeable with charging indicator
- Featuring low power indicator and intelligent output downshift function
- Tapered surface reflector designed with German standard, reduce the hazard of glare to oncoming people
- Detachable and adjustable bike mount, fit for 19-33mm diameter bicycle handlebar
- 360-degree rotation on the mount allows easily to adjust the shooting direction
- One switch for fast and easy operation
- Versatile to serve as a bicycle light and handheld flashlight
- Made of high-intensity ABS materials, solid and lightweight
- Size: 77.5*45*31.5mm (excluding handlebar mount)
- Net weight: 87.5g (excluding handlebar mount)
- IP68 rated protection, 1.5 meters impact resistance
- Two years free repair, limited lifetime warranty
Ministry names
Installation, removal method
After installation, the body can also be rotated left and right to adjust the direction
Technical Information
With medium brightness, the time can reach 3 and a half hours
If a night ride takes 2 hours, it is enough
But it should be charged every time you come back.
Lest it’s not enough to use it again
Overall style
head, internal reflector
On the back, USB charging hole
side
The above big orange plastic button, feel good, clear stroke
fixed
Name and safety mark
Head close-up:
It can be seen that the LED is mounted on the top and shines through the reflectors at different angles
CREE XP-G3 NW
Side
After turn on. Visually feel that the LED color temperature should be around 4000K
Low
Medium
High
Animation:
Red light when charging
Charging completed, green light
Slow flash warning when battery is low
Flash warning when battery is seriously low
Operation
ON/OFF: Click the switch for ON, long press the switch for 1 second for OFF.
Output selections: When the light is on, click the switch to cycle through Low-Med-High. Next time you turn on the light, it will recall the previous output level.
Flash: When the light is on, press and hold the switch for 4 seconds to enter Strobe, another click to cycle though Strobe-SOS-Beacon.
Overall, this is a small, easy-to-use bicycle light
Because of its small size, the battery capacity is small
Remember to charge every time you ride
