LG 18650 HB5 1500mAh (Blue)
Official specifications:
Nominal capacity: 1500mAh
Nominal voltage: 3.65V
Standard charge: 750mA, terminate at 50mA
Fast charge: 4000mA, terminate at 100mA
Maximum charge current: 6000mA
Max. charge voltage: 4.2V
Standard discharge: 300mA
Discharge end voltage: 2.5V
Fast discharge: 10000mA
Fast discharge end voltage: 2.0V
Maximum continuous discharge: 15000mA
Cycle life: 100 cycles to 75% with fast charge/discharge.
Operating temperature: Charge: 0° ~ 50°C, Discharge: –20° ~ 75°
Storage temperature: 1 month: –20° ~ 60°C, 3 months: –20°C ~ 45°C, 1 year: –20°C ~ 20°C
Older high current cells (Data sheet says 2014) with fairly low capacity.
The cells has fairly constant capacity at any discharge current within their specifications and they are a good match on the discharge curves.
Conclusion
This is good tool cells, but with a older design and not that great a lifetime when used at full power.
I wonder if the HBx cells are developed in sequence, because this cell do not look better than HB4
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
